Question about Dishwashers
Drain The water will not drain. Everything seems to work until it gets to the draining part.
  • 1 more comment
  • Kevinfitzjar Jun 14, 2008
  • BUBBLESANN Jun 14, 2008
    i am having the same problem everything else runs fine but when it's all done the water is staying in the bottom of the dishwasher so i think it's the filter that is clogged so i'm wanting to try and clean it but i don't know how to go about that so help would be great
  • monteath_r Jul 26, 2008
    My Kitchenaide dishwasher is not draining..."Kitchenaide superba" there is a twist top on top of the bottom arms. How do I access filter to try and clean it? The twist top does not want to move so that I can take the arms off to get to the filter??
    Thanks
    Problem Solver:
  • 12 Answers
Your going to have to get the water out by hand first to see whats going on. Dishwasher drain pumps do not often fail it's more common for bits of broken glass or cups to have got past the filters and jammed the pump. On some machines you can access the impellor on the pump by removing a small plate inside the machine which covers it, on others the only way is to remove the pump from underneath. Bosch machines usually have a twist lock pump which is fairly easy to remove.
Posted on Jun 15, 2008
Water seems to be leaking from freezer into refrigerator
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? it overflows into the ref.
If this was helpful please rate me.
IMUFO2
Leo Ponder
imufo2@sbcglobal.net
Jul 24, 2011 | Whirlpool Refrigerators
Water does not completely drain after a wash cycle. Everything else seems to work just fine.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jun 16, 2011 | Frigidaire FDB1100RHM Builtin Dishwasher
I am having an issue with my LG front loader washing machine model number WM1815cs. The water will not drain and the clothes will not spin out. Everything works fine until the rinse/spin cycle and it just...
Hi
Thanks for using FixYa. OE is a Drain Error which indicates that the water was not fully drained within 10 minutes. To start with check the drain pump filter for any clogs/foreign materials and try to clean the filter. Also if you have already checked the drain hose for any blockage then check the pump for any blockages, if still its not resolved then it seems to be the pump that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 28, 2010 | LG WM1815CS Front Load Washer
Whirlpool ET21DMXDW05 top freezer. icemaker not working
Give it some more time. The icemaker has an internal thermostat and it will not come back on until it reaches 16 degrees. It takes a while after it gets warm. if it doesn't start functioning in a few more hours you may have other problems. Hope this helps
Jun 07, 2009 | Refrigerators
Water in my refridgerator
common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Jan 26, 2009 | Refrigerators
I have water leaking into the ref compartment from the freezer
I would get a pipe cleaner or wire and clean out the rest of the drain hose. also use HOT water down the drain. untill all the water drain thru the hose.
after you get it clear run a wire down the drain and wrap it around the heater .. heat from the wire will keep it clear of ice..
Dec 21, 2008 | Kenmore Refrigerators
Water collects on shelves in refrig.
Nov 26, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Admiral Washer AAV7000AWW everything works -goes through cyclebut will not drain
You,ve done a good job the first time the pump fail MikieM. You can do it again. We sometimes forget to empty our pocket. Some small metal things could have gotten into the pump...could be other hard foreign object. Good luck.
Dec 21, 2007 | Admiral AW22 Top Load Washer
Wash motor does not run: Inlet/Drain error
Wordhog: Does sound like a siezed wash pump to me. Wash motor needs to run to get the correct level of water.
To drain a Miele dishwasher, start the machine on a cycle. All the Miele range of dishwashers drain before filling. Then hold in the start button until the end/finish light is lit. Keep doing this until all the water has gone. You could just get a jug and bail it out. Once the jug does not do the job anymore, switch to a cup, I use a very large syringe for the remaining half a litre.
Oct 28, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Dishwashers Logo
117 people viewed this question
Top Dishwashers Experts
