Question about Samsung HLR6768W 67" Rear Projection HDTV
Have a samsumg 67 inch-- HLR6768w tvworks ,when i replace color weel , i discover there is a part w magnifire lenses (located between color wheel and lcd board assembly) lenses inside are cracked,how can i get part # many tech friends sugest repl whole light engine ***'y
  • Samsung Master
  • 5,138 Answers
Yes ,its the Light Engine also known as Optical unit Assy block
Go to Encompass Parts Distribution 1-800-638-3328 and look up your Model #
Samsung Parts.com 1-800-627-4368 (PTS 1-800-844-7871) (UED 1-800-648-6657)
PN# BP96-01198 E
Posted on Nov 06, 2010
How to remove rear cover samsung HLR6768W?
Possibility (one screw behind a piece of tape or other manufacturer icon) Also there are some with a couple snap together clasps that you have to be very careful to get open with small screwdriver. Be sure if this is a CRT television that the screw that fastens to the flyback transformer is out. Some also have a screw or three in the front where the power button, channel & audio adjustment are located. Just a few places and things you can check.
Jun 07, 2014 | Samsung HLR6768W 67" Rear Projection HDTV
Hlr6768 Fans and Color wheel turns on full speed as soon as it's plugged in.
Whenever you attempt a repair and have new issues ( yours is a duzzey) stop and step back and look over what you just did.
Possible reasons for this:
A bolt of lightening struck and by chance just after you replaced the light engine--not likely.
I would (serious note) BACK TRACK and remove it checking all cables and connectors are plugged in and in the right place--the whole engine in most of these slides in and it is easy to miss something or tangle some wires etc.
the other two possible reasons are = the new engine has a defect, strange and odd but odder things have happened.
The engine does communicate to other boards and anything you have already replaced is suspect.
Hope you get it sorted out but likely it is man made--happened in the course of your adventures at trying to fix it.
May 28, 2012 | Samsung HLR6768W 67" Rear Projection HDTV
Loud motor type vibration sound
This is an indication of faulty color wheel. Watch the link below to have an idea how it gonna look like.
http://www.youtube.com/watch?v=QznEaSWq-C8&feature=related
Oct 04, 2011 | Samsung HLR6768W 67" Rear Projection HDTV
Once we turn the tv on it would start making a sound like a whinning high pitch sound with no picture..and it wont turn off anymore unless you pull the plug..
hello jackiea0819,
pich sound on HLR6768W because of the collor wheel. The color wheel not rotate properly.
My suggestion you replace the color wheel. Call samsung technician to replace it.
Good luck.
Mar 29, 2011 | Samsung HLR6768W 67" Rear Projection HDTV
Tv shuts off within five min. light bulb was replace and its still shutting off. HLR6867W samsung
U hear alot of clickings,when turn on the tv?Ur Ballast board is dead.The ballast board to help it to light up the projection bulb.
Jun 06, 2010 | Samsung HLR6768W 67" Rear Projection HDTV
Loud noise, line on the left side, no color
It sounds like the color wheel has fallen apart and will have to be replaced by a technician. The line could be from the color wheel or from the light tunnel. You can call 1-800-samsung for the nearest service center.
Feb 04, 2010 | Samsung HLR6768W 67" Rear Projection HDTV
Turbine/moaning sound and vibration
The grinding sound that you are hearing is your color wheel. They can make a noise from a buzz to a power saw type of noise. Usually the set will continue to play with the noise, but it is annoying. You will need to replace the color wheel now.
This is not as easy as the lamp replacement, as you have to pull the light engine to access the color wheel. It is not hard just more work and be careful of the color wheel lenses.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jun 03, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung 6768W DLP 2 yrs old Replaced lamp and now color is off Faces look like paint by number
possible solution:
http://www.avsforum.com/avs-vb/showthread.php?t=1050735
  1. You may need to adjust the index delay after the replacement. You will be able to tell because you may see strange color banding in any scenes that have colors close, but not quite the same, in tone. This is usually most obvious in face skin tones (i.e. “clay faces”). If you need to adjust index delay, turn off the set, wait for the lamp to cool down, then hit mute-1-8-2-power in succession. The set should turn on with the service menu popping up eventually on the left. I don’t remember which submenu “index delay” is under, but find it and usually it will need to be lowered. I believe mine started out in the mid-50’s and had to be lowered to 47. These numbers are different for each Samsung model, so just adjust until the picture is pleasing to your eye. By the way, the supposed “correct” way to do this is to make the reddish part of the test color bar appear the “most saturated”, if you have a color calibration device.
Oct 15, 2008 | Samsung HLR6768W 67" Rear Projection HDTV
Samsung HLR6768W 67" Rear Projection HDTV Logo
258 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
