Question about Canon PIXMA MP530 All-In-One InkJet Printer
I have a paper jam in my printer and i cant reach it from the back, and i cant get it
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
Hi
Open cover of printerg in order to see the cartridges (like when you replace them)
you will see the paper you can reach it from there
In case I had help you pls vote me
Posted on Nov 06, 2010
Mg5250 paper jam
do auto clean should help paper come lose
Jul 16, 2013 | Office Equipment & Supplies
Have a paper jam in my pixma ip4500 and cant see the paper anywher to take it out?
Paper jam I suppose is the commonest of all printer problems as it can occur due to strayed, stuck bits of papers in pathway of paper tray, outlet, roller etc. I would recommend cleaning the paper inlet, outlet, and other possible areas to avoid a paper jam situation.
Follow the given steps to clear paper jam
>Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
->To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
->For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
->Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
->Try printing another document
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Mar 15, 2013 | Office Equipment & Supplies
Says paper jam, but there is no paper jam
->Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
Nov 20, 2012 | Kodak ESP 5 Printer
I cant fix the paper jam problem. every time i take the paper jam out it jams again
I have had paper jams in five different places on this machine. It has jammed at the pickup point from the tray, in which case you have to remove the paper tray and pull the jammed paper out. It has jammed at the manual paper feed tray, in which case you just have to pull the jammed paper out of the feed rollers. It has jammed at the toner/drum, in which case you have to open the front cover and pull the toner cartridge out to remove the jam. It has jammed in the back of the machine where the paper feeds through to the output tray, in which case you have to open the small back panel and remove the paper. And it has jammed in the output rollers, in which case you have to reach inside the output tray and remove the paper. Then once the jam is cleared there are times when the machine has to be unplugged for up to 8 hours to reset before it will function properly.
Aug 16, 2010 | Brother MFC 8840D All-In-One Laser Printer
Paper jam and cant reach it I can see the end of the paper in there but I cant get to it
I would be very surprised if you cannot reach paper with all compartments open!!
Can you carefully use tweezers or long nose pliers.....BEWARE of not touching any interanl components with them. Unplug from wall also.
Apr 07, 2010 | Brother HL 2140 Laser Printer
Paper Jamming
The problem with your printer is likely to be dust getting the way of your sensors; preventing it from seeing paper, preventing the rollers from effectively feeding the paper. This is if you are sure all other things are in proper working condition. Just get a long reach brush and try to reach in as far as possible and brush as best as you could, front and back is there is access.
Sep 14, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Paper jam on my ESP3 printer. How do I get the
Go to www.kodak.com/go/itg and select all in one printers and then paper jam as your problem. they will give you step by step instructions to resolve the issue. if this does not solve the issue, call kodak @ 1800 421 6699 and they will replace the printer for you free of cost as all the esp-3 printers are in warranty as of now.
Aug 07, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Paper jam on office jet G55 hp in a hard to reach location.
in rear of HP printers there is an access (clip on plastic plate) you should use to remove paper shads or jams. Pulling paper out from front may harm the printer. Open back and attempt removal of jam.
May 19, 2009 | HP OfficeJet G55 All-In-One InkJet Printer
Paper jam
It's pretty rare to not be able to manually clear a paper jam. Occasionally, after you clear a jam, some paper gets stuck in the mechanism where your fingers can't reach. In that case, part of the printer mechanism needs to be taken apart to get to the jam. Like I said, it's pretty rare, but when it happens, your only option is to take the printer to a certified printer repair shop or back to the place where you bought it to get it worked on. Unless you know what you're doing, I wouldn't recommend using tools inside the printer yourself. You run the risk of damaging the mechanism and making your current problem worse.
The HP web site does publish a couple of solutions. Have a look at the information on the following two links and see if there's anything you may not have tried yet:
Clearing a Paper Jam
Clearing a Carriage Jam
Post back whether or not either of these links worked out for you. Good luck.
Oct 01, 2008 | HP PSC 1610 All-In-One InkJet Printer
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
24 people viewed this question
old marine
old marine
