Question about Air Tools & Compressors
Our company has ingersoll rand air compressor model SSR MM 150 is giving high temperature of air ultimately facing moisture problem at downstream of dryers.Need your assistance.Kindly send the manual if you have.
    Problem Solver:
  • 17 Answers
Make sure the cooler is clean..change the oil filter if hasn't been changed in a while..could be bad thermo valve..oil level?How many hours on machine?
Posted on Dec 19, 2010
How to change from BAR to PSI on INGERSOLL RAND INTELLISYS CONTROL for INGERSOLL RAND SSR-6-20-125 AIR COMPRESSOR
Ingersolll Rand website support section should be able to provide a manual.
Failing that contact customer services.
Aug 03, 2016 | Ingersoll Rand Air Tools & Compressors
Ingersoll rand air compressor model SSR-UP5-30-14 frequent trip on high airend temperature ....what is the solution ? and another unit ( same model ) always trip on " starter fault ". Untill...
check if approach and discharge pipes to oil cooler are similar temperature as there is a thermo bypass valve that controls the flow through the cooler if cooler is quite cool but still very hot inside this could be stuck in closed position causing restricted flow through the cooler
Sep 20, 2011 | Ingersoll Air Tools & Compressors
Ingersoll Rand SSR compressor shuts down loaded or unloaded with no alarm, and then shows ready to start . Will not run more than a few minutes either loaded or unloaded. installed meter on incoming power...
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
PRESSURE OR TEMP SENSOR FAIL
CHECK MOTOR ROTATION
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
I am assuming this has a Intellisys controller.
Aug 25, 2009 | Air Tools & Compressors
My rotary screw air compressor model SSREP100H
It's just too hot. Blow out the radiator weekly. There is an oil temp switch that might need replaced but the radiator is the most common problem with screw compressors. You can check the settings in the control panel, where you turn it on and off. It should be set for a high temp of 185°.
Aug 08, 2009 | Ingersoll Rand - Rand Type - 30...
Where can i find motor fan part # 2mtr and 3mtr ingersoll rand compressor ssr-ep25
I would try Grainger (www.grainger.com)
They sell IR compressors and always have a large assortment of parts
Jul 16, 2009 | Ingersoll Rand Type 30 Fully Packaged Ir...
Air Tools & Compressors Logo
201 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
