Machine keeps doing one step of cycle and beeps
When we go to do a load in our Frigidaire LTF2140ES Front Loader it does one step of the cycle then just beeps. We have to push the start button again and then it does the step again and does another step and beeps. It takes about 2 hours to do a load now cause we have to keep pushing the start button and it keeps repeating cycles. Any ideas on what to do?
    Genius:
  • 1,036 Answers
Hi there.
There may be a problem on the control board (you suspected yes?)
Or it may be waiting for a certain condition.
Basically it's a very simple computer.....-
Select program (sequence of events)
Water fills.....Untill weight sensor says stop.
Water then heats........Untill temperature sensor says stop.
Goes through a sequence of motor spins....untill time out.
Pumps out.....untill floatswitch says empty.
Does same again ...or something else.
Either the control board has a fault - so just doesn't advance, or there is a faulty sensor that never supplies the info needed to advance.
Try and spot at what point it stops and waits. This will pinpoint what it's waiting for.
If it's waiting to heat up - and the element has blown. it will be stone cold. This is a common fault.
Let me know how you get on.
Richie.
Posted on Jun 14, 2008
  • crshowers Dec 04, 2010
    Our washer has this same condition. It is not any specific cycle and it does stop and beep on different cycles. The next load you do it will not stop at that same cycle but may stop at a different cycle.
    Any ideas would be appreciated
My frigidaire GLTF2940ES3 front load washer keeps making beeping noises even when not on. I have unplugged it until using it. Seems to work somewhat but it stops in between cycles, beeps and blinks...
frigidaire has problems with their computer boards and it sounds like this is your problem,i've seen them shut down and then after a while start beeping on it's own just like your machine is doing and it was the board part 137006000
Dec 04, 2017 | Frigidaire GLTF2940ES Front Load Washer
I have a front loader washer...it was in the middle of the cycle and starting beeping. The dr (door) signal is flashing. Cloths are wet and i can't get any cycle to go now. Any suggestions?
Unplug your machine.
Open the top of the machine.
Open door
Remove the door lock assembly
Check contacts of the door switch.
Replace if faulty or try to clean with electronics cleaning solvent.
Jun 23, 2010 | Frigidaire Affinity ATF6000F Front Load...
I have a mo# FTF2140ES0 front loader washer that won't spin
check the pump for a blockage,if the water cantget out of the wash tub,the machine senses this and wont spin out the load,also make sure to check both sides of the pump from the tub to pump and pump to house drain sides
Mar 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
Front load pumps out water, DOESN'T SPIN, but DOES "tumble"
The pressure switch or pressure switch tube could be blocked tricking the machine that it still has water in it therefore not advancing into 'spin mode'.
Or the electronic card could be faulty and require replacing.
Jun 17, 2009 | Frigidaire GLTR1670A Front Load Washer
Error messege, front loader wont start.
my name is joyce
first try the simple step, unplug unit for 60 secounds, then replug unit back up. reset load and see if that works. let me know if I can be of further assistance.
joyce
Feb 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigadaire front loader washer
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Nov 03, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Beep coming from washing machine
You might have the end of cycle setting turned on. It will beep to let you know that the washer is done. Can turn off, under options on the control panel.
Oct 01, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire front loader washing machine won't spin...
just had my frigidaire fronter loader repaired,,try the door switch ...mines wouldnt spin clothes were soaked did everything else fine... what may have happen is when the spin cycle is ready to do its part it double checks to see if door is locked but with a bad switch it sends the wrong signal and computer this the door is open so it shuts off....well gl mines is running got lots of laundry to do,.,,,hope this helps
May 29, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washer keeps beeping
HATE TO SAY IT BUT THE BOARD WOULD NEED REPLACEMENT.BEEPING NORMALLY INDICATES A FAULT CONDITION WHICH WOULD STOP THE CYCLE(WASH) OR THE COMPLETION OF A CYCLE.
Jun 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
96 people viewed this question
Top Washing Machines Experts
