Question about Epson Stylus C86 InkJet Printer
My Epson T10 printer is printing cyan instead of magenta
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
Hi
Your printhead is clogged at magenta exit
try cleanning it from printers menu
In case I had help you pls vote
Posted on Nov 06, 2010
The cyan and magenta cartidges have run out but I cannot print in black only, since a staus window appears telling me to replace cartridge the cyan and magenta and will not let me continue to print in...
You can't print in black only mode because printer need all cartridges not empty to initialized and working.Don't try to refill this cartridges, it's have a chip and you need to reset it too.Just look in your are for non OEM ink cartridges.Thea are 2-3 times cheaper.
Nov 08, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Type of catridge epson stylus R390 uses can't find
You can see the reference on the cartridge itself.
Take it with you when you buy new ones.
Jul 29, 2009 | Epson Stylus Photo R390 InkJet Printer
Colour Ink Jet Cartridges emptying during a black ink print run
If you go to your printer properties, there should be a setting whereby you have to select the option to "PRINT USING BLACK CARTRIDGE ONLY". Make sure this option is selected, otherwise your printer will use ALL colors even if you only print black.
Let me know if you need any further assistance.
Best wishes,
Graemevm
May 07, 2009 | Epson Stylus DX6050 All-In-One InkJet...
Epson R800 Red Color Problem
Actually magenta is the weakest compared to cyan and
yellow using even K3 inks. Now epson is releasing
K3 with vivid magenta ink. Using any color management
I have found it very difficult to reach a real red without
a lot of tweaking in my color profiles. Now it appears
that Epson sees the problem and is changing magenta
out for vivid magenta ink to solve the weak magenta.
Jul 17, 2008 | Epson Stylus Photo R220 InkJet Printer
Printing Yellow instead of Red
The colours in the 3 colour cartridges are cyan, magenta and yellow. If you want to print "red", this requires a mixture of magenta and yellow. Thus if only yellow is printed when you should be printing red, it means the magenta is not printing i.e. faulty/empty magenta cartridge or faulty/blocked magenta nozzles.
Please post a new comment if you wish for further help with this problem.
Jul 17, 2008 | Epson Stylus C86 InkJet Printer
Epson Stylus R230 Light Magenta Not working
Print first a nozzle check pattern, self test which they say. Check your manual for your printer, it should be accessible from that if you dont have any manual, go to the epson website and download a manual. Usually the self test would go like this.
While the printer is turned off, you press and hold down the paper feed button, continue holding it down while turning on the printer. It will print the nozzle check pattern standalone. If you see all the colors then the issue your having is a color management issue, if you do not see the cyan, magenta, yellow, black, light magenta and light cyan from that test; then you will need to do 3 consecutive times of Head Cleaning from the maintenance program in your computer. If you have a windows xp it goes like this.
Click on start go to control panel - printers and faxes -
you right click on your printer icon and select printing prefrences. From there, go to maintenance tab and click head cleaning, go through that cycle 3 consecutive times and see if it improved. Good luck....
Jun 12, 2008 | Epson Stylus Photo R300 InkJet Printer
C88 / T060 cartridge refilling problem
sounds lke your yellow nozzle not working properly...had same issue on lexmark printer, ended up geting this epson...learnt from my mistakes...perhaps it ran dry? or you left the yellow cartridge out longer than the rest....only you might know what happened
Mar 22, 2008 | Epson Stylus C88 InkJet Photo Printer
Epson cx5000 Ink Cartridge shows ink is running out after 2 8 x 10 prints.
IT IS POSSABLE THAT THE PRINT HEAD ARE DIRTY THEY HAHVE MATCHING BOARDS TO THE TONER CARTRIDGE BOARDS UNPLUG THE MACHINE AND CLEAN THE PRINT HEAD WITH ALCOHOL IF IT DOESN'T WORK THE BOARDS HAVE FAILED
JP
Dec 31, 2007 | Epson Stylus CX5000 InkJet Photo Printer
Epson Stylus C86 InkJet Printer Logo
161 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
