Question about EliteGroup Computers & Internet
Asking about components in ECS 848P-A v 1.0
Did anyone know the part code and may be the function for :
-a mosfet with a 2 legs near the cmos batery and SouthBridge, and side by side with ELCO?
-a part with 5 legs, position is up (my english is bad) from the AGP slot and left side of the NorthBridge Chip?
-6 mosfet on the left side of the CPU socket?
I will appreciate your help...although if you are new for this thing..
my mobo has become a canibal victim to revive others' mobo, but someone forgot to write notes about the original part that taken from the place.
one more thing..
how is the sequence of a booting process?
Swich on> activate logic ic>logic ok>give power to cpu>cpu send power ok to ???>cpu try to find BIOS in the end of the memory address (where?)>linked by memory to the real bios is>execute bios>bios execute POST>test device..cpu..ram..vga..fdd..hdd...>boot ?
is that right or wrong and complete or incomplete in details???
i want to learn more...
  • udinho Jun 18, 2008
    thanks, bro
  • 3 Answers
Cant you find image at ecs website of motherboard ??
enlarge image for possible ID of part ??
--Try doing a "DOGPILE" search with just the numbers found on the chips you inquire about ..i learned alot just from searching parts and even FCC #'s when i first started .. all via dogpile ! exellent results everytime ! ..
you have knowledge of what the board is and made by who --- so you are in good shape there -
May i suggest getting or at least browsing thru at local retailer or library or online or friend ? ..
this book -- which i cant seem to find at the moment .. arg
but called something like
-- Ultimate guide to PC REPAIR
Edition # 16 now i think .. Scott Muller .. new book every September indicated by edition # -
-- average $60 new/current edition $45 new/previous editions
used $0 unknown ... try powells --
-- $=USA
Posted on Jun 18, 2008
Ms-7108v1
1 long beep dram refresh failed
remove everything
JUST INSTALL MIN. RAM, CPU, CPU FAN, POWER CONNECTION, THAN TURN MACHINE ON, IF OK, CONTINUE INSTALLING I DEVICE AT A TIME UNIT YOU IN COUNTER AN ERROR THAN YOU WILL KNOW WHAT IS WRONG.
now a few things to check video card, ram, cpu fan plugged in right area,
you mite want to reset the cmos, by jumping the connectors for few seconds, then turn machine off, remove jumper, than just install cpu and fan, ram, speaker, keyboard, turn on if ok add video card, turn on , if ok, than install hhd, 1 at a time, than restart system if boots ok than move to next device, keep doing this until you installed everything you want or have to have in the system
Jun 07, 2014 | MSI 848p-neo2-v-848p Neo2-v Intel 848p...
Ecs 848p-a v1.0
The manufacturer's support page for this motherboard can be found at the following link
http://www.ecs.com.tw/website2008/Product/Product_Detail.aspx?CategoryID=1&DetailID=361&DetailName=Feature&MenuID=24&LanID=0
Perhaps the answer to the question you have not asked is found there.
May 21, 2014 | EliteGroup Computers & Internet
I bough memory for my 848P-A V2.0 - ECS Elitegroup mother board. when i install the memory i get a few long beeps. i bought 2 .. 1 gb pc3200/400 mhz ddr is this the wrong size for this mother board?
Hi
Thank you for your query
The memory is correct please can you try putting in only memory stick at a time and see if this problem occurs, it could be that one of the sticks could be faulty
Regards
Shauqat
Sep 25, 2010 | EliteGroup 848P-A V2.0 Motherboard
HOW CLEAR INTEL D915 GAV BIOS PASSWORD
Intel mother board is very populer brand.I like it very much.If itself, It has three leg jumper near the cmos battery.1-2 short defaultor normal.2-3 short clear cmos.you like 2-3 short then fix your bios password.you must be power switch on.Un plug power cable.again jumper short 1-2 normal position. your bios clear.
Feb 08, 2010 | Intel D915GAG Socket 775 Motherboard -...
HI I have a FSP200-61GT SPI switching power supply with a burned out Mosfet on the high voltage side. There is a (I think)a .5 or 1 watt resistor on both sides of the mosfet. But they test good, my problem...
I think it's usually about 820 - 1K Ohms... It;s the emitter resistor.In saying that we generally don't repair these SMPSU's anymore as they are so inexpensive these days like NZ$45.00 for a 350 Watter. Also 80% of the time the repaired supplies fail again shortly after due to the stress put on the other components, by the initial problem.Good luck.
Jan 27, 2010 | Computers & Internet
ECS Motherboard P4M800 LGA 775 Socket
One of these should work:
1. Reset the BIOS (remove mobo battery or short-out the two reset pins near the battery or CMOS chip)
2. Disconnect every drive from power and data; remove all add-on cards. Leave only video card and one memory module in place. Turn on.
I hope #1 worked for you.
In #2, a device may be internally shorted to ground, that's why you must disconnect the power AND data cables from them.
Sep 24, 2009 | EliteGroup ECS P4M800-M Socket...
Blown channel
Its possible to repair, but you have to crack the amp open and prod around a bit. I found that the failure is usually in the power components or the MOSFET drivers. If you have 1 channel out, I would focus on the MOSFETS (if you dont know what they look like just Google MOSFET - they are the black 3-legged chips and are usually mounted to aluminum to disperse the heat). Some things to look for:
- burnt / melted solder traces (where the MOSFETS connect to the main board)
- disconnected leads (same place as above).
If you find any connection that looks suspicious, it wont hurt to re-melt the solder around the joint to make sure its a good connection.
Hope that helps...
May 08, 2009 | Car Audio & Video
T1500-1bd burnt mosfet
First of all is the mosfet your talking about in the output section or in the power supply section? Most car amps use mosfets in the power supply section, some use them in the output section. To test the transistors in your amp, take a digital volt meter and set it to diode check. Then take the leads and put them accross the first and third legs of the transistors. Usally the red test lead on the first leg and black test lead on the third leg of transistor. If you get a reading of 000 then transistor is shorted. If you get a reading below 600 then transistor is on it's way out if not allready or it's next to a shorted transistor that is it's complimentry output transistor. comonly you will have 2 transistors working together, one NPN and one PNP per a channel, or 4 of them in a bridged type output circuit depending on the watts and how man channels your amp has. I was just looking at the specs of this amp and it's got me confused. It says it's a 2 channel but looking at all the info on different pages it says at 4ohm:200wattsx4 and at 2ohms:300wattsx4 and 1 channel mono 600watts into 4ohms. weird for a 2 channel. anyway that is how you test your transistors. Same way for the power supply section but, you will come accross a couple or more switching diodes that look like transistors and you will get a 000 reading when you test those like I specified. They rarely go out and most of the time there is only 2 of them. They will have a diagram like a diode on the front showing you which way the power flows. Let me know what you find out. Your amp should have went to protect mode if you smoked a mosfet.
Feb 08, 2009 | Audiofonics ADF-243 Car Audio Amplifier
848P-A mother Board P4FSB 800 INTEL CPU PENTIUM 4 PROCESSOR
If by "Reboot" you mean turn-off and restart, your CMOS battery is probably bad and not able to supply enough power to the bios to retain your time settings. Replace the CMOS battery.
Many web sites require the proper date and time on the surfer's PC. For example, Microsoft Update will not allow downloads if the surfer's PC date and time are far out of syncwith the real time. Ironically, even the Update Time function on the surfer's PC will not work if it is too far out of sync.
Oct 31, 2008 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Computers & Internet Logo
190 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
