Question about Panasonic Lumix DMC-ZS3 Digital Camera
What are the different options in the mode dial?
    Genius:
  • 1,177 Answers
For complete information on this and other aspects of your camera, you can download an intruction manual from this page.
Posted on Nov 06, 2010
My sony DSC-H200 mode dial does work as it should if I turn it to 'M' or any other mode the led screen show a different mode, if I press down on the mode dial it correct itself.
M is for Manual Mode which allows to shoot manually adjusting the exposure settings. It gives you host of another option and as well as activates other options.
https://docs.sony.com/release/DSC-H200_guide_EN.pdf
As you mentioned that when you press down the mode dial it corrects itself, actually it goes back Intelligent mode. For in depth detail i am attaching a link of a pdf manual you will get all the info about modes.
Dec 04, 2016 | Sony Cameras
Flash on camera is not working
Hello. If you're shooting in Auto mode and you have turned off the flash, your camera will remember that setting and the flash will not fire. If you switch the dial on top of your camera to another mode and then back to auto it should clear the setting and the flash should now fire, if needed. The other thing to try is to hold down the the flash popup/mode button while, at the same time, turning the rear control dial. You can watch your top display and the flash modes should cycle through different options.
Dec 25, 2013 | Nikon D7000 Digital Camera
KX-T7431 try to dial out and dispaly says CO Not assigned, I cannot answer calls either!!!! Hellllppppp
What has happened is that the CO1 CO2 etc buttons have not been programmed to dial the access code for an outside line. You can do this manually by dialling 9 then the number you wish to call. You need to enter the programing mode from the default extension usually EXTN 20 or 21. You need to go into the options and assign the digit 9 and a pause (P). The system will allow you to set different options such as if someone is on CO1 and another user dials 9 from another extension, the system will then assign the next free exchange line, again this must be programmed via the default extension. Let me know if you need further help.
Sep 04, 2013 | Panasonic KX-T7730 Corded Phone
What's the options for the settings of the thermostst and how do you do it ?
Most recirculation pumps can operate in 2 different modes.
Timed mode where you schedule times of day on face of analog timer that rotates like a clock, or thermostat mode where the pump runs when water inside pipe drops below 90 degrees.
The selector switch lets you choose which mode.
http://waterheatertimer.org/Water-heater-recirculation-system.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 26, 2012 | Grundfos UP10-16B5/ATLC Comfort Series...
Broken mode dial?
Make sure that the SETUP option is nearest to the black mark on the camera, if you are still not shown the options menu, you should probably call Nikon USA to get the camera serviced if still under warranty.
Jul 16, 2010 | Nikon COOLPIX P3 Digital Camera
I am in the "s" mode for shutter speed priority and i cant change the shutter speed i use the scroll to get the arrow above the shutter speed on the view finder and from then i cant figure out how to...
Are you pressing the jog dial to save the setting? Here's what your book says:
  1. Turn the Mode dial to P, A, S, M, or C.
    The mode options are displayed.
  2. Use the jog dial:
    • Press the jog dial to open a setting.
    • Press the jog dial to save the setting.
    NOTE: Available options are white. Unavailable options are grey. Red options are out of range and may cause unacceptable image/print quality. Adjust the value higher or lower until it turns yellow.
Jun 11, 2010 | Kodak EasyShare DX7630 Digital Camera
Pvc selection keeps changing to dial up mode
  • delete the dial up connection on the internet option
  • click tools-internet options on the internet explorer - click connections tab, delete all dial up on the box, and select never dial a connection
Aug 04, 2009 | Siemens SpeedStream 2624 Router...
I want to put color bar in pd 170
dear when u will open menu .. at last where we check ..HR. METER ,if u remmber ...
der is the option for the colour bar
Jan 25, 2009 | Sony Dvcam DSR-PD170 DV Digital Camcorder
How can I set tone/ pulse so I can dial out
Press menu and use the arrow down to goto Global setup and press select. Use the down arrow and goto Dial Mode and press select. Use the down arrow to select your dial mode and press select
Jun 01, 2008 | Uniden 5.8GHz Dual Cordless Phone
Panasonic Lumix DMC-ZS3 Digital Camera Logo
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
