Question about Asrock P4I45GV R5 Motherboard
Show me the jumper setting of P4i45GV motherboard
    Genius:
  • 1,672 Answers
theres a lot in the net that you could download the manual for your BOARD, in pdf file!!
Posted on Nov 06, 2010
P4i45gv motherboard can support 250gb ide harddisk
Hi
The motherboard has 2 IDE connectors on board, specified to ATA 100 so I would be very surprised if a 250Gb IDE drive didn't work wth the board.
It is vital however if you have more than one device connected to one of the IDE ports (each port will take 2 devices) that the jumpers on the drives are correctly set to "Master", "Slave" or "Cable Select" as necessary, to ensure that both are recognised
Hope this helps
Cheers
Aug 27, 2014 | Asrock 845GV (P4I45GV) Motherboard
160gb internal harddisk can support p4i45gv
Yes, this board will support that capacity drive provided it's using an IDE interface and it's 3.5" in width.
Don't forget to check your jumpers!
Hope this helps!
Aug 23, 2014 | Asrock 845GV (P4I45GV) Motherboard
If its coming then it means you need to change the CMOS jumper settings. how ???????????
1 and set for standered 2 and 3 are reset but i would take out the battery then put it in again
Aug 07, 2013 | Asrock 845GV (P4I45GV) Motherboard
How to change jumper on intel p4i45gv
Here is the link to the manual for your motherboard. It is a PDF file.
ftp://europe.asrock.com/manual/p4i45g.pdf
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
Jumpers are under Section 2.7
Sep 05, 2012 | Asrock P4I45GV R5 Motherboard
Off mode in 5 seconds
Goodday!
Try to reset the settings of your motherboard, there's a jumper on your motherboard try to change it to reset.
Thanks and godbless!
Apr 04, 2011 | Asrock P4I45GV R5 Motherboard
CMOS Battery do no work
Just change your CMOS battery with a new one and after that goto the bios settings and update the time and dare.
After that just save the settings and then check that the warning message is coming or not.
Mar 09, 2009 | Asrock 845GV (P4I45GV) Motherboard
Mainboard problem
check your power supply the voltage and check all your jumper settings on the motherboard
Nov 07, 2008 | Asrock P4I45GV...
Please help me
Hi
Check ASROCK P4i45GV R5.0 User Manual Page 17 - http://download.asrock.com/manual/P4i45GV%20R5.0.pdf
Note: Check Page 11 for the CLRCMOS0 location on the motherboard. From the picture CLRCMOS0 is number 18. You can locate CLRCMOS0 just below the CMOS Cell Battery.
Turn off the computer and unplug the power cord, then use a jumper cap to short the pins on CLRCMOS0 for 3 seconds. Please remember to remove the jumper cap after clearing the CMOS. If you need to clear the CMOS when you just finish updating the BIOS, you must boot up the system first, and then shut it down before you do the clear-CMOS action.
Regards
Mike
Mar 22, 2008 | Asrock P4I45GV R5 Motherboard
Check cmos error
Read this only if you are sure that you have replaced the correct type of battery & you have set the jumpers to the default locations.
It is not the problem with the battery or the charging problem (Actualy CMOS battery is not Recharable )..in most cases.
The problem is the battery holder in mainboard where we put the battery IN. eventualy or accidently these Pins from the Battery Holder are made loose or not contacted with the battery.i had the same problem and the solution was to adjust the Battery holder to seat the battery in proper way.
May be This helpe
Jul 25, 2007 | Asrock P4I45GV R5 Motherboard
Restarting problem
constant restarts are down to a faulty driver or the cmos battery needs replacing, or short the motherboard cmos jumpers and reset the motherboard settings
Asrock P4I45GV R5 Motherboard Logo
151 people viewed this question
Top Asrock Computers & Internet Experts
Joe Negus
Joe Negus
Davit Mamyan
Davit Mamyan
Rajendra Singh
Rajendra Singh
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
