My printer still does not working properly.And my printer also still show low ink after i refill the ink
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
Hi
try cleaning cartridges from printers menu
Ink level that you get has no problem
you can ignore it and keep printing
for more information pls tell me your printers model
In case I had help you pls vote
Posted on Nov 06, 2010
Hp 6515 cartridge shows low after a refill
There is no such mechanism to detect ink levels in your printer., it wont detect if adding more ink in it., it will detect only new cartridge when you replace it., printer shows estimated ink levels as per the print outs. This is hp trick to aviod refill &non hp consumables...
Sep 30, 2014 | HP Photosmart 6515 Wireless Color All In...
Changing ink cartridges
If you have put in genuine Canon cartridges, contact Canon support for advice.
If you have refilled in any other way, your printer cannot detect ink levels. If you have used a refill kit, you might have problems if you return your printer for repair under warranty as evidence of refilling is the first thing checked for
Apr 09, 2010 | Canon Pixma iP2600 Photo InkJet Printer
We have a Dell 944 showing Error 1102 consult user guide...cannot find the user guide. We just replaced color ink cartridge with a re-processed one ordered online. Please advise...many thanks!.
Hi there
Dell Printer 944 error message 1102
Please unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Now plug everything back in. This will reset any error messages the printer has. Now open the printer with the power on and the cartridges should go to the center to be replaced. Take out both Dell Series 5 ink cartridges and make sure the tape is off the cartridges and insert both back in and make sure the seat properly and latch. Close the printer and it should print an alignment page. If you still get the error message
Why does my Dell ink cartridge level still show up as "low ink" after refilling them?
Dell ink cartridges have a sensor that reports the ink level as low once it reaches a certain level. The sensor can not
be reset. If you refill an ink cartridge that previously reported low ink, it may print fine, but the sensor will always
report low ink. Buying or replacing ink cartridges with new Dell cartridges will resolve the low ink message.
Dell discourages ink refills. Refilling ink may lead to print quality problems, and even eventual hardware problems.
This post is in no way a validation of refilling ink cartridges.
Why my printer is reporting “low ink" after using refilled/remanufactured ink cartridges?
Most ink cartridges have sensors that report the ink level. The “Low Ink” is usually the last sensor (fuse) before
running out of ink.
Since the sensors are fuses that open when the ink level drops, they cannot be reset. If you are using refill or
remanufactured ink cartridges, the best thing to do is to disable “ink alerts” on the printer’s software so you don’t keep
getting “low ink” messages.
To disable “Ink Alerts” on Dell inkjet printers:
1. Open the Dell printer software (All-In One Center, Tool Box, etc)
2. Go to Settings
3. Advanced
4. More Options
5. In the “Appearance Mode, window, check “Never display the Printing Status window” and “Display the low
ink alert only when the cartridges are almost empty.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 23, 2010 | Office Equipment & Supplies
With new cartridge indicates low ink level,
The ink level gauge may not work properly with refilled cartridges. Because of this, you might get low ink message after refilling. To install the refilled cartridge you might need to override the ink level gauge. Overriding the ink level gauge disables the printer’s ink level tracking feature, but allows you to use refilled cartridges. To override the ink level gauge, please check your printer reference guide. After disabling the ink level tracking feature you should check the ink level visually and as soon as the ink level gets low you need to refill the cartridge. You do not want to try to print with an empty cartridge. Trying to print with an empty cartridge may damage your print-heads.
otherwise you will have to replace the cartridge .
Oct 21, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Ink low/empty errors.
Some of the ink sellers have the chips available for purchase. You just have to make sure you get a new chip with your new inks...
Sep 18, 2009 | Canon PIXMA® MP530 All-In-One Printer
Low ink showing with refilled cartridge
sometimes the proper carteidge ink has a element in it that is seen by the lazer. refills do not. you have to guess. but it will work. its best to have a proper cartridge ever 3 changes. keeps things working. it will show the level on a real one.
Mar 26, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
How to reset ink level warning when refilling?
EASY!!!!: push the cancel button by 6 seconds, this deactivate the ink level sensor.
Dec 15, 2008 | Canon PIXMA MP470 All-in-One Printer
Low ink light will not go off after refining HP94 ink cartages
the message of low ink cartrige always appears after refilling the cartridge or installing the recycled cartridge.only if u install orignal cartridge it will go.but let it show low ink you will get proper printouts till the end of the cartridge as this message does not effect on copy quality or number of printouts.the printer will work.just cancel that message or ignore.it will not effect your printer.
thanks.
Nov 13, 2008 | Office Equipment & Supplies
How to Override Ink Level Gauge When Using Refilled Cartridges
Above link great.
If you have a newer print cartridge cart, look for the little window. I put a sticker over the little window on the Brother (innobella) LC38 cartridge cart and it worked great :)
Despite finding a fix for this problem, I think this is a rip off setting on the brother printers and I will never buy another Brother printer for this reason.
Jul 04, 2008 | Brother MFC 420CN All-In-One InkJet...
Canon mx310
Canon cartridges have an intelligent chipset to prevent them from being refilled. To have them working properly you need to reset the chipset.
Try the software on this link.
If the above did not work you will need to use a cartridge chip resetter if you want to refill your cartridge.
Jun 06, 2008 | Canon Pixma MP500 All-In-One InkJet...
26 people viewed this question
k24674
jasbo
jasbo
