M heater comes on and gets hot but fan doesn't start blowing. I turn it down to make sure not to overheat the furnace. It has happened several times now and sometimes it will work for awhile then stops working again. It's an older furnace, I live in a 40 Year old mobile home and suspect it is the original furnace. Any ideas why my fan works one time but not the next?
  • 1,711 Answers
Usualy the fan absorb dust and dirt which located on its axis and support ball bearing and this making it more hard to rotate so some times rotate and some times is not. However if you are capapble you desasemeble the motor and clean the shaft axis and lubricated the ball bearings, if its is dificult for you, you can use a lubrican oil in between shaft axis and bearings this can help it run better.
The final solution is to replace the fan motor
Posted on Nov 06, 2010
I have a evcon EB12B where is the reset button. The blower stays on even if heater is turned off at thermostat. I have to turn off in breaker box
This may need the furnace technician to repair.
I can locate the manual for your heater and the parts list but I cannot locate any reset button.
Blowers that run all the time have either a stuck fan relay or depending on age, have either a defective "fan control and limit switch" or a breaker that operates the fan. When the furnace ignites the fan waits until the air get hot before it blows. When the heat goes off, the fan continues to run until the furnace is cool.
You probably can replace the parts yourself but please make sure it runs safely. The making sure is what the furnace tech will do.
Apr 18, 2015 | Heating & Cooling
1990 dodge dakota 2.5 over heats temp gauge erratic
For car running hot and overheating issues, I suggest to you go through this help links. Click this link below and go through the troubleshooting procedure to take care of the problems: ----
temp gauge goes erratic? http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html
Temperature gauge keeps fluctuating up and down close to red? http://technoanswers.blogspot.com/2012/01/temperature-gauge-keeps-fluctuating-up.html
Car runs hot? http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
-----------All types of car overheating problems and troubleshooting?
http://technoanswers.blogspot.com/2011/11/all-types-of-car-overheating-problems.html
Car freeze overnight and started overheating while driving?http://technoanswers.blogspot.com/2012/01/car-freeze-overnight-and-started.html-----------Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
--------overheating? http://schematicsdiagram.blogspot.com/2011/12/buick-century-overheating.html
----------Car engine Overheats and transmission starts slipping?http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
Temperature gauge does not move and no heat when heater is ON? http://technoanswers.blogspot.com/2012/01/temperature-gauge-does-not-move-and-no.html
This details will help.Thanks.
Feb 07, 2012 | 1990 Dodge Dakota
My Buick skylark doesn't leak but it over heats..
To troubleshoot this types of problem,click the link below :---
All types of car overheating problems and troubleshooting? http://technoanswers.blogspot.com/2011/11/all-types-of-car-overheating-problems.html
heater blows through defrost?
-http://howtobyme.blogspot.in/2012/02/heater-blows-only-from-defrost.html
--------Go through the procedure to confirm the issue.
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
This will help.Thanks.
Dec 08, 2011 | 1995 Buick Skylark
The pole buiding 24 in hanging Dayton sometimes the blower comes on like after 5 minutes after everything else kicks in and sometimes like when its supposed to and sometimes not at all?? All the electric...
I'm not sure whether this is a gas unit or not. With many gas heaters, the blower comes on when the heat exchanger gets hot enough and goes off once the heat exchanger cools. Other things are happening before the blower goes on. The blower is normally controlled by a "fan control thermostat". This stat actuates the blower when the furnace is hot enough so that cold air is not being blown around and allows the blower to run until the furnace cools enough to get out the remaining heat after the flame shuts off but not so long to again allow cool air to blow around. If this fan control is malfunctioning, you will get erratic runs from the blower or the blower may not run at all or run long or continuously. The fan control is the first thing to check.
Gary
Jan 31, 2011 | Dayton Gas Furnace Heater
Heater blowing hot then suddenly blows cold and engine overheats. Intermittent problem. After engine cooled may overheat again with heaters blowing cold then suddenly heater blows hot again and...
I have written a tip on this.
You may have a couple of problems. I would first replace the thermostat, and make sure you have the proper coolant(ant-freeze) level.
Please let me know how it goes and if you need further help I am here.
Feb 09, 2010 | 2002 Toyota Celica
My furnace heats the house well, but during the cool down it actually blows cold air dropping the temperature causing the furnace to re-ignite. How do I adjust? Goodman - GMS9/GCS9
Depending on the age of the furnace you may be able to adjust the cool down. On some furnaces there is a silver box usually made by honeywell. This is your fan limit control. If you take the cover off you will see a dial with different temperature settings with 3 pins in a grove. The first one is fan on with temperature rise this turns the blower on when the furnace starts and warms up. The second is the fan off after furnace shuts down, this would be the one you want to adjust to a higher temperature to keep the blower from blowing cold air. The last pin is the high limit if the furnace gets to this temperature it will shut the furnace off but keep the blower running. Make sure that the thermostat fan option is set to auto and not on.
Jan 02, 2010 | Goodman GMS90703BXA Heater
Coleman gas furnace. Burner will re-fire for a few seconds during the cooldown. Model G8C07512MUB12A
This is a little complicated because it can be several things and you need to provide more specific info....It could be your furnace is shutting off on the High Limit...which means your furnace is running too hot...check the filter , return air vents etc would be an airflow problem...dirty blower....Furnace can be too big for your house....when the furnace shuts off on High LImit , the fan will continue to blow air , cooling it down as usual and once the furnace cools enough to reset the high limit trhe furnace will Ignite again as long as the thermostat is still calling for heat . The furnace could also be running too long and getting too hot....your Ductwork can be too small...many factors come into play
Oct 25, 2009 | Heating & Cooling
We have a Janitrol PGB 048125-1 unit and it is not blowing heat. the fan comes on when in fan only mode on thermostat but once we turn it to auto it goes off. we cannot get the unit to blow hot air. does...
If the unit is newer than 10 years I guess there will be no pilot light per sey. You will have to look at it to tell for sure. Here it is supposed to work. When there is a call for heat the thermostat will close and send a signal to the furnace to start the exhaust blower. When the blower gets up to speed, it closes a pressure switch that will send voltage to the gas valve and to the igniter. The igniter glows or sparks lighting the pilot. Once the pilot lights it sends a signal that all is well, then the gas valve opens up more and the burner(s) light. There is a sensor that tells the control board when the flame has stayed lit. Once that is done, after a period of time or as the heat exchanger gets to a specific temperature, it will turn on the room air blower and blow hot air. Once the thermostat has been satisfied, the furnace turns off. Now, get in front of the furnace and with the door panels off (you may need to tape down the door safety switch to make this work) watch the furnace go thru each step I described. Once you see where the problem is, you can start the proceed of repair. There may even be a flashing light indicating a problem. Find the wiring diagram on the furnace and look for a diagnostic chart and compare the number of blinks to this chart.
Oct 17, 2009 | Goodman Heating & Cooling
Temperature gauge fluctuates and the heater blows cold air
Definitely check your fluid level in your radiator. Top it off all the way. I've seen that happen multiple times on cars that were low on anti-freeze. If that doesn't work try replacing your thermostat. It's cheap and the easiest place to start if topping off the fluid doesn't get you fixed up.
Oct 16, 2009 | 1997 Chevrolet Camaro
Heating & Cooling Logo
243 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
