Question about Hotpoint Ovens
Fan in main oven does not come on when oven is switched on,there is a delay of sometimes up to fifteen minutes oven has often reached desired temp from element at back of oven without fan operating. When fan does eventually come on oven working as it should.
  • Hotpoint Master
  • 3,463 Answers
The fan motor is obviously faulty, the only real solution is to fit a new fan, if you do not, then the element is in danger of burning out, do not delay replacing the fan motor.
Posted on Nov 06, 2010
Main Oven does not reach required temperature
check gas pressure and burner if ok bad temp sensor
May 19, 2017 | Electrolux EOD5330 Ultrafan Electric...
How do I replace the bottom oven element in a CDA CD 907 double oven
ISOLATE MAINS POWER BEFORE WORKING ON THIS APPLIANCE
Remove the back of the oven check temp controller before replacing or buying element, as this can often stop any heat being produced. The element is in front of the fan, if this model is fan assisted, remove fan, after removing element inspect to see any small hole in metal, if you see a large hole more than 10mm , this could be a sign that the fan needs cleaning. Clean fan with WD40, do not switch oven on untill fan has dried off. Then replace element, switch oven on low with door open, if you feel slight heat, go for a full test, gradually build up heat, keep on for at least 30 mins, make sure the oven reaches temp, you can expect some smell from a new element, this is protective oil, and considered normal.
May 10, 2011 | Ovens
Takes for ever to reach temp
you may want to check to make sure both elements are working, if only one is working it will take longer to reach temp and to cook
Sep 18, 2010 | Fisher and Paykel AeroTech OS302 Electric...
The oven pre heats to desired temp and then loses
SOUNDS LIKE THE TERMOSTAT IS FAULTY REPLACE IT AND YOUR OVEN SHOULD WORK FINE.
Nov 09, 2009 | Thermador SMW272 Electric Double Oven
Oven not reaching correct temp
It isn't a design flaw. It is an air pressure switch. Main fan not running OR oven is dirty and the tube to the air pressure switch is clogged. Dirty ovens aren't a design flaw. I saw it once a week. Five minutes clearing the tube and you back in business. Hope this helps.
Jan 13, 2009 | Lincoln Conveyor Oven - 1133-000-A
My oven turns off on me after only a minute never heating up fully
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turning then replace fan. If mains voltage is not present then its the thermal switch.
Jun 19, 2008 | AEG B1180-4 Electric Single Oven
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
Ovens Logo
281 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
Steve Allison
Steve Allison
Colin Stickland
Colin Stickland
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
