Light flashes on power button
The power button flashes five times and then nine times what does that mean.
  • 8,617 Answers
I would need to know the model number of your set to even begin to answer your question.
Posted on Jun 15, 2008
How do I solve a problem with my Hp Probook, whenever I press the power button, the power light flashes nine times?
On that particular model you need to press the power button nine additional times waiting for the light to Blink 9 times each and then after the 9th time the procedure is as follows... Press the button 4 times hold for seconds on the fifth button push then release for 4 seconds then press the button twice and it should blink 8 times repeat this procedure continuously until the button only lights up once. After the button lights only once then you are ready to place the item into a garbage bag and throw it into the dump
Feb 08, 2018 | HP Computers & Internet
Light kee flashing orange/green and says computer is busy when there is nothing in print queue
FLASHING ORANGE LIGHT ERROR MESSAGES
Try counting the number of orange flashes.
* two flashes means you’re out of paper or the paper is not feeding correctly.
* three flashes means there is a paper Jam or the output tray is closed.
* four flashes means the ink tank is empty
* five flashes means the print head is not installed correctly or not installed or is defective (before buying a new print head always try the cleaning instructions at the end of this post first.)
* six flashes means the inner cover is open or not closed properly.
* seven flashes means you counted wrong.....
* eight flashes means the waste ink absorber is almost full or full.
* nine flashes mean that a digital camera or video that is connected is not compatible with the printer. If a specific amount of time lapses without getting a response from the digital camera or video camcorder this will happen.
* ten flashes means it can not print to both sides of the page
* eleven flashes means the automatic print head alignment failed. (this can be caused by low ink levels, ink tanks not being installed correctly, the print heads being clogged. It can also be caused by the paper output slot being exposed to a strong light source (Press the resume /cancel button and move the printer to a darker location and try to align the print head again.
* check to make sure the lock lever is correctly positioned (down)
If the above does not work, align the print head manually by opening the printer properties dialog box and clicking the maintenance tab and then select the print heal alignment button on the left side, second row down.
Mar 29, 2010 | Canon BubbleJet i320 Printer
The orange light keeps flashing
Mar 22, 2010 | Canon I990 InkJet Photo Printer
Panasonic TCP58S1 has no pic. or sound. Red light blinks 9 times.
It's dead. 9 Blinks means the display adaptor is dead. If it's still under warranty, you're covered.
Jan 22, 2010 | Panasonic Viera TC-P58S1 58 in. Plasma...
WON'T TURN ON
nine blinks means that there is a short inside the set you will have to find a tech to troubleshoot the set most probably is the G pcb
Aug 23, 2008 | Sony KP-46WT520 46" Rear Projection...
I have a 52" RCA tv that when i turn it on the green power light comes on for five seconds, shuts off for five seconds, it does this three times. And if you hold the power button down, it does it once...
you need a flyback. If your model has the ITC222 chassis you need flyback 259296 you can get one at the following link with free instructions on how to install it yourself.
http://servicemanuals.vstore.ca/
Aug 15, 2008 | Televison & Video
Power
When i try to turn it on the power button flashes a code. The power button lights up once for a second, then turns off, then flashes quickly nine times and lights up once again for a second before turning off. The screen doesnt turn on at all, nor do the speakers. Any help would be highly appreciated.
Feb 11, 2008 | RCA D61W130 61" Rear Projection Television
3 beeps mean what
If the only thing that happens is three rapid beeps when you select a feature from the console this is usually a symptom of a defective door switch.  The door switch must be closed to complete the circuit from the timer to the heating circuit and drive motor.  If the switch is bad, or the wiring is broken, the dryer will not run.
Oct 17, 2007 | Kenmore 62062 Electric Dryer
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
