Question about Lexmark X6150 All-In-One InkJet Printer
I have a Lexmark X6150 and it is connected to my Windows 7 computer via USB. I can't fax from my computer because the device isn't recognized as a fax. How can I fix this?
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
Hi
uninstall you printer driver fro myour pc
download from here and reinstall it
In case I had help you pls vote
Posted on Nov 06, 2010
My Lexmark e332n shows error code 43 ,what does it mean?
G'Day Mate,
Are you running the Lexmark driver for Windows 7 64 bit.
Try down loading the driver and installing it on your p.c.
Suspect USB driver for printer is missing - Windows can't detect it as it doesn't recognise it. By installing the Lexmark driver it updates windows to recognise the lexmark printer usb interface.
you will find driver here
http://support.lexmark.com/index?locale=en&page=product&productCode=LEXMARK_E332N&segment=SUPPORT&userlocale=EN_US&frompage=null#1
Aug 14, 2015 | Lexmark E332n Laser Printer
Can't print. Lexmark has an x by offline
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Mar 10, 2012 | Lexmark X6150 All-In-One InkJet Printer
I have upgraded to Windows 7 and my Lexmark X6170 will print but not scan. I need the scanner badly. Please advise on solution.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
Aug 29, 2011 | Lexmark X6170 All-In-One InkJet Printer
Cannot get my Lexmark Z2420 printer working--it has the wi-fi capability, but trying to connect it via USB. Should be plug-and-play but windows makes a sound like it recognizes it, but nothing comes up as...
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/9xPHL4. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 26, 2011 | Lexmark Z2420 Printer
My impresora es modelo 4408-k02 y necesito sofware my computadora es windons 7 pero no lee la inforrmacion
Utilice el controlador de Vista en Windows 7. Antes de descargar el controlador, busque el tipo de sistema de Windows 7 (si es de 32 bits o 64 bits). En el equipo, haga clic en el menu Inicio -> PC -> Propiedades. Tome nota de el tipo de sistema. Ustedpuede descargar el controlador Lexmark X6150 de la pagina web de Lexmark utilizalos siguientes enlaces:
- Lexmark X6150 Driver para Windows Vista de 32 bits - Lexmark X6150 Driver para Vista de 64 bits
(NOTA: Esto se traduce con http://translate.google.com.)
Apr 19, 2011 | Lexmark X6150 All-In-One InkJet Printer
Where can I find drivers for windows 7? many thanks avio
The Lexmark X6150 printer is not compatible with Windows 7 OS. However, this printer will work with Windows Vista and Windows XP computer. Here's the link for the driver - http://bit.ly/d43qMR.
Aug 17, 2010 | Lexmark X6150 All-In-One InkJet Printer
Wireless printer communication unavailable via USB
Hi. Hope you got it working fine now on your Windows 7. If not, go to Start Menu > Devices and Printers > right click on the Lexmark print object > Troubleshoot. Make sure the printer is on and is still connected to the computer via the usb cable.
Mar 12, 2010 | Lexmark Wireless X4850 All-In-One Inkjet...
I have windows 7 and need to install lexmark x6150 and it will not plug and play, how can i get it installed
go to lexmark.com put in your product x6150 it will ask for your os. Type windows 7 and download the software.
Jan 08, 2010 | Lexmark X6150 All-In-One InkJet Printer
How do I connect my X6150 to my PC just to scan pictures into the computer
I believe that the AIO Lexmark printers connected to the PC via the USB port on the PC.
They also may have connected by a parallel port connection using the ECP connection protocol of the IEEE 1284 Standard.
Don
Dec 09, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark x6150 wont scan
Sounds like your laptop isn't talking to your scanner. These scanners only work if it has access to a computer to store the scanned image. Check if your USB drivers are installed. Most times you can go to "Device Drivers" in Control Panel (Under the "System" icon) and right click USB to update drivers on the net. Depends how old your laptop is too. If that isn't the problem, try installing the drivers again, or search the net for newer versions.(Usually at the Lexmark site). But at the end of the day, you won't be able to scan till your laptop can recognize your Lexmark printer!!!!
Feb 14, 2008 | Lexmark X6150 All-In-One InkJet Printer
Lexmark X6150 All-In-One InkJet Printer Logo
32 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
