Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
I have an older model bosch HE front load washer; where is the and how do I clean the filter? I have an E04 code . thanks
  • 2 more comments
  • cathleen_kre Nov 06, 2010
    thanks; however my machine doesn't have the small round door at the 5-o'clock position. can't find my owners manual; can't locate on on-line manual.
    appreciate your reply.
    Thanks again. I really appreciate the continued (apparent 24 hour) assistence. I'll locate model number and forward to you.
    Many thanks again.
  • cathleen_kre Nov 08, 2010
    my extreme bad. you were correct. I think I should a) put on my glasses so I can see better; 2). quit working night shifts so I can think better.
    Many thanks for your attention, courtesy and time.
    absoutely spot on information. guru was courteous, unfailing in his provision of assistance &, I suspect, just as cute as a bug.
    will use this site in the future for my repair needs.
    thanks very much.
  • 8,197 Answers
May I get the make and model # to help you more. If this is your washer you can get the manual on the link below.
http://www.bshextranet.com/files/techtoolbox/WFMC6400uc.pdf
Good Luck
Posted on Nov 07, 2010
    President:
  • 1,554 Answers
Disconnect power then put the end of the drain hose into a bucket or shallow basin to manually drain the water by gravity. Position the bucket or basin as low as possible to extract as much water. There is a round door on the bottom front of the washer and at the 5-o'clock position, there is a small hole. Insert a pointed tool into the hole then push in to release the latch and rotate the cover clockwise to the 6-o'clock position and the door will pop out. Place a piece of towel under the door to catch residual water when you remove the filter. Take extra care to get cut by the edges of the opening then turn the filter knob counterclockwise to remove it.
Posted on Nov 06, 2010
  • Jahn27
    Jahn27 Nov 06, 2010
    I can probably help you find the manual if you indicate the exact model number of the machine.
What is error code e04 bosch front loader washer
The "E04" error code on your Bosch washer refers to a drainage problem as you may or may not already know. ( it can mean door lock error, but that is usually a by-product of it not draining )
What you may have is either a partially clogged pump, or a faulty pump...the later being the least likely
Nov 22, 2016 | Bosch Washing Machines
What does fault code e04 mean
There are many brands of washers and the error codes are different.
What kind of washer do you have. Brand name and model number.
Open door and look around the frame for the model number.
Here is a link to e04 on a Bosch washer.
Repairing 04 Error on Bosch Washer
Sep 10, 2014 | Washing Machines
E04 error code, washer wont drain, water left in tub on a Bosch Nexxt 300 series
http://applianceguru.com/attachment.php?id=2463
Make sure you click helped, if helped that is.
Apr 12, 2013 | Bosch Washing Machines
We are getting error message E04 on our Bosch front loading machine and it won't drain and it makes a grinding sound.
We removed the round panel in the front and there was a knee hi stocking stuck in the filter - great advice - it's fixed and working perfectly.
Jan 03, 2010 | Bosch WFMC 2100 Front Load Washer
I have a bosch WFR 2460 washer. Er:15 error code.
You need to check and clean pump filter, normally located behind a removeable plastic cover at bottom front of washer right hand side.
If no filter found there remove rear panel of washer, and clean pump from rear of washer.
Please rate my solution.
Thanks.
Nov 11, 2009 | Bosch Logixx WFT 2806 Front Load...
Frigidaire Dryer Error E 04
I have the same problem. Does anyone have an answer?
Jul 26, 2009 | Frigidaire Affinity ATF7000E Front Load...
I have a bosch wfmc 2100 washer that doesn't drain
Have a look on the Bosch web site, they offer solutions to some problems, if not contact them via email
Jan 01, 2008 | Bosch WFMC 2100 Front Load Washer
Water not entirerly draining, e04 code continues on...
you did not say what make ,but anyway,there is probably a obsuction in the bottom hose on drum, ie sock, underware remove it and see.. close ire
Nov 27, 2007 | Bosch WFMC 3200 Front Load Washer
E04 not draining
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Nov 20, 2007 | Bosch Exxcel WFO 2264 Front Load Washer
E04
Perhaps try opening the round panel on the front of the machine at the bottom and cleaning that hose...good luck because it might be messy.
Nov 19, 2006 | Bosch WFMC 2100 Front Load Washer
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
149 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
