Is that any specified smps to be used for mother board
  • 5,660 Answers
Depends on the age of the motherboard.
To clarify;
When Switched-Mode Power Supply's were first made for personal computers, for the main power cable they used two of them.
This was the AT power supply.
http://www.playtool.com/pages/psuconnectors/connectors.html#oldpc
The next version of the SMPS used a single main power cable, the ATX power supply.
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
As personal computers increased in Processor power, and graphics power, it was found that more power to the motherboard was needed. The ATX main power cable was increased from 20-pin to 24-pin, to handle the extra load,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
A lot of motherboards also receive extra power through a 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
This power cable is used for power to the Processor.
Power Supply's (SMPS) have increased in power over the years to keep up with the demand for power.
They have also increased the number, and type of power cables used.
Some now have an extra 6-pin PCI Express power cable for added power to a graphics card, or two 6-pin PCI Express power cables.
Some SMPS's have an 8-pin PCI Express power cable for added power to a graphics card.
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress8
If an SMPS has an 8-pin EPS +12 Volt power cable, it is used for added power to the motherboard, for the Processor.
http://www.playtool.com/pages/psuconnectors/connectors.html#eps8
If your concern is how much power can your motherboard handle, know this;
A computer ONLY uses the power it needs, and NO more.
If you had a 10,000 Watt power supply, and the computer only needs 100 Watts, the computer only uses 100 Watts. (10,000 Watts is an exaggeration)
Do you know the motherboard's name, and Model Number?
State in a Comment, and I should be able to tell you what power cables it needs, and give examples of an SMPS that will work.
SMPS,
http://en.wikipedia.org/wiki/Switched-mode_power_supply
Posted on Nov 06, 2010
Hp Pavilion, Power supply Inactive, HHD savagable, intel Chip Savagable, i was thinking a new motherborad for the chip and the hard drive ????
If your Desktop not start it means not you mother board problem because starting you find your SMPS proper running or not. Because SMPS supply all power in CUP so you check it SMPS on or off position. if SMPS ok then you check it mother board light on or not, if on then ok or not on then you change SMPS supply.
If your display issue then you check it RAM and HDD.
Thanks.
Computer Support
Feb 20, 2014 | HP Pavilion a305w (DM181AR) PC Desktop
Smps working indivudually but motherboad no disply and when i conect to board in that time smps and cpu fan also not working why
1.) Use alternative SMPS
2.) Use alternative motherboard
3.) Unplug HDD, check if BIOS screen is displayed
4.) Check if your input voltage power to the SMPS is sufficient
Feb 26, 2013 | Intel DG31PR Motherboard
I brought a new Intel H55Tc Mother board, Core i3 Processor, 2GB DDR3 Ram. Now my system fan and smps fans spindling is not continue. But My SMPS is working well with other mother board.
Dear vijay, Please check your power ic of mother board there is problem. When you change it then your cpu and processor fan will be working.
Thanks. Rakesh.
Nov 26, 2010 | Intel H55TC Motherboard Core i5 650...
Dear sir my motherboard not display i will cheack ram, bois,smps
does ur processor fan and smps fan work if both are working then the problem is in the motheboard if both are not working check ur smps by shorting the green pin with black if it doesnt work change ur smps and it works the problem is in ur motherboard ur power supplysection in ur motherboard has been fried take the mother board to a qulified chiplver service personal
Sep 27, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Tv standby
Possible that the mainbaord is faulty, the output driver is short or a high voltage component is short.
Since the model is not specified , you will have to check the mother board for errors as your SMPS is working but check if the secondary fuse has gone off in the high voltage section of the SMPS.
Sep 26, 2010 | Televison & Video
Dear sir, my computer asus sis961 is not working, power is not showing in mother board, technician is telling in mother board short sirkit
Do u know how to assemble a pc
if yes take the mother baord out of cabinet . place the mother bord on an insulating surface with proceesor . then connect smps ... poweron the board by shortin the frnt panel connectors . connect all peripehrals like monitor , kb and mouse etc ..... if this seems to be working try to insulate the cabin whre mother board is fixed ................ SMPS can also cause no power try chekin with another smps too
Aug 05, 2009 | ASUS P4SE Motherboard
Computer will not start
first you connect your harddisk data cable to mother board
connect your hard disk powercode using smps
connect smps 24pine connector threw mother board
connect 12v connector threw mother board
connect cpu&external fan connections
also connect the front panel connections on mother board using mother board details
Jun 17, 2009 | ASUS A7N8X Motherboard
No beeps,cd,flopy,monitor-can i use cleaning fluid on mother board?
Dear sir,
Have u changed the SMPS or not? If not change the smps & check it
Max.this problem related to smps only, in somecases problem may with motherboard also
Pl try it
was this soultion useful?show your appericiation by rating it.
Thanks
Mar 17, 2008 | Gigabyte 7nnxp Motherboard
No booting is possible
check the connections between your mother board and power supply. if it is in tack and still wont work replace your power supply.
Jan 21, 2008 | ASUS P5RD1-VM Motherboard
Display
I have Intel Jetway 945 Mother Board, I checked the Processer and Ram, And SMPS it is working properly, but I am facing display problem.
Oct 29, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Computers & Internet Logo
281 people viewed this question
Alun Cox
David Payne
David Payne
