Question about Whirlpool 30" Free Standing Electric Range WFE361LVD
Scharpf cooker - i need instructions - it has timer & i can't stop the clock from flashing or get the oven to turn on
    Genius:
  • 1,340 Answers
Here is a link to your manual.When you go to download it,all you have to do is enter the number code,you do not have to sign up with them.If you bookmark the site,it keeps whatever ones you have download in it's memory from your computer's IP address.Even though the D is missing,it should be correct.The D may just be a designator for store or country where it is sold.
Good luck,Greg
http://www.retrevo.com/support/Whirlpool-WFE361LV-Ranges-manual/id/23611ag100/t/2/
Posted on Nov 06, 2010
Can i by pass the clock or timer to be able to use the main oven they are worked by electricty
Cooker dead or oven not working or clock flashing - YouTube
? 3:05
https://www.youtube.com/watch?v=FDz4UpFMXq0
Dec 20, 2011 - Uploaded by Richard Saupe
Can be quite a problem when your cooker or oven is dead and always ... want to use it. watch this video on tips to re set theclock and get it up and ru. ... I try to set time I'm after a video clip on how to change the timer any help .
My Rangemaster 110 oven will not light, the timer/clock is ...
www.howtomendit.com > Kitchen Appliances, Gas Cookers
Free repair help - rangemaster 110 oven will not light timerclock broken too. ... I turned off mains electric then took out the 5 screws .... all I was interested in was bypassingthe timer and not fixing the timer -like others ..... Like I say, you will have no clockfunction but will be able to use the oven in the way it was meant to work.
Nov 24, 2015 | Kitchen Ranges
Replaced EOU43002X element, clock/timer now dead
Make sure there is power to the timer. Should be a fuse somewhere.
Mar 19, 2014 | Electrolux Ovens
SMEG OVEN BRAND NEW WON'T HEAT
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 08, 2012 | Smeg Ovens
The digital clock on my beko dv555 cooker isnt comin on and as my cooker was on timer now my main oven doesnt work either but my grill and hobs do
Try turning off the power for 3 minutes to try and reset the clock module. If this does not work it will need the clock replaced or a clock by pass done. A good electrician can do this.
Mar 09, 2011 | Ovens
My90 duel fuel range master cooker : The two fan ovens and the clock have stopped working but the grill and all hobs are fine !! any solution??
the ovens work through the clock auto contacts if the clock not working then the ovens wont. may need a new clock or you can bypass the timer relay contacts if your clever. one of the oven elements may have blown to earth this is the main reason for a clock failing
Aug 04, 2010 | Ovens
The bottom oven on my zanussi zuq 875 has stopped working. No power indications of any kind.Top oven works fine. Followed instructions in manual but no power at all.ie; indicator lights, fan ,oven light....
Have you checked that the timer clock is set and not flashing,because the rest of the cooker will work after power outage but for the main/fan oven to work the clock needs resetting.
Hope this helps.
Jun 13, 2010 | Zanussi Ovens
Clock on cooker flashing
Just to let you know that i have solved the problem with my cooker, (clock flashing after electric going off) i held down the cook period button and the end time button, then i was able to reset the clock by pressing the +button.
Apr 28, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Auto light wont fo off
good day,
hope this link below will solve your problem.
ovens
Aug 15, 2008 | Rangemaster 110 (Gas) Kitchen Range
Flavel Milano 100
Hi all...
Yep got the main oven gone......
Lucky iam good with electrics, got my brother in law to double check Qualified Elctrician it turns out that its the Thermal Fuse that has gone have ordered a new one at the cost of £8.......
This range is made by Beco thats why its hard to find info on the cooker.. The grill/fan oven has thermal fuse as well.....
Hope this helps MVE
Aug 11, 2008 | Kitchen Ranges
Rangemaster 110
Hope this helps with your dual fuel version 3 weeks on and working perfectly! Rangemaster 110. Ovens not lighting due to faulty auto/clock. FIXED! Our clock /timer kept flashing and would not reset
Someone, somewhere on the internet had the solution to my problem but I can't find the link again to thank them! If you don't mind losing the clock/timer auto function this is for you and it's free! Just takes a bit of time.
Basically you need to lift/open up the LH &RH hobs to get at the wires behind the clock. You should see 2 blue(neutral) wires coming directly from the back of the clock. Pull them out and connect together - should be easy to click them together. Then the ovens will light - but you will lose the auto/clock/timer functions. We only used the timer so not a big issue. We didn't take the control panel off but we did take ages to unscrew the hobs etc Probably took us about 2 hours going back to instruction manual we found on internet and trying to work it out but I think we've saved a lot in not replacing the unit with the usual call out charges. We made sure electrical supply was switched off and just took our time. Really chuffed!
Comment by tinling, posted on Nov 06, 2008 http://www.rangemaster.co.uk/Siteimages/Site_311/BigMedia/RM110Gas_04_06.pdf
This should allow you to see the instruction manual for the 110. There was another one somewhere showing a diagram of how to link the 2 blue wires at the back of the clock but I can't find it again! By the way our cooker is 10 years old so maybe different from newer models. We didn't have to take of the front control panel we accessed everything by lifting up the hobs to get behind the clock/timer.
Hope this helps! Ovens still working just got to go and buy a wee timer.
Apr 05, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Whirlpool 30" Free Standing Electric Range WFE361LVD Logo
123 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
