Question about Panasonic PT-AE900U Multimedia Projector
Aloha, I'm trying to connect a macbook pro to a PT AE900 projector using a DVI to HDMI cable. the projector will NOT display the movie when i play it on the computer. it will NOT display the desktop of the computer. but it DOES display some of the system preference windows (which is bizarre), so i know that a signal is getting from the computer to the projector. i set the projector to HDMI mode. can't think of what else to try. can anyone help?
4 Suggested Answers
  • 17 Answers
SOURCE: Panasonic PT-AE900U displays black and white only
sounds like bad cables, or wrong setting on projector you may have it set to compoent instead of composite,, you don't tell how you are hooking it up. (what type of cables you are using)
Posted on Jul 17, 2008
SOURCE: panasonic pt ae900 wont fire up
First , start over and unplug it. Wait a few minutes. Turn on AV system that is connected to it but not video or dvd player. With remote, point at is corectly and push power 1 sec or as soon as you see green light come on. Be quick.
If this fails you can wait 4 hours and repeat. OR try only projector with out any feed.
Let me know if this worked.
Posted on Dec 27, 2008
SOURCE: Panasonic PT-AE2000U All three HDMI Ports stoped
WOW. I just experienced the same thing. None of my HDMI ports are working, though component is fine. I've had my unit since November 2007 and had no problems until this. I think the HDMI board has gone bad and will require replacing.
Posted on Jun 21, 2010
What might be the problem since my macbook pro is connected to the projector through a HDMI to VGA adapter, yet the screen remains black?
Vga and hdmi are different formats. Unless you are using a coverter box that translates the data from one format to another it won't work. Vga is analog and hdmi is digital
Oct 08, 2016 | Sharp Office Equipment & Supplies
Recognize macbook connect
You may need to check the settings of your mac book that permits you to output the signal to an external display. Also you may need to purchase a display port adapter (VGA, HDMI or DVI) that is compatible with the input connector on the projector
Dec 18, 2013 | Dell 2300MP Multimedia Projector
How can I hook up MacBook Pro with Optoma 1690 Projector? Am I supposed to hit a certain function key to get Projector to see MacBook
You may need a certain connection (MiniDisplay Port to DVI, or MiniDisplay Port to VGA). If you're connecting to an HDMI-compatible projector, you'll need an adapter. You'll also need an adapter if connecting your MDP (MiniDisplay Port) to a DVI or VGA port. Here are some helpful links:
#1 MDP Adapter Video (YouTube)
#2 MDP to HDMI Adapter (RadioShack)
#3 MDP to VGA Adapter (Apple Store)
#4 MDP to DVI Adapter (Apple Store)
http://www.radioshack.com/product/index.jsp?productId=3898890&CAWELAID=447271885
http://store.apple.com/us/product/MB572Z/A
http://store.apple.com/us/product/MB570Z/A
Mar 12, 2010 | Apple MacBook Pro Notebook
Macbook Pro wont connect to Vizio tv
disconnect hdmi cable and shutdown pc, completely power it off. plug your hdmi cable back in to your pc and power it up. it should properly detect your tv. i use projector mode. tv must stay on while performing this procedure.
Feb 11, 2010 | Apple MacBook Pro Laptop Computer with...
I have connected my macbook to my tv using mini
Later MacBook (Pro) use a mini-DVI connector that does not pass analog needed for composite or S-video. Was yours ever working? And most DVI connectors do not pass sound as seen by your cabling. You cannot detect display through RCA. You just set it in Sys Prefs :: Displays, try some other settings, although your seem right.
I have a white early-2009 MacBook and mini-DVI to HDMI adapter (monoprice <$10) and HDMI cable and have not connected the TOS-link for sound, yet--just slideshows at 1920x1080. You will get a much better picture digitally. -Ken
Jul 13, 2009 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Macbook recognizes dell projector, but not vice versa
Your Macbook should automaticaly find the best resolution, if everything was OK. Is there any HDMI input on the dell projector? What projector is it? Is there is an HDMI input, you can use a HDMI to mini DVI cable: better picture and sound than VGA, and will probably solve your problem
Jun 26, 2009 | Apple MacBook Pro Notebook
I have a MacBook Pro and a XR-30s sharp projector. When using the DVI port on the Mac to DVI-D on the projector the picture turn grainie. WHY? However, when I disconnect the cable, the pix clears up on the...
It is probably mirroring the screens on your MacBook and the projector. If you want different resolutions and things on each screen, go to the Apple menu, System Preferences, Displays, Arrangement and uncheck the "Mirror Displays" checkbox.
Apr 22, 2009 | Sharp XR-30S Projector
Macbook pro + IBM m4000
Depends on the connections you have on both. Most MacBook Pros have a DVI connector on the side. If the IBM projector takes that sort of input, then all you need is that cable.
If the IBM projector has a VGA input, then you'll need an adaptor from DVI to VGA.
(VGA input is standard monitor looking connector.)
Jul 26, 2008 | Apple MacBook Pro Notebook
Can't use my hp sb21 with my Macbook
it works if you do it in bootcamp. but have to select external monitor instead of digital display under the intel graphics control panel. does anyone know of such an option under OSX?
Jun 13, 2008 | HP Digital Projector sb21 Multimedia...
Apple Macbook pro video out to VGA port ("d-sub") on Optoma
There's no solution. it will not connect with macbook pro or any other mac. as on the phone with all technicians and they do not know what to do. I had the unit replaced and still would not connect.
Mar 19, 2008 | Optoma MovieTime DV10 Multimedia Projector
Panasonic PT-AE900U Multimedia Projector Logo
64 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
