Question about Dell Inspiron 1545 Notebook
DOG CHEWED THROUGH ADAPTER WIRE IT BANGED NOW LIGHT ON FRONT OF LAPTOP KEEPS GOING ORANGE LAPTOP WORKS FINE WHEN ON MAINS LEAD BUT NOT ON BATTERY ALONE IT GOES OFF HAS IT BLOWN SOMETHING INSIDE ?
    Sniper:
  • 51 Answers
Hi, it most likely has burnt out the sub board which has the DC socket on it and/or the motherboard. But I would point it almost completely at this sub board. You would also need to replace your AC adaptor as it has a "smart chip" inside it which would have also fried. Your battery is most likely ok. Hope this helps
Posted on Nov 06, 2010
Laptop keyboard does not work after dog laid on computer
Tell dog to grab it's allowance, and buy you a new laptop
NO?
Then protest around the dog daily until it does
(No, you have to feed it)
[Hold the dog's chew toy for ransom. Chew on it a little bit so dog will get the message.
"Hey! Ain't kidding around here! Laptop or I keep this!" ]
OR,
Remove ALL power. Remove the AC adapter (Charger), and Battery.
Press the Power On button, and hold it in for a count of 10 seconds.
(And I mean 10. Count; 1001,..1002,..1003,...etc)
Let go of the Power On button. Do this procedure two more times.
Reinstall Battery, THEN reattach AC adapter to laptop, and THEN plug AC adapter into power.
WAIT 1 minute,....turn the laptop on.
Post back in a Comment.
Regards,
joecoolvette
[Merry Christmas to all who are celebrating it! ]
Dec 25, 2012 | Compaq Computers & Internet
My battery won't charge why not
If it's connected properly, that sounds like a dead battery. Try wrapping it in something waterproof and freezing it overnight. If that doesn't work, replace it.
Apr 06, 2011 | Toshiba Satellite A135-S4527 Notebook
My Ac Adapter i think is broken and my Xbox wont turn on but the AC adapter has a orange light that when i unplug it the orange light still does not go off.
Hi if the main brick has got an orange light then this is telling you the mains lead is working so try doing the following
1 unplug all leads from back of xbox and turn the power brick off at mains
2 plug the power lead back into the xbox, now when you push it in and it stops try pushing it in a little bit further usually they just dont push in far enough and it can be quite tight so make sure you are pushing it in hard enough,
3 now plug the video lead in and try switching it on,
keep an eye on the orange light whilst you switch it on if it comes on then it should continue to work if it dont come on watch the orange light and see it if changes color at the same time your switching it on, it will either flash green or red just once before going back to orange.
let me know what happens ok
Nov 28, 2010 | Microsoft Xbox 360 Console
My Computer Wont Charge!!
if the charger power up your laptop,that means that the charger is working fine,what you need to do is just replaced the battery
Jun 28, 2010 | Lenovo IdeaPad Y510 Notebook
Laptop wont turn on orange light flashing on front indicating power plug
There could e a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Try also to reseat the main components of the notebook: the battery, the AC adapter, the memory modules, & the hard drive.
After that try switching it on & see if the problem was fixed.
Nov 14, 2009 | Toshiba Satellite A135-S2276 Notebook
How to wire a tach on 05 heritage softail
Locate & route Black lead to ground / 2004-later softail: On the frame strap under the seat directly in front of the battery.
Locate & route the pink lead to Signal / For 2004 & later FXST/C/I The #3 cavity in the connector {39b} on the back of the speedometer. The socket terminal on the signal (pk) lead fits the #3 cavity.
Locate & route the Orange and white lead to power / Ummm.. it's saying for 2004 and later to adapt to the fuse block For earlier [ For 1996 to 2003 softail: locate the power lead (o/w) in the tail lamp pin connector {7a} under the seat behind the right rear corner of he battery.] "here you are looking to run it to a fused line, not directly to power/battery" I hope this helped.
Sep 06, 2009 | 2000 Harley Davidson FLSTC Heritage...
Laptop computer won't turn on...
this is ur battery problem so just get ur baterry cheked
Jun 25, 2009 | HP Compaq Evo n610c Notebook
HP 530 Laptop, NO Power
Um apart from growling at the dog lol you will probably need a new keyboard section.
Apr 25, 2009 | HP 530 Notebook PC
Dell inspiron E1505 won't charge or power on period!!!
Sounds like you might have a bad dc power jack. ifyou wiggle the jack around where it plugs in on the computer, does the powr light come on?
Mar 30, 2009 | Dell Inspiron E1505 Notebook
Dell Inspiron 1545 Notebook Logo
Alun Cox
