Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Light flashing and control won't work
We had a power outage, now the twin lights are flashing and my wall unit will not operate the garage door, either up or down.
  • 1 more comment
  • sparkydoodle Jun 21, 2008
    I have the same issue - the lights flash but the door won't open.
    HElp
  • campwags Jun 23, 2008
    After power outage, GDO only makes a click, click... and nothing happens.
    The led lights will flash 5-6 times and nothing. Lights on side of unit will not come on even when light button is pushed.
    Is this a capacitor problem?
  • mikeburgdorf Aug 01, 2008
    The light is rapidling flashing on my garage door wall unit but everything is working fine. It started earlier this week but I cannot find anything wrong. Any ideas on why the flashing would start?
    Mike
    Scholar:
  • 91 Answers
Your opener has been hit by lightning or power surge.
If it's not too old you can replace the 'back board' (the computer board on the back of the opener.) Also If the opener has safety sensors one or both of them may be burnt out too, and if it was really bad then the rpm sensor will go too. So you could be looking at paying half the cost to repair or just get a new opener. Up to you, and get a surge protector. Lift master has a good line of products and makes thier own surge protectors for thier products.
Posted on Jun 27, 2008
Hello!WE had recent power outage ,now door opener won't work.unit has power lights come on when remote pad pressed,but nodoor action?thank you
Along with the power outage you probably also had a power surge. You need to pull the logic board and check the printed circuit board for burnt or missing traces. Unplug the unit first.
Sep 10, 2011 | Sears Craftsman LiftMaster Chamberlain...
My Chamberlain Liftmaster Formula 1 garage door (2002) has stopped working. The power is on -- light turns on when I push the wall mount button. But the remotes no longer work. The door does not move. ...
The light by the learn button may be sending a diagnostic code. See if it is flashing a number of times, pausing and then repeating. Count the flashes. Is your door stuck in the open posititon?
Jun 11, 2011 | Sears Craftsman LiftMaster Chamberlain...
The wall control unit is flashing but it will close and open the garage door, but when I press the remote from the car the light flashes twice and it will not shut the door.
You may have 2 problems here. First press and hold the lock button on the wall control for 3 seconds. This should stop that flashing and your remotes should work. If the main light is flashing when you try to close the door you need to check that your door sensors are pointed at one another and the small light on each one is lit and not flickering. Tweak them a little.
Mar 01, 2011 | Sears Craftsman LiftMaster Chamberlain...
Garage door opens w/ Power outages
You will need to get a surge protector on this unit first of all. You will have to replace the logic board and maybe the wall button or sensors depending on how bad the surge was. Any time the power goes out the logic board can be affected by it. Thanks BB
Oct 06, 2009 | General Electric GE 13-438 Overhead Garage...
Garage door only opens with wall unit
a component in the wall unit is failing , that makes the conection happen when the remote signal is recieved , ( it is recieving the remote signal but not sending it out to the control circuit for the motor )
Dec 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage Door only opens with wall unitq
The unit is in the lock mode, push and hold the lock button in for about two seconds and the green LED should stop flashing. Your remotes should work.
REMOTE CONTROLS WILL NOT WORK-WALL BUTTON FLASHING RAPIDLY
Does your wall switch have a lock feature? By pressing the lock button, the remote control is disabled. A flashing light indicates this feature has been activated.
To deactivate, press and hold the lock button for 2 seconds. The flashing should stop and your remote should work again.
Dec 03, 2008 | Sears Craftsman LiftMaster Chamberlain...
Opener on wall will not work after power outage
Actually it sounds like the vacation lock has been enabled. To turn it off press and hold the lock button for 2 seconds and test it out. If this is not it then you will need to replace the logic board and get a surge protector as well. Thanks BB
Nov 11, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,133 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
