Question about Adobe Photoshop CS2 for PC
Smoke who to create smoke affect in photo shop
  • 75 Answers
Dude,follow these steps and u will make it.
1)first, make a new layer and set your foreground color to a light tone of grey which suits the color of smoke and the background color to black to have a stark contrast.
2)make ur foreground color active.press alt + backspace on the keyboard by making sure the new layer is active.
3)go to the filters menu and choose noise>add noise.
4)play around with the noise values until u have a clear contrast in the add noise area.
5)click ok, and go back to the filter menu, blur>motion blur. increase the value just slightly.
6)now, u will have a kind of a rainy effect.all u have to do now is to go to filter menu>liquify and choose a slightly medium sized brush and warp the layer to ur heart's content until u get a shape of the smoke. At this stage, it looks somewhat like smoke, but to add more reality, reduce the opacity values slightly to see the real effect of a smoke.
7)if u want to see the smoke more clearly, just adjust the levels in the levels command.enjoy!!
7)thank you! If you have further doubts, please make sure u post a question, we are here to help u!!!!!!
Posted on Jun 16, 2008
96 Toyota Corolla wiper switch is releasing smoke and fluid is shooting out by itself... what's wrong with it?
Julia, Unhook battery if switch is smoking with key off. Some wires may have melted them selves together, creating a short in switch. Take into a good shop and have them diagnose and estimate repair.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
May 25, 2016 | Toyota Cars & Trucks
I uninstalled then reinstalled Facebook :n my Android phone and all account information including friends and photos is missing.
Most likely you have not logged into the Facebook account you were using. Perhaps you accidentally created a new Facebook account. All of your friends and photos are stored on the Facebook server so reinstalling the Facebook app on your phone will not affect these. Be sure to login via the email address you used when you setup your Facebook account.
Nov 29, 2014 | Computers & Internet
Vs v6 95 holden whining noise out of wheels or under car
None of those spares would affect the car by creating any noise. I always recommend that you find a local shop to give it a listen.
Jul 13, 2012 | Cars & Trucks
2000 MAZDA 626 IGNITION SWITCH
I have the exact make, model, year in the repair shop right now with the same symptoms. Horrible screeching noise after starting the vehicle, and smoke coming from the ignition area. Most likely it is a short in the ignition switch. It could have also affected the starter module but I would start with the ignition switch.
Jun 22, 2012 | Mazda 626 Cars & Trucks
Electric weed wacker motor smoking
If the motor is smoking it will be shot, probably cheaper to but a new machine rather than changing the motor.
Mar 11, 2012 | Toro Electric Trimmer
Why can I not erase background in my photo?
You can... Create a new white layer. Move the original photo layer to the top. just use eraser, or a combination of select area + delete.
Mar 05, 2011 | Corel Paint Shop Pro Photo X2 Full Version...
I want to save the scan to the computer. What do I have to do?
HI, If you have Photo shop Elements, go to File then Import and look up you scanner from the list. If you are scanning from the scanner, it must see your computer to save to a file you created.
I use Photo shop, I've never scanned from the scanner onto the computer.
Take care...
Nov 15, 2010 | Lexmark X5150 All-In-One InkJet Printer
Photos don't show
Usually you are not limited in the number of folders you can create. You can have this problem if you are not createing folders to store the pictures in. Make sure ther are no pictures or other files outsde the folders in the root directory. If that does not help, that that drive to a camera store or coptuter shop that can do a data recovery. If there is a corruption in the USB directory then you may get problems like this as well. Reformatting the USB drive might help, but you will need to remove everything from it first. Chenck out http://www.spartanphotocenter.com/data-recovery-service.html
Sep 19, 2009 | Cameras
I have a 1999 Mitsubshi Galant that blowes white/purple smoke after it has idled. Lets say at a stop light, or for the morning crank up. I am also having to add oil in between oil changes. Is there any...
If you're sure it's "smoke", then it's probably burning oil. But most likley it's water vapor. When an engine is first started and the air is cold, the water vapor in the exhaust will create visible steam. Automotible exhaust primarily consists of carbon dioxide and water vapor. If the engine and exhaust system are cold, the exhaust will be cooler when it comes out and it can create a cloud of water vapor.
However, if it's not water vapor, as I mentioned above, it could be oil smoke. If that's the case you need an engine rebuild since you probably have bad rings.
Jul 24, 2009 | Mitsubishi Galant Cars & Trucks
A/C wont blow, makes noise and smokes when turned on
hi,maybe the bushing of blower motor is defect,creating noise,by touching the blade to the housing,or the carbon brass is also defect,ty
Apr 07, 2009 | 1993 Mercedes-Benz Mercedes Benz 300 Class
Adobe Photoshop CS2 for PC Logo
85 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
