Question about Canon Office Equipment & Supplies
I have canon ir4570, Very often for a week, copies do not fix the ink, although lamp & teflon is already changed. lot of remedies done by engineers, but of no gain. what to do.
I have a problem in canon IR4570 it shows error E000 i replaced the heater element because it was broken, but after replaced the heater ,i switch on m/c the element cracked and 5 element is cracked right now ,Please help me what is the problem
thanks
Posted on Aug 21, 2011
  • 21 Answers
I think pressure roller problem.check it
Posted on Nov 07, 2010
Why error code E000000-0001
it is the encode on the fixing unit / fuse unit change the fixing film and then reset the error code by entering service mode then clear it
Oct 12, 2015 | Canon ImageRunner 4570 | IR4570 |
How do i solve an error e000-0000 canon ir 2002n please
Description
The main thermistor reading does not reach 40C 14 sec after the fixing heater goes ON (fixing low temperature error)
Remedy
1) Wiring Is the connection of the connector (CN8) on the power supply PCB and the connector (J103) on the DC controller PCB and the wiring to the fixing assembly normal? NO : Correct the connection and wiring. 2) Fixing assembly Try replacing the fixing assembly. Is the fault corrected? YES : End. 3) Power supply PCB, DC controller PCB Try repacking the power supply PCB. Is the fault corrected? YES : End. NO : Replace the DC controller PCB. 4) Error With the power switch ON, clear E000 through E004; then, turn off and then on the power switch.
Aug 05, 2015 | Canon Office Equipment & Supplies
How do I resolve the code e00010-001
Hi
I found the following description for your error
Description:- The rotation of the main motor is faulty.
Detection is executed every 100 msec after the start of motor rotation; however, the drive detection signal is absent for 2 sec.
Remedy:- Replace the main motor. Replace the DC controller PCB.
This was here:
Error Codes Canon iR4570 Code E010 0001
On this webpage where you can change the code you are receiving to a different one if required (or view them all) by using the drop down menus along the top of the page. You can also change the make & model using the drop down menus if you wish. You can also get a Service Manual from this page using the link.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Jan 01, 2015 | Canon ImageRunner 4570 | IR4570 |
My canon photocopier ir2018 is showing system error e007. What do I do to sort it out?
this is the problem with the teflon of the fixing unit.If ur a rep then u have to replace the teflon(fixing film) or u have to a call a tech rep to do so
Jun 30, 2011 | Canon imageRUNNER 210S Copier
Using a canon ImagePROGRAF iPF710, reviewing the nozzle check pattern, it is clear that the cyan ink area has a line missing through it, is this a problem with the print head? I have done numerous print...
you propably must change the prind head. check the metters info, dont make a lot of prind head cleaning because you lose a lot of ink and you will rise the cost if you need to buy and printhead and inks
Oct 13, 2010 | Canon imagePROGRAF iPF710 InkJet Plotter...
My Canon MP830 Printer will mot work. Alarm blinking and copy light blinking . How do i FIX? Dr.s' office...help!!
Canon MP750, MP760, MP780, MP830
The Unset mistake:
##341. Maintenance jet waste ink capacity full
##342. Cleaning absorption waste ink capacity full
##343. Ink detection waste ink capacity full
1. Include the printer.
2. Press button Menu , then Scan , Copy and once again Scan (entry in service mode, on дисплее will appear #1 SSSW)
3. The Arrow to choose 7. Printer test , press Ok .
4. The Arrow to choose 5. Ink abs capa , press Ok , install importance 0 .
5. Switch off the printer.
Sep 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Dpi scanner setting for canon ir4570 location?
For scanning doc.s it can changed in network scangeartool, for copier/ printer it was in copy/ print setting under user settings,
Jul 07, 2009 | Canon Office Equipment & Supplies
Canon IP5200 printer - "duplicate ink tanks"
Hi i have Ip 5200 but the pawer lamp and yelow lamp are blink
Mar 26, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
163 people viewed this question
old marine
old marine
