Question about IBM Netvista Intel Pentium 4 2.4GHz / 512MB DDR / 40GB HDD / DVD-ROM / 10/100Mbps LAN / Windows XP P (RBP42400XPP) PC Desktop
Fan in control unit running continously - IBM Netvista Intel Pentium 4 2.4GHz / 512MB DDR / 40GB HDD / DVD-ROM / 10/100Mbps LAN / Windows XP P (RBP42400XPP) PC Desktop
  • 734 Answers
When a fan runs continuously, it suggests a narrow and definable range of possible issues.
1. Dust "Bunnies" have inhabited the blades of the fan directly where they spin, and/or have clogged the cooling blades at the end of the heatsink arm bars made of high heat conductive copper, and the heat can't get out.
2. The temperature control chip on the main board (motherboand) has failed (or is close to doing so) and is sending the wrong information to the fan, causing it to run when it doesn't need to.
3. You have not recently visited the site for drivers and downloads for your computer to check if a new BIOS release is available to reconfigure the fan settings.
4. You are asking entirely too much of the processor for operations when you should have upgraded what I consider to be an under-supplied sufficiency of RAM for your unit.
It is my hope you'll consult briefly with a knowledgable local friend to discuss these issues and rememdy them in the exact order I've stated them.
To end on a less formal note....get an air compressor and blow the crud out of your machine and get some RAM.
LOLOLOLOL
Kindest Regards,
Selk
Posted on Nov 06, 2010
I have the fan set at auto..yet it ( the fan ) runs all the the time..everything else runs fine. What can I do
w/o knowing model of unit ??? If your unit has a mechanical fan limit switch either it is stuck in on position, or the manual button on it if so equipped is set for manual operation so it will run continously
Nov 04, 2013 | Dayton Gas Furnace Heater
My Rudd air conditioner fan is running continuously.
Hello, if the outdoor unit is running continously then the contactor coil is stuck and msut be replaced. If the indoor fan is running then most likey the relay on the control board is stuck and the whole board will need to be replaced.
Jun 16, 2011 | Heating & Cooling
The units fan runs continously even when the switch at the thermostat is set to off
These units with the old dial switch had problems with the control boards. There is a
digital replacement kit that runs between 140 and 180 dollars and works well with
good installation instructions. It requires pulling out unit to install the sensors, board and transformer, but a good time to vacuum out the pan area as well. About 1 hour
installation time.
May 09, 2011 | Amana PTC093B35AM Air Conditioner
I want to program the fan to run continously
I don't see this as a 'programable' feature.
The unit is designed for the fan to run anytime the compressor runs and if you just want the fan to run all the time (without the compressor) just switch it to the 'fan/fan only' position.
May 12, 2010 | Amana PTC093B35AE Air Conditioner
Radiator fan cycles continously. Fan radomely comes on and off frequently and has consistently gotten worse. Because of intermittent problem, Mazda was unable to diagnose problem. Any advice would be...
First, intermittent problems are the worst! I would look for a bad or loose connection. Does the fan ever run consistently? If you turn on A/C most cars will run fans continuously, if yours works ok on this setting then problem is isolated to temp control (fans ok, wiring ok, relay ok) The temp switch would be probably be faulty (or connections). If your fans cycle even on A/C setting then you are looking at a complete electrical inspection. Switches, wiring, fuses, connections, relays, fans...everything! Hope this helps and good luck!
Mar 17, 2010 | 2006 Mazda MPV
Why does my fan runs continus. and the condenser won't run out side.
The fan runs continously because your condensor is not kicking on and removing the heat. The thermostat needs to come under the set temp. to kick off the fan. If your compressor doesn't run and the fan on the outside unit does run, your compressor has an issue. If nothing runs outside, then your transformer on the inside unit(air handler) has an issue. This could also be a control relay on the condenser or the air handler.
Jan 15, 2010 | Omega Trane Furnace Draft Inducer Blower...
Fan runs continously, feels like heat. Turn off at meter box.
Is the fan on the outside unit running continuously, or the fan on the inside unit? Please explain the problem in more detail.
Sep 18, 2009 | Intertherm P3RA-048K Air Conditioner
Fan won't stop on Maytag M1010
Some thermostats have a fan switch that turns the fan on to run continously. Check to make sure the fan switch is not turned on.
If thermostat is not the problem, then somebody will have to troubleshoot the control wiring to find the reason for the fan issue
May 02, 2009 | Heating & Cooling
IBM Netvista Intel Pentium 4 2.4GHz / 512MB DDR / 40GB HDD / DVD-ROM / 10/100Mbps LAN / Windows XP P (RBP42400XPP) PC Desktop Logo
32 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
