Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
I cant find Recycle Bin in my Western Digital EHD when put on pc. But it show in my TV EHD player. How can I access it?
5 Suggested Answers
lenny297
  • 133 Answers
SOURCE: Free space on my external hdd
You need to run a virus scan, there could be some infection which is making it misread the amount of empty space and if the disk has several partitions are those partitions formated?
Posted on Mar 20, 2008
  • 3422 Answers
SOURCE: Missing recycle bin
To delete apps you can also use shift+delete key.
This will permanently delete the app..
If you need anymore help let me know..
Posted on Jun 01, 2008
SOURCE: we purchase western digital 500 gb hdd when pc is
The blinking of the lights is just the indication that data is being accessed.
Posted on Mar 19, 2010
lock123
  • 6831 Answers
SOURCE: can not access western digital external hard drive...
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
Topcon total station gts 725
In windows 7, it is there. In explorer, put the name recycle bin in and it will show.
Apr 06, 2014 | HEWLETT-PACKARD Computers & Internet
Wd 1 tb - shows no disc space left, but the files on it don't take up much space.
Depending on the Operating System you are using (i.e. Windows or Mac OSX etc.), they deal with deleting files in different ways. In the case of an Apple Mac, it doesn't actually delete you files, but instead moves them to the recycle bin which is located ON your external hard drive. This means that in order to make the space available, you have to empty your recycle bin on your desktop whilst the hard drive is plugged in and it will empty the folder for you. Or look for a hidden folder on the root of your Hard Drive called Recycle and delete it (it will be recreated by your system when your system needs it).
Alternatively, 1TB is a large drive meaning that it is possible that your file structure has become "fragmented". Don't worry yourself with the specifics, but if you right-click on the drive and access the Properties, choose the Tools tab and use the Defragment tool. Also it might be worth using the Check Disk For Errors option, although Defragment is more relevant in this case.
If you run through these basic troubleshooting steps listed above I hope you will gain access to your cleared space.
Apr 01, 2014 | Western Digital My Book Essential 1TB...
Deleting tracks off 4gb sa2640 gogear
The files are not deleted from the device but moved to the recycle bin. To completely remove the files from the MP3 player, use the following procedure:
1. Open Windows Explorer by double clicking the My Computer icon on your desktop.
2. Click on the Tools menu and select Folder Options.
3. Select the Tab View and check to select the Show hidden Files and Folders option.
4. Navigate to the device. A folder called recycle bin is available. Completely remove this folder from the device.Once the recycle bin folder is removed, the files are completely removed from the device and the free space is available.
Mar 27, 2014 | Philips GOGEAR SA6045 MP3 Player
I deleted the music folder from my PC , how do I restore it?
Open the "recycle bin", usually on the desktop. Select the recycle bin icon on your desktop, right-click the icon and click open. Find your folder in the list then right-click it then click "restore". Your folder will be restored to its original location and should be available to you with all files within the folder intact.
Feb 09, 2014 | Eclipse CLD2 MP3 Player
Deleted recycle bin
What operating system do you have? I will show you how to restore Recycle Bin within Windows 7.
Right click on your desktop, chose "Personalize", and follow steps in picture
Nov 17, 2013 | Apple iPod Audio Players & Recorders
Deleted recycle bin
It depends on what version of Windows you are using. If you open Windows explorer by pressing the "windows" and E key at the say time you should see it. Otherwise, modify your display settings as the option to show the recycle bin is usuall there. Another thing you can do to empty the recycle bin is to run a disk cleanup, as this will give you the option to empty the recycle bin as well.
Jul 29, 2013 | Fujitsu Computers & Internet
How can i delete folders from my wd hard drive (500)
You can delete the folders from your hard drive by
**To select any folder just Left click once on the folder**
1. Select the folder press delete button from keyboard.
2. Select the folder right click it in it you will see delete option just click delete.
3. All the 2 above ways will delete the folder but it send the deleted folder in your recycle bin from there you have delete them further by the same methods i told you above or by right clicking recycle bin icon in it you see empty recycle bin.
4. If you want to delete the folder permanently without sending it to recycle bin. Just select the folder and press shift+delete keys. Then a dialog box appears to conform it select yes and thats it.
You can contact me or thanks me on my email id ejaz89@live.com
Aug 05, 2010 | Western Digital My Book Essential Edition...
Need to restall from recycle bin
Open the recycle bin. Then, select the file you want to restore (or multiple files, through either Ctrl-click or Shift-click), right-click it (them), and select 'Restore'. It (they) will be moved to its (their) original location(s), prior to its (their) deletion.
Just my 2 cents.. Carlos
Jul 01, 2010 | Western Digital My Book Essential 500GB...
Power to 1T EHD not going through
yay, I plugged it back into my computer at home and it worked... might have not been enough power or the USB connection wasn't strong enough. anyway, happy happy happy...but have learnt a big lesson...BACK IT UP ON DVD as well.
Mar 26, 2009 | Western Digital My Book Essential 1TB...
Recycle bin
1. Click Start, and then click My Computer. 2. On the Tools menu, click Folder Options. 3. Click the View tab, and then click to clear the Hide protected operating system files (Recommended) check box. 4. Click Yes when the warning message appears, and then click OK to close the Folder Options dialog box. 5. Click Folders on the toolbar.
Note If Folders is not visible on the toolbar, point to Toolbars on the View menu, and then click Standard Buttons. 6. In the left pane, under Folders, locate the Recycle Bin folder, and then drag the Recycle Bin folder to the desktop. 7. On the Tools menu, click Folder Options. 8. Click the View tab, and then click to select the Hide protected operating system files (Recommended) check box. Click OK.Note This procedure does not re-create the original icon. However, this procedure restores most of the features of the Recycle Bin, including the following: • Delete a file by dragging it to the Recycle Bin icon on your Desktop. • Retrieve a file that you deleted by double-clicking the Recycle Bin icon on your Desktop, right-clicking the file that you want to retrieve, and then clicking Restore. • Empty the Recycle Bin by right-clicking the Recycle Bin icon on your Desktop, and then clicking Empty Recycle Bin. When you use these step to work around the problem, you cannot right-click the Recycle Bin shortcut to access the Recycle Bin Properties. To set properties for the Recycle Bin, follow these steps: 1. Double-click the Recycle Bin shortcut on the Desktop. The Recycle Bin folder opens. 2. In the upper left corner of the Recycle Bin folder, right-click the Recycle Bin icon, and then click Properties.
Mar 31, 2008 | Acer Aspire 5500 5570-2609 Laptop
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
121 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
