Question about Dishwashers
Dishwasher isn't drying probably coming up with error three. Can't locate a solution to this. Can anyone help?
  • 77 Answers
I would say a 3 fault is a heater element fault so you water is not getting hot atall. The heater is located in the base which you can gain access to from the front bottom of the appliance but be very careful the base plate is very sharp and will cut you, cover it with a towel for safety. The element is a little tricky to change but not impossible if you have some diy skills. Make sure you tighten the clamps that hold the element to the spray motor as it will leak and then give you an f2 fault. I think the elements are about £40 quid if you do it yourelf.
Hope this helps
Posted on Nov 06, 2010
Water not heating up and not drying
Hello
If your dishwasher is not heating properly, troubleshoot the issue. You can often repair this problem and eliminate service fees.
Incoming Water
Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat
The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan
The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Additional Concerns
If your dishwasher isn't drying your dishes properly, see if you have selected a heated drying cycle. An air drying cycle doesn't completely dry your dishes. Never overload the dishwasher, as this prevents heat from circulating around your dishes, keeping them from drying properly. Plastic and Teflon dishes don't usually completely dry. You must towel-dry these items.
Sep 12, 2011 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher not heating water already replaced in line heater element no change
Hello
Possible causes;
Incoming Water; Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat;The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan; The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Sep 07, 2011 | Westinghouse Dishwashers
My dishwasher clean light keeps flashing and wont run. it flashes 7 times and pauses then repeats. whats the issue?
This is an error code.
The error indicates that your dishwasher is failing to heat the water in an allotted time. The error can be caused by numerous issues but the first thing you want to do is reset the control board.
-To reset the control board press: high temp wash, heated dry, High temp wash, heated dry, high temp wash, heated dry, high temp wash, heated dry, high temp wash. If you don't have a "heated dry" button, use the "air dry" or "energy saver dry" button instead.
-All the lights will go solid at which point you press cancel to reset the board.
-If the control board doesn't reset, it's likely that you've just got a faulty control board and the control board will need to be ordered and replaced.
The next step in this process is to start a new cycle and see what happens. If the error code returns, then you'll want to reset the board again and check several things. The most common reasons for this error is because the water coming from your household is just too cold. The dishwasher is expecting 110 degree water to enter your dishwasher, so if your pipes are cold, the water may only come in luke warm. To correct this issue, just run your faucet next to the dishwasher until the water coming out is hot. On another note, make sure the dishwasher is washing with good water pressure. You can put a cup in the upper rack facing upwards and run a cycle to see if it will fill within 10 minutes of starting the cycle. If it doesn't fill with water then you know that the dishwasher isn't producing enough pressure which, in turn, will cause the water to not heat. You'd want to take your pump and motor assembly apart to clean inside if you had a loss of pressure.
You could also have a failed component including a faulty heater, control board, or high limit thermostat. You'd need to uninstall your dishwasher, disconnect power and lay it on it's back to check the resistance of the heater as well as the resistance of the high limit thermostat to confirm if they were bad or good. You should get tangible reading of between 5 and 30 ohms on the heater if it's good and less than one ohm on the high limit thermostat. If both of those devices check good, then replace the control board because that's the one device you cannot test.
Jul 05, 2011 | Maytag Dishwashers
Just got a new Bosch dishwasher (forget which model). After the dishwashing cycle has ended (even long after), the dishwasher and dishes are still wet. Was this an installation problem? Thanks
Hi -
I can't see how any installation problem would cause this - if the dishes are still wet at the end of the cycle, you'll probably find the water isn't heating during the wash cycle. The dishwasher uses steam to heat the washing compartment and dry the dishes. It would appear that the dishwasher isn't heating water internally.
Even if the washer was accidentally connected to the cold water supply ** (see note), this shouldn't happen as regardless of the water supply temperature, the washer should still heat the water to the correct temperature internally.
** UK dishwashers should be connected to the cold water supply. For US installations, dishwashers are commonly connected to the hot water supply. For other locations, please consult your installation instructions.
I suggest you start a regular wash cycle and leave it to run for 10-15 minutes. Then open the door and test the temperature of the water in the base of the washer by hand. The water should be hot and there should be steam present in the washer when you open the door.
If the water is cold or only warm, the water isn't being heated internally or isn't heating to the correct temperature, in which case you should contact the retailer or Bosch Service immediately for a replacement. Do not accept an offer of repair on a brand new washer!
Additionally, do not attempt to repair the dishwasher yourself when under warrantly as this will invalidate the warranty.
Hope this helps. If you need further assistance, please let me know your location and the model number of the washer. This should be laser-etched into the top of the door if you can't find it on any of your paperwork.
Regards, BElectric
Apr 27, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Dark Screen, Lense focus gone and error code: E61:00 - Help!
In this situation (salt water) best thing is rinsing the equipment immadiatelly with tap water and drying it throughly and quickly (with hair dryer etc.) But its been three days, so the internal circuitry and metallic mechanisms are most probably affected from salt water since its highly corrosive. Now, you can send it to your dealer/camera manufacturer for throughly check and repair. I believe nothing you can do right now. And its probably still damp inside, means still affecting by corrosive salt water if you did not already dry it throughly.
Jul 08, 2009 | Sony Cyber-shot DSC-T10 Digital Camera
Kenmore dishwasher will not start
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers.
The problem is usually attributed to water supply temperatures being too low when filling.
Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models).
There is a reset sequence that you can try to clear the fault.
Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times.
The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button.
This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher.
This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line).
The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits.
If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is.
The flashing light will be a series of flashes, followed by a pause.
If you indeed have a component problem, it will depend on the number of flashing lights in the sequence.
Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 27, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Ge dishwasher not drying
1 make sure heated dry is on.
2 run your cycle and when it says drying open the dishwasher. see if it has steam coming out.
3 give me your whole model number.
4. if heater is not turning on then you may have one of three issues.
1. Bad door switch
2. Wire off element or bad thermistat
3. No power going through the control. to the heating circuit.
Jan 07, 2009 | GE ADW1100N Built-in Dishwasher
Whirlpool dishwasher # quiet partner II
Pushing and holding the 'Heated Dry' button should turn off the light over the padlock symbol and get you going again.
Jan 17, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
665.17019401 - Kenmore diswasher
It indicates a water temp problem. If water temp doesn't rise at a certain rate, by the heater, it goes into this error. Probably a problem with heater or wires to it.
Nov 22, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
Idesit dishwasher
it sounds like the element isnt working properly.locate the element connections by removing the lower kick panel and turn the unit on to the drying cycle.use a volt meter and check the voltage.if you have voltage there than turn the circuit breaker off remove the wires to the element and check with the meter for continuity,let me know.
Nov 10, 2007 | Indesit 24 in. D63 Free-standing...
Dishwashers Logo
Top Dishwashers Experts
Oloyede Monsuru
Marvin
Marvin
