Question about Kodak EasyShare C653 Digital Camera
I plug in the usb, both ends. I hear the signal but the screen to download never shows up on my monitor
  • 34 Answers
I got a new pentax...it did the same thing...we get used to our old camera's...this one you have to turn the camera on...or load that cd that came with it
Posted on Nov 06, 2010
Asus led monitor model vh197 shows no signal on screen and no display ,screen became dark
Good Day Dasarathi!
Please check the VGA cable if its properly connected and make sure two screws are fixed to both end connecting the monitor and the video card.
No signal comes out when there is no signal from the video card to the monitor. That is why you need to check if the VGA cable is fix to both end.
If that did not fix it, you will need to open the casing of your computer. Disconnect the video card from the motherboard. Gently clean by wiping a clean clothe over the contact surface of the video card. Then, reseat the video card properly to the slot in the motherboard. Return the casing cover and connect the VGA cable again.
Just remember doing the above procedure is only when the computer is turn off.
Turn on your PC and see if that fix it.
You will need to replace the video card if by booting the PC you will hear a series of beep codes. If no beeps then you are lucky VGA cable is the faulty one.
Jun 09, 2011 | ASUS Computers & Internet
VX922 only shows "No Signal" on black screen
The monitor shows no signal probably it didnt detect the tower
Ill be advising you to remoev the cable that conencts the cable
used a clean cot or rug clean both ends of the cable , clean also the area whre you plug in the cable , the ports on the monitor and on the CPU make sure its clean .
Then plugged it in , in case nothing happens
try to used another cable that conenct from the monitor to the CPU
you may aslo try to used other CPU to checked if monitor is working fine or try other monitor to checked if the port on the your CPU is working fine
May 23, 2011 | ViewSonic VX922 19" Monitor Flat Panel
Normally, when the monitor is switched on, a blue screen is shown momentarily, with 'acer' right in the middle, before it shows the image that the computer is sending. But now, the screen does not show...
It sounds like either a bad signal input , possibly from a loose plug on the cable from the PC or bent pins on the plug / the video graphics card in the PC/ or the settings on the monitor need adjustment. Use the OSD (On Screen Display)
First check to make sure both ends of the cable from the PC to the monitor are not damaged and are seated good & tight.
If those are fine then unplug both cables from the monitor & leave unplugged for 10 minutes or so to see if the screen has an automatic reset.
If that does not work then use the monitors OSD (On Screen Display) to adjust to default settings. If that does not work, plug the monitor into another known good PC.This will tell you right then if its the monitor or "Your" PC.
__________________________________________________________
Here is your manual if needed
http://www.retrevo.com/support/Acer-AL1717-Monitors-manual/id/719ag107/t/2/
Oct 09, 2010 | Acer AL1717 17" LCD Monitor
Can't hear music on my monitor
There should be a lead plugged from the computer speakers output to the monitor input, usually a 3.5mm stereo plug at each end. Make sure this is actually plugged in at both ends (sockets and plugs are usually Green for speakers).
There is a volume control in the computer, which you may already know about. This is accessed by double-clicking the speaker icon in the system tray (lower right corner of the screen).
The monitor will also have a volume control, accessed via the On-Screen Display (OSD) menu system, using the buttons on the monitor.
Check all those things and see how you go.
Apr 16, 2010 | Acer AL1916W 19" LCD Monitor
My computer is not working shows keyboard erro and stop
Hi...
When you monitor saying which is no signal this is a monitor port problem. Check your monitor connector if it is properly connceted to the motherboard. That is the only way of monitor saying no signal.
Regards
PCmania
Aug 22, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Screen shows message "no input signal" and monitor goes to sleep.
monitor show "no input singnal" error masage when not gating any type of video singnal ,
so if u realy check your monitor wires for correctty plugged in .
then:-
Two possibilities:
either the video/mainboard of the monitor is defective; or
the video card/ CPU is the faulty.
A way to verify is to try the PC with another monitor or to try the monitor in another PC.
thanks
Apr 30, 2009 | HP vp17 Monitor
I cant get my acer aspire one to connect
your describe: connect a laptop VGA out to a monitor but no signal: you need check
1) newer monitor have two signal interface (analog or digital) and you may try to do a logical change the signal way by select buton
2) any laptop have two way display (local LCD or extenal VGA) change by the key (fn+f key showing creen icon)
Nov 08, 2008 | Dell E207WFP LCD Monitor
Monitor stuck in sleep mode
It will do this when it's not getting a video signal from the computer. Make sure that the signal cable is firmly plugged in at both ends. Also verify that the computer is actually starting up. The monitor may not be getting a signal because the computer isn't sending any.
Sep 25, 2008 | Compaq TFT5015 15" LCD Monitor
HI no startup beep on my emachine and no signal onscreen
Get a new Hard Drive and plug it into your USB Port
Jul 05, 2008 | E-Machines eMachines Desktop PC
Monitor shows no signal
ur monitor is "not" the problem... you have problem in ur PC..
solutions:
check loose graphic card
remove ram. put them back again/...
Feb 11, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Kodak EasyShare C653 Digital Camera Logo
16 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
