I'm hearing two programs on my toshiba tv at the same time on cable 26 with rogers cable connection.
  • 19,396 Answers
Hi.
Since cable channels are digital, the problem is not caused by interference. With digital channel interference causes noise (no audio or white noise), rather than reproducing analog signals from different channels. The problem is the Rogers box. The Rogers box has features that allow you to listen and watch more channels at the same time. In normal condition this can only be done activating PIP features.
Your Rogers box is instead broadcasting double audio on channel probably because faulty.
If the second audio is very faint, there is also the possibility of an analog radio signal interference being caught by one of the audio wires. In that case the sound will not be a TV channel audio, but a radio channel from local transmission.
If you get audio from two different TV (or digital radio) channels at the same time, then you probably have a defective Rogers box.
Try disconnecting box power cord for five minutes. Also test using different connection to TV if possible.
If that does not work, call the number listed in Rogers documentation. The operator will ask to perform a simple test on the box, and then willl eventually send you a new box.
Regards.
Ginko.
See also TVRogers
Posted on Nov 06, 2010
Toshiba 15 yr old tv, without HD box getting all channels execpt CP 24, i m in toronto area with roger cable
and you have a question . you get anything that is cable provided if you want 24 you need to check with roger cable
Jan 29, 2015 | Toshiba 32A33 32" TV
Need a remote code for fluid tv using rogers remote
Hi MiMi I attempted to search for the Code for your TV under several of the Rogers remotes and was unable to find one. You can do a general search for a code on any of them following some minor instructions. Navigate to link , choose the remote that looks like yours and then to the left will be choice to search all possible codes. Hope this helps. Good luck Rogers Cable Remote Support
Nov 04, 2014 | Televison & Video
Can not change my toshiba remote back to dish mode how do i do it?
The TV have been changed to program 12. Press the TV/AV button to come back to AV.
Jul 13, 2014 | Toshiba 26HF84 26" TV
How do you use PS3 and DVD player with the Toshiba 32Dtu2 LCD TV?
The PS3 can be hooked up to the tv using either a HDMI cable or the old RCA (Yellow, Red, White) cables. If you are having problems viewing a picture or hearing sound, here is some trouble shooting you might want to try.
Connect the PS3 using both the HDMI and RCA cables. select the HDMI input on your tv. turn on the PS3. If you cant see a picture, press and hold the power button until you hear 2 beeps (this will take about 15 seconds). This resets the PS3 to the old RCA cables. Select the RCA input on your tv. Hopefully you can see the image and hear the PS3 now. Go to the settings on the PS3 and change the display settings to output video through the HDMI. Remember, your tv can only go as high as 1080i resolution, so you wont see anything if you select the 1080p resolution.
If this didn't work, you might have a bad signal though the HDMI cable. Unplug the tv and PS3 for atleast 30 minutes, and then connect the PS3 to the tv before you turn either one on.
If this doesn't help, then you might have a HDMI cable that isn't recognized by either your PS3 or your tv. Try replacing your HDMI cable.
Hope this helps!
Sep 19, 2011 | Toshiba 26HF84 26" TV
I'm trying to connect my DVD to the TV I can hear sound but can't get a picture and I get the message 'no video signal'
Connect the yellow video cable from DVD player to TV's yellow video input. See diagram below. Connect white RCA audio cable and red RCA audio cable as shown. Be sure to select the proper input on the TV.
Apr 08, 2011 | Toshiba 26AV500U 26 in. LCD HDTV
Can't get cable to work on Toshiba 40E200U1. Cannot get a cable input on tv. Can get the dvd to work though. We have a roger's PVR too
If you can get the dvd to work, probably nothings wrong, you have to just 1. find the right input which in your case is cable. 2. Make sure you program you set in the cable input. Make sure not on air. If you have a some sort of cable box, then it should work through channels 3 or 4.
Dec 27, 2010 | Toshiba Televison & Video
How do i program my channels
Hello
Your Toshiba tv can be automatically tuned to all stations. The procedure follows.
Programming channels automatically
Your TV can automatically detect all active channels and store them in
its memory. After the TV has stored the channels in its memory automatically,
you can add or erase channels manually.
To add channels automatically:
1. Press MENU, then press "left arrow" or "right arrow" button to display the SETUP menu.
2. Press "Up arrow"or "down arrow" until the TV/CABLE
selection is highlighted.
3. Press "left arrow" or "right arrow" button to highlight either
TV or CABLE, depending on which you use.
If you use an antenna, choose TV.
If you use cable, choose CABLE.
4. Press "down arrow" button until the CH PROGRAM selection is highlighted.
5. Press "left arrow" or "right arrow" button to start channel programming. The TV will automatically
cycle through all the TV or Cable channels (depending on which you
selected), and store all active channels in the channel memory.
While the TV is cycling through the channels, the message
"PROGRAMMING NOW-PLEASE WAIT" appears.
6. When channel programming is complete, the message "COMPLETED"
appears.
7. Press CH UP or DOWN button to view the programmed channels.
OK.
Dec 14, 2010 | Toshiba 26HF85 26" TV
How would i program my rogers remote to my lg tv to be able to change the volume without having to use the two remotes
Please rate this solution if you find it helpful:
It would help to specify the model of remote control or TV, however, here is the guide to programming your Rogers remote for any television:
http://www.rogersdiscover.com/cable-tv/learn-about-your-rogers-remote-control/
Oct 14, 2010 | LG 42LC2D 42 in. LCD HDTV
Toshiba 26 inch lcd tv/dvd combo lost picture
I have same problem with a 7 month old Toshiba 26LV610U LCD TV/DVD combo.
Feb 10, 2010 | Toshiba 26HLV66 26 in. LCD TV/DVD Combo
Cannot program Cable remote to control panasonic 26'' LCD
the issue is with time warner remote. contact the cable company.
Feb 27, 2009 | Panasonic Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
