Question about Fujitsu Siemens SCENIC E600 Green PC (LKN:GBR-655111-041) PC Desktop
No ethernet controller - Fujitsu Siemens SCENIC E600 Green PC (LKN:GBR-655111-041) PC Desktop
You can buy an ethernet controller that pligs right into any USB port.
Posted on Nov 06, 2010
Need ethernet controller
Hi Ethernet controller is a hardware built in connected to your motherboard and NIC (network interface card ) is a device that you can use if the motherboard does not have a built in Ethernet controler.If the motherboard of your computer do not ahve a built ethernet controler you should go to your nearest store of computer parts where you can purchase it . Ethernet controller and NIC are devices that will provide your computer to have an access to connect from router,pc,modem etc. going to your computer using the Ethernet cable.
4_20_2012_11_44_48_pm.jpgABOVE IS A SAMPLE OF NETWORK INTERFACE CARD
ABOVE IS A SAMPLE OF ETHERNET CORD
Hope my solution will provide you an idea about what your looking for .
Apr 20, 2012 | Computers & Internet
Not detect ethernet controller for dell optiplex 210L i looking for the driver
You want to try and see if there is a driver update for the ethernet controller. Go to: START> RIGHT CLICK "MY COMPUTER"> then PROPERTIES> DEVICE MANAGER> NETWORKING> ETHERNET PORT. You can roll-back the driver or you can try to update the ethernet driver using Windows Update Program. Make sure the driver is located in the device manager system and windows recognizes it. Your Ethernet Controller is a discontinued product. If you can't seem to get the ethernet controller to work and don't have the Floppy Disk Driver for it, then I suggest replacing it with a new stand alone ethernet controller that uses PCI or PCI-E ports. You can find some at Best Buy and Staples. They are easy to install and they don't use your motherboard memory and are not integrated on motherboard. I hope you find something that works and you can get back online again.
Jul 22, 2011 | Computers & Internet
> no Ethernet controller
Does your motherboard have a built-in Ethernet controller?
Are the correct device-drivers loaded, so that Windows can use that controller?
Do you have an add-in Ethernet adapter connected to a PCI slot on the motherboard?
Jun 26, 2011 | Computers & Internet
D945GCCR Motherboard: i dont have a ethernet controller ethernet contro...
dude there is and in built ethernet just installdriver or maybe built in would be disabled ..enable from bios and try again or just buy new 1 it will cot not more than 300rs
May 17, 2010 | Intel D945GCCR Motherboard
Lan terminal not working
first check for all the drivers in the device manager.... if every thing is perfect in driver side, then check if the ethernet/ lan is enabled....
then check is the light in the ethernet adapter is lit, when you plug any ethenet cable in it... still if it is not working, then finally try to update the latest driver for the ethernet controller.... if nothing works, then buy an pci ethernet card and use it..... you can also buy external cards like usb to ethernet converter... even belkin manufactures usb to ethernet controller....
May 09, 2010 | ASUS P4P800 SE (890552603657) Motherboard
How i istall ethernet driver from internet
If you have no internet because the ethernet controller was not installed, you will need to download the ethernet drivers from another computer.
To do this, you will need either the motherboard model or the ethernet controller model. Search google for your motherboard model, and then on the drivers page, find "LAN drivers". Download the drivers, save them to a usb and transfer and install them to your pc.
Feb 01, 2010 | Broadcom BCM5721 NetXtreme Ethernet...
''!!! WARNING: The switch is not usable !!!''
Unfortunately the show stack isn't showing any results other than it is either a hardware or software fault. I am guessing it is a fault with the hardware as the show version in your first post states "interface Ethernet-controller 4 failed POST POST error status : general error occured".
Ethernet-controller 4 is one if the gigabit ports (poss fibre port), so if you have anything attached to those, disconnect and reboot the switch and see what happens. If that doesn't work, you could try reinstalling the IOS, but at a guess I would say its a hardware fault.
Jun 01, 2009 | Cisco Catalyst 3550-24 24-Port Ethernet...
Ethernet controller has a yellow ! makr after it
reinstall the ethernet adapter driver from the dell drivers and utilities and extract the necessary ethernet driver under network driver
Apr 04, 2009 | Dell Latitude C610 Notebook
Pleas i m not getting the ethernet controller
You need to re-install your Ethernet driver.If you have Driver CD with you then first uninstall the Ethernet driver from device manager and install the Ethernet driver from you driver CD.
If you don't have driver CD with you then You can download ethernet driver by Clicking here.
Thanks
Mar 04, 2009 | HP Compaq nx6115 Notebook
Ethernet controller problem
go to device drivers and update the Ethernet drivers
Aug 07, 2008 | Intel DG31PR Motherboard
Fujitsu Siemens SCENIC E600 Green PC (LKN:GBR-655111-041) PC Desktop Logo
233 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
