Question about Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub Washer
Kanmore heavy duty super capacity washer does not spin and belt is off and stretched'
My kenmore washer appears to have a belt which looks to be stretched and worn. When i have the washer on spin it hums very loudly and does not spin. can you help the model #22642100 ser#cm1741104
    Genius:
  • 1,036 Answers
There are lots of appliance retailers online. It pays to shop around, but this is one of them that supplies your belt.
http://www.partselect.com/AppliancePartList.aspx?Brand=Kenmore&Appliance=Washer&ModelNum=&Type=Belt&MinSize=U&MaxSize=U&Electrical=N&Metal=N&Plastic=U&OneColor=Y&PageSize=15&FirstPart=1
Hope this helps.
If it solves your problem, please rate as "Fixya."
If it is of some help - then "Helpful"
Thanks.
Posted on Jun 14, 2008
Heavy duty super capacity plus
You dont. If it is making noise drum bearings or idler needs replaced
Nov 03, 2013 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore 80 series Heavy Duty Super Capacity Plus that stopped turning on.
If the drum does not turn at all the motor, may be bad, belt may be off, the tensioner may have popped out of it's mount.
If it turns very slowly the belt is slipping. It may be stretched and needing replacement or again the tensioner may have come free from its mounting
Apr 04, 2010 | Dryers
Kenmore Washer 90 Series Super Capacity will not agitate or spin.
http://appliancejunk.com/forums/index.php?topic=3437.0
Yes, you have a direct drive coupling problem. Use this video to replace your part.
EZPZ.
Aug 13, 2009 | Kenmore Washing Machines
What is the capacity of my Kenmore washer?
3.2cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Old Washer won't spin or agitate
You found a belt? Most w/p washer do not have a belt they are direct drive. take off the pump and motor to replace the motor coupling, 2 plastic pieces w/ a rubber in between
Feb 15, 2009 | Whirlpool Washing Machines
Kenmore 90 plus series: heavy duty super capacity won't agitate
this is the site to find out how to fix your washer.
you have a broken drive coupling.
it probably wont agitate or spin, but will fill and drain.
you need to remove 2 screws from the control panel, hinge it back and then remove the 2 brass colored clips that hold the cabinet to the base. once you do then pull the entire cabinet forwards to a 45 degree angle and pull it off the base.
then pull the 2 clips off pump and then 2 more on the motor. that will allow you to get to the drive coupling. you will find it to be broken.
replace it with part number 285753a for about 15-20 bucks.
Jan 31, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Won't spin or drain
Check to make sure your lid switch is working.
Nov 17, 2008 | Kenmore 22422 Top Load Washer
Kenmore 80 series only 3 yrs old, won't, spin and the agitator appears to be stripped
your agitator dogs are stripped there about $10.00,remove cap to replace. easy,need 1/2 to 3/8 adapter or 7/16 socket depending on model. and your coupler is broken about $20.00 its what runs yous washer its like your belt under neath between motor and transmission , less cloths max water will stop it from happening again
Nov 09, 2008 | Kenmore 24032\24036 Top Load Washer
Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub Washer Logo
169 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
