Question about Sony KP-51HW40 51" Rear Projection Television
6 blinking lights on my kp51hw40
What is code 4?
  • jdreilly1 Sep 17, 2008
    When I plug in the set, I hear a relay click, then click again.  The noise is the same one you normally hear when the set in turned on or off.  The display stays black.  The red light on the front blinks six times, pauses, then blinks six times again, .....on and on.  I think this is a trouble code, but I don't know what the code means.  Someone must have access to a service manual somewhere.  Please help.
  • Sony Master
  • 8,617 Answers
IC8003 is faulty on the A board is what a 4 blink error code is for the KP-51HW40 rear projection
Posted on Jun 17, 2008
Fix for 4 red blinking lights - standyby
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Jan 21, 2015 | Sony BRAVIA Televison & Video
2001 ford ranger 3.0. trouble codes p0174 and p0304. replaced coil,wires,plugs,.ran fine for a while light is back on again same codes.running down highway light blinks.come to a complete stop light goes...
The light blinks to let the driver know the problem is serious enough to damage the catalytic converter.
If you know for a fact cylinder 4 is getting a hot spark, it could be the fuel injector. Code 304 means there is no power from cylinder 4.
Jan 24, 2014 | Cars & Trucks
MY TV DOES NOT TURN ON AND I HAVE A BLINKING RED LIGHT MODEL IS KP51HW40
the blinking red light is an error code. How many times is it blinking and I will let you know what the error is indicating?
Aug 22, 2011 | Sony KP-51HW40 51" Rear Projection...
What is the code for LG 37LE4500 TO WORK WITH SKY REMOTE CONTROL
I also have an LG TV. I used this 4 digit code: 0742.
TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
Mar 12, 2011 | LG Televison & Video
Same as jasonvonk mar 15 2010 I get error code 37 after device and menu buttons pushed. red lite blinks 4 short pause and 4 short again Jim
37 is lamp or dmd failure. i don't find anything on 4 red blinks.44 error code which is 4 blinks, and then 4 blinks in disconnected DVI cable from light engine.
Mar 25, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
1998 ford expedition blinking overdrive light
This blinking light indicates a problem. You will have to have it scanned for trouble codes to find out
what it is.
Mar 29, 2009 | 1998 Ford Expedition
5 flashing light code
Disconnect RED Tube CRT board if set plays without shuting off RED tube is bad or video IC on CRT is bad.
Feb 12, 2009 | Sony KP-51HW40 51" Rear Projection...
2002 sony #kp51hw40 flashes red light and then shuts off
Count the flashes and the gap between the flashes as I know from experience the tv is giving you an error code in this way to say what is wrong. You should even be able to do this while the tv is in standby. Then once you have the code either consult your manual or try some of the sony forums to find out what the exact problem is. Hope this helps.
Sep 30, 2008 | Televison & Video
RED LIGHT
Does the light blink?
there is a
Sony Picture tube recall
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Feb 07, 2008 | Sony KP-46WT500 46" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
119 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
