Question about ASUS WL-130N Super Speed Wireless-N PCI Adapter (WL130N)
NEED BOOST FOR ASUS WL 130 NIC FOR SIGNAL FROM ASUS WL 500W ROUTER. SIGNAL HAS TO GO THRU BRICK WALLED HOME AND IN TO STEEL CLAD BUILDING. SIGNAL IS SO WEAK IT IS USELESS. TRYING TPO FIND AN ANTENNA TO BOOST WHICH ALSO CONNECTS TO ALL THREE FEMALE RPSMA'S. ANY IDEAS?
4 Suggested Answers
SOURCE: WL-138G connectivity issues
need vista x64 drivers
Posted on Mar 24, 2008
Krenn
  • 59 Answers
SOURCE: signal periodically disappears
do you know if reciever WL-167G is using any type of password or wireless security protocol?
Is it possible that the router is set to only allow certain mac addresses to connect?
can you log into the router to check its records and wireless settings?
Posted on Mar 29, 2008
  • 14 Answers
SOURCE: Connection problems with ASUS WL-167 G
Try going to "network and sharing centre" click "internet options" then click "connections tab" then "lan settings" check if it is set to "automatically detect settings". If this is clicked then maybe look through the guide or contact microsoft (if using windows that is!!)
Posted on Feb 02, 2010
Asus wl-500w and modem
your sub net mask is wrong you have to put 255.255.255.0 and make 192.168.1.1 to modem and 192.168.2.1 to router
Apr 11, 2009 | ASUS WL-500W Router (WL500W)
Wireless and router configuration hangups
- Kindly try to lack down the Link speed of the router and if theres any.
Mar 14, 2009 | ASUS WL-500W Router (WL500W)
Connecting 2 routers (ASUS WL-500W and D-Link DSL-G604T Wireless)
This will give you a "Double NAT" setup. Meaning, Your D-Link router is connected to the external internet address assigned to you by your internet service provider. More than likely this is a DHCP address you do not control. Your D-Link router is then translating the address to the 192.168.1.x network. This is the first NAT translation. You are then connecting the ASUS router to DLINK, causing a second NAT translation. (Internet ADSL --> D-Link WAN Port --> D-Link Lan Port --> ASUS WAN Port --> ASUS Lan Port to computer/server/etc. ) If both of your routers are giving out DHCP addresses, then this is all that is required.
Nov 22, 2008 | ASUS WL-500W Router (WL500W)
Problem open a series of ports ASUS WL-500W
Hello!
You should try to add a port range like this 7777:8000
Hope this helps!
Oct 01, 2008 | ASUS WL-500W Router (WL500W)
Problem with sitecom wl-130 connection
I think I have the solution: you have to click on the basic settings tab, then n "site survey" button, then (optional) on "refresh" button.
Now you will get the information about your network, and you just have to check the channel number of the signal from your main router. then you have to set that channel in the "channel" button of the basic settings tab. You also have to choose Universal repeater as working mode of the sitecom device, instead of Access Point.
Hope it helps.
By the way, all these settings should be automatic in such a device.... But this sitecom range extender is ****.
I suggest everybody is reading: DON,T BUY THIS ITEM!!!! Spend 10 bucks more and get a working one!!!
Jun 01, 2008 | Computers & Internet
Intermittent WiFi with ASUS WL-500W
I had the same problem. The problem is interferance from other devices. Solution, Change the channel from auto to a fixed one. That worked for me. No more droped connections, and a very strong signal now.
May 16, 2008 | ASUS WL-500W Router (WL500W)
Asus WL-500W USB printer - Can't add printer
Fixed it, remember to install the vista driver for your harddisk, then select the port of the ip to the wireless devide, then it should work, you can check in the wireless web setup that the printer is located, under System.
May 12, 2008 | ASUS WL-500W Router (WL500W)
ASUS WL-500W not connected to the internet
how your ADSL internet service provider, lock connection from any his machine ? Or your ISP dont provider for IP ADDRESS for DHCP or your ASUS dont set up get IP from DHCP.
Check this information.
Good Luck!
Mar 27, 2008 | ASUS WL-500W Router (WL500W)
ASUS WL-130N Super Speed Wireless-N PCI Adapter (WL130N) Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
