Question about Lexmark X5470 All-In-One InkJet Printer
Mediacard Can some one please help? My printer works but all of a sudden I cannot use my media card. The green light does not come on and it says there is not one inserted. Thanks Bobbie
  • 1 more comment
  • Bobbie1944 Jun 15, 2008
    Sorry..Not media card but memory card and it is plugged directly into the computer slot. I tried another card and it will not work either.
    Thanks for reply Bubbabear
    No that is not the problem because you can only plug it in one way. Actually the light did come back on but I can still not get it to read. Thanks again for trying.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Where is the media card plugged in at?
  • Lexmark Master
  • 2,794 Answers
Are they plugged in the right direction? Sometimes those card readers won't let you know that you plugged that card in wrong.
Posted on Jun 15, 2008
  • Tim Babcock
    Tim Babcock Jun 15, 2008
    Im just making sure here.
    Are you able to read the media card in the camera ok?
    If so it's probably something going on with the card reader on the printer.
    If you have one for your computer, that one should work.
    There fairly inexpensive to get at electronic or computer stores.
Epson L355 - My Printer suddenly cannot connect to Wifi network.
try to put it back to the same place where you took it, if it work, it means that the place where you moved it might have poor signal and if thats the case, i advise you to put a wifi repeater/extender near that wireless printer
Mar 05, 2014 | Epson Stylus Multifunction Inkjet Printer/...
What causes a computer not to start up and the mediacard is not working?
A computer will not start/power up via the software control on/off switch, you will need to reset the power supply controller circuit by completely removing the power plug from the AC main for a couple minutes and then replug the desktop. Incidentally for a Laptop, you additionally need to remove the battery pack.
If your computer gets power and it does not BOOT-UP, then the media you have chosen does not have a valid bootable section or operating system make sure that any external media (e.g. SD card or USB memory stick or USB externa drive) is not plug in as the system will normally attempt from the externally media first.
Hope it helps: let me know how you go.
Sep 27, 2010 | Computers & Internet
I have a wrt54gc. It's been working well for some
1. Check with the ISP to see if there are no outages in the area.
2. 1st try to release/ renew the ip.
3. G to the Command line see if you can ping out i.e ping www.yahoo.com or some familiar site.
Apr 26, 2010 | Linksys (WRT54GC) Router
My ML 1610 Laser printer was working just fine a few minutes ago but it suddenly stopped printing and now the lights are blinking. It seems to be in this order 5 red 1 green 9 red 1 green 7 red 1 green...
please your problem is printer in rem and sarket in ice is fail. and you go to the near autho. dealer and changing the serket board
and checked the rem. and printer's services is fine.
Oct 03, 2009 | Samsung ML 1610 Laser Printer
My samsung ML2010 printer has Error button flashing green
your printer is not inisilize properly. it is a logic card problem.so pls you can repaired it from printer vendor.
Sep 02, 2009 | Samsung ML 2010 Laser Printer
Printer suddenly stuck while starting up
eww this one can be lots of things!!!
make sure no paper jammed anywhere
make sure the print head is moving
make sure the ink cartridge is set down right
May 24, 2009 | Samsung CLP-300N Laser Printer
Installing the 1gb card
Remove the sheel backside of your phone
remove the battery
now you see your sim-card
you place the sd-card just at the right side of the sim-card
lift the mediacard holder
insert the sd-card into the slot in the mediacard holder so that the metal connectors on the card will align with the metal connectors on your phone when the media card holder door is closed
close th media card holder door and slide the media card door away from its hinges to lock it
put back the battery and shell and you done!
If you still dont know, here is an demostrator how your phone works
http://demos.blackberry.com/8310/na/us/gen/
Good luck
Dec 07, 2008 | SanDisk 2GB microSD Memory Card
I am inserting a media card and comp is telling me it needs to be formated and can't format it.
once its inserted, go to my computer , right click on the mediacard (now seen as removable storage) and click on format.
Oct 07, 2008 | HP Computers & Internet
Orange cartridge light error keeps on blinking!
clean the carriage home
check the data cable for the carriage home
check the media sensor on the left of the plotter media bar
Mar 12, 2008 | HP DesignJet 450c InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
22 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
