Question about Canon BJC 210 InkJet Printer
My canon bjc 210 printer cartridge is giving very low quality prints. I put in boiling water and cleaned with ammonia solution also but no effect. My other cartridge BC 02 is not printing at all.
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
Hi
You need to replace it with an other one new
but check first at new one the expire date on cartridge
In case I had help you pls vote me
Posted on Nov 06, 2010
My pixma610 is not printing clearly. It leaves gaps in the print. All the ink cartridges have ink in them.
Rosemary.
Do a deep clean cycle then a nozzle check either from the computer or the maintenance wheel on the 610.
May sure all the line are printed correctly.
If not remove the head and cartridges and take some hot(not boiling) water and mix it with2 oz. of Ammonia and let the head sit for an hour in a cereal bowl .Re-install after making sure the head is completely dry and check nozzles again.
If not working you either have bad cartridges or a bad head.
I have a new heads if needed.
Apr 06, 2015 | Canon PIXMA MP160 All-In-One InkJet...
Can the print head be replaced?I have an older printer that hasn't been used in a while. print quality is really bad, i've put new ink in
Yes it can be replaced, but this is often unnecessary. Printer manufacturers don't want you to know this, but if you get a shallow dish and place enough ammonia-based window cleaner in it (something that REALLY smells like ammonia, not the lemony other nonsense, or streakless) to cover the print head, right up to the pads that the ink cartridges sit on, and let it soak for a few hours, it will come completely clean and work like new. It's best to squirt the pads for a minute or so to remove the current supply of ink, THEN soak it overnight. Use a lint free cloth to pat dry the inside, re-install the ink cartridges in their correct spots and re-install the printhead. You're ready to go. While you're at it, clean the copper electrical contacts on the print head with a bit of isopropyl alcohol and a Q-tip. May as well be thorough!
Mar 15, 2010 | Canon BJC 3000 InkJet Printer
I have a Canon BJC 210. Colors reversed, won't print black
take the cartridges back and stick to official ones. Remanufactured cartridges tend to be more trouble than they are worth and cost more in the long run fixing the errors they cause.
Get a refund as they are faulty and buy some Canon ones :D
Nov 25, 2009 | Computers & Internet
Problems with Canon BJC S400 - will not print ink on documents even though I just changed the ink cartridge
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 18, 2009 | Canon BJC S400 / CanoScan N650U InkJet...
Started printing light / dark blue bands instead of same shade. Tried cleaning but no different. Thanks.
Do a proper head clean.
Remove the cartridges and put them aside.
Remove Print head taking care not to touch the metal parts.
Boil some water, pour one quarter inch of boiling water into saucer.
Place the part of the print head where the ink comes out in the water.
Give it a few seconds, you will see the ink coming out into the water.
Sit the print head on some paper towel with the part where the ink comes out on the towel and let the excess water be absorbed by towel..
Replace print head in printer, taking care not to touch the metal parts.
Place cartridges back in print head.
Do some test runs to check the condition of the head, you may have to do a head clean or two.....
If that doesn't work try a new blue cartridge.
Usually works on my machine.
Jul 08, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon BJC 80 prints blank pages!!
Power off the printer.
Unplug it, then plug it back in.
Wait until it stops its initialization sequence.
Press and hold the power button.
Allow the printer to beep 7 times, then release the power button.
This will reset the EEProm to factory default, and should clear your problem.
May 26, 2009 | Canon BJC 80 InkJet Printer
My Canon mp390 printer doesn't print
I had this problem several times, had to buy new print head until I found that to clean it you should use ammonia. It really worked for me. You should really try ammonia it does work.
Apr 22, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Can I use only a black BJ cartridge on a Canon 620 printer?
Nope. You can use Cyan, Magenta and Yellow as well as Black.
Specifications (BJC 620):
  • Form Factor: Desktop
  • Connectivity Technology: Cable
  • Language Simulation: EPSON LQ • IBM Proprinter X24E
  • Media Type: Coated Paper • Envelopes • Glossy Paper • Labels • Photo Paper • Plain Paper • Transparencies
  • Max Media Size: A4 (210 x 297 mm) • Legal (216 x 356 mm, 8.5 x 14")
  • Total Media Capacity: 100 Sheets
  • Media Path Type: Straight
  • Operating System: Microsoft Windows 3.x
  • Product ID: 20152942
  • Exterior Color: White Product Description for Canon BJC 620 (From the Manufacturer, Canon)
    Simply a piece of printing marvel, with high definition printing, superior ink technology, innovative waste-free ink system and user-friendly Windows printing system. The BJC-620, simply a must buy for those who seriously considers printing in superior, high quality color. It comes with an Internet kit.
    This printer model is not being manufactured by Canon any more
    Related links for Canon BJC 620:
    Canon BJC 620 printer ink cartridges at PrintCountry.com
    Canon.com's site
    Canon printer ink cartridges
    Canon BJC 620 Driver
  • Apr 18, 2009 | Canon BJC 6200 / CanoScan N650U InkJet...
    Printer problem
    I found a small plastic "clip" of the type that covers the print-head of a cartridge in the mechanism where the printhead/inkcartridge is mounted. I have no idea where it came from nor how long it had been in there but the printer works OK after I removed it.
    Jun 22, 2008 | Canon BJC 2100 InkJet Printer
    Canon BJC 210 InkJet Printer Logo
    Clive
    Clive
    old marine
    old marine
