Question about Dryers
Hi, I have a Whirlpool thin twin LTE6234DQ and it is stopping at Rinse position. What is the possible solution. Please help.
  • 43 Answers
SOURCE: whirlpool dryer
First make sure you have power to the unit through the plug. If power is present, then you most likely have an open Thermal Safety Fuse. The Thermal is a Safety feature that shuts off the power to the Heat Element in the event the Blower is not blowing or the Lint Vent becomes clogged not allowing air to flow over the Heat Element. NO air flow, Heat Element over heats, Thermal Safety Fuse opens, power shuts off. If the Thermal Safety Fuse is open find out why. Was the blower not working? Was the Lint Filter clogged? ( Lint Filter should be cleaned after each use to assure continued air flow.) Was Lint Vent Clogged? This is the Vent Hose that goes from the Dryer to the outside of your house. It should be checked for free air movement. The next thing-- Could be a defective Timer or Control Module.
Find where you lost power and WHY!!
Posted on Jan 27, 2008
  • 10 Answers
SOURCE: Whirlpool Thin Twin
Before you run in there with a hammer, is there any way to simply turn off the buzzer alert? I have a different dryer, but I can disable the buzzer. Please check the operator's manual first. If you've gotten to the point of no return, you can disable the buzzer - carefully. Never leave any exposed wires dangling about.
Posted on Mar 16, 2008
  • 1122 Answers
SOURCE: Whirlpool Thin Twin YLTE6234DQ2
YOU CAN DO THIS.,POP THE FRONT PANEL OFF,GO TO THE SWITCH PLUG JACK ON RIGHT SIDE UNPLUG JACK,ON THE SWITCH SIDE WIRES CUT THE OUTSIDE WIRES PUT THEM TOGETHER WITH WIRE NUT,LEAVE GREEN WIRE ANONE,PLUG BACK INTO JACK,YOUR DONE,REMEMBER NOW IN THE SPIN CYCLE IT WILL WORK BUT WHEN YOU OPEN THE LIP IT WILL NOT TURN OFF SO KEEP YOUR HANDS OUT OF THERE,THANKS-MIKE
Posted on May 28, 2008
jsrock516
  • 5911 Answers
SOURCE: washer
The symptoms you describe are typical of a broken lid switch. The lid switch is located under the washer top on the right hand side. It is activated through a slot by a small plastic piece on the lid called a "lid strike". Make sure the lid strike is still installed and not broken. Make sure the lid switch itself is not loose, as well. There are two mounting screws along the washer tub opening that hold it in place. If the screws become loose the switch will not make contact with the lid strike when the lid is closed. If you need to replace the switch or lid strike, the parts are available at searspartsdirect.com. Just type in your model number and look under the "Washer Top and Lid" heading on the next page. The lid switch is listed as item number 22 (part #3355806) and the lid strike is listed as item number 16 (part #358684). Both parts combined will cost you about $30. If you have further questions and/or require additional assistance, please let me know. I hope this helps you.
Posted on Jul 22, 2008
  • 7 Answers
SOURCE: whirlpool thin twin filled with water then stopped!
Not sure about the dryer but there are a couple things that could cause the no draining issue.
You could have a leak or block in your pressure hose. Basically there is a thin, clear tube inside the cabin that attaches to the tub on the lower right side. If this has a leak or is clogged then the washer has problems filling and draining.
The other possible problem is a broken lid switch. This is an easy fix. Basically, the mechanical mechanism that goes down when you close the lid does not work properly so when it comes time to drain, the washer actually thinks the lid is open.
For both of these you would need to open cabin. I posted instructions for that here:
http://www.fixya.com/support/t1885690-whirpool_twin_washer_dryer_lte5243dq3
Posted on Apr 03, 2009
Thermal cutoff switch fails 2x in a year. Heating coil ohms out ok.
Whirlpool Thin Twin, dryer thermal cutoff failed twice - Appliance ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Oct 12, 2011 - 6 posts - ‎2 authors
Friends Whirlpool Thin Twin came with purchase of condo half a year ago. A month ago it stopped heating. I checked continuity and found the ... Whirlpool Dryer Thermal Cutoff
Jan 9, 2013
Thermal cutoff blew again (Whrpl Elect Dryer)
1 post
Jan 5, 2013
More results from forum.appliancepartspros.com
Why does the thermal fuse keep blowing in my dryer ...
www.shopyourway.com > Manage My Life > Questions
Dec 28, 2015 | Dryers
Whirlpool thin twin LT5000XUWO why water not shutt off overflows
bad water solenoid, underneath that is the unit that the water goes to and there are wires coming from it it is sticking in the on position
Aug 25, 2014 | Whirlpool Thin Twin Washer and Electric...
Whirlpool Thin Twin WET3300SQ (water stops coming in)
  • We are sorry to hear of the problem with your Whirlpool washer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your washer.
Apr 07, 2017 | Whirlpool LTE6234D Top Load Stacked...
How can I fix my whirlpool thin twin washer?
It almost sounds like your motor is kicking out on overload. The fact that it starts agitating after the fill can rule out the pressure switch. You have installed a new timer so we should be able to rule that out. It's possible that your pump is binding, which is attached directly to your motor and causing it to overheat. To tell for sure you would have to check the motor to see if it's getting power when it cuts out. Check your terminal block where the power cord comes in to see if all connections are secure. Other possibilities could be the clutch and brake assy. With out being there too see the problem, this is where I would start.
Apr 27, 2006 | Whirlpool LTE5243D Top Load Stacked...
Dryers Logo
47 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
