Question about RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2
Replace PTO oil seal -difficulty in removing shaft from bearing
2 Suggested Answers
  • 5481 Answers
SOURCE: my to30 P.T.O shaft is
Hello, I have in front of me a catalog for Valu-Bilt.Com, a tractor supply company for all makes. Your Seal can be one of several depending on the Serial number of your tractor. There phone number is 1-888-828-3276.
The Catalog I have shows a Model 35, but I see you have a Model 30. I believe the transmissions were different between the 30 and 35, but see no reason for the rear end to change. The later Model 35 had more gears like a Sherman unit. The Model 35 had a model with 2 extra forward gears and the model used as a Front Loader had 2 extra in both Forward and Reverse.
Now Ferguson and Ford were similar, with the Ferguson having more innovations. Check with a Ford Dealer for PTO seals. The Continental engine was desired as it had Overhead valves and more power over the Ford.
You may also get lucky with Tractor Supply who carry some parts. One additional thing is the number of teeth on the PTO shaft. The book shows a 17 tooth, 25 Spline as 1868528M1 for the Model 30 PTO shaft. The Model 35 has 10 Splines in both a 17 and 19 tooth shaft.
So it is possible you may not even have the original PTO seal if someone put in a part for a Model T35.
I hope this is helpful and would like to know if you found your part. Thanks
Posted on Jul 03, 2011
Change seal for PTO kubota f3680
Remove the PTO shaft extension from the shaft put a drain pan under to catch the oil Tap a chisel or other tapered tool in behind the seal flange and work the seal out install a new seal an re-install oil up to full level
Jun 13, 2015 | Kubota Garden
Leak oil from underneith where the shaft comes out of the engine
If you look at the bottom of the engine, if you see oil on the large shaft coming out of the engine where the blade is attached, the PTO or crankshaft seal is leaking. It can be replace without taking the engine apart, but you'll need to remove the blade and adapter from the crankshaft, which can be difficult without the proper tools. You'll also have to remove the old seal, with a seal puller, or by using a couple self-tapping sheet metal screws into the outer metal part of the seal. You then would pry on the screw heads to remove the seal. Replace with a new one after cleaning out the bottom of the crankcase. Clean the PTO so that the new seal is not damaged as it is slid into place. You can use a length of plastic pipe to drive the new seal into place. Replace adapter and blade. Check oil level before use.
Oh, be sure it is not the drain plug, as it may have been left a bit loose if the oil was recently changed.
tom
Jun 17, 2012 | Measuring Tools & Sensors
Briggs&straton all the oil leaked out from under the engine. the engine oil
hi there donald77
provided you have not got any cracks in the sump plate and the sump plate bolts are tight
sounds like you have a worn out pto seal ( please check pto for bend or wobble ) as this could have caused this from hitting something solid
it it is bent have it straightened before proceeding
remove the blade carrier and hub and key - clean up the pto with emery tape , drain oil , use a straight shaft flat blade screwdriver and lever the seal out of position
obtain a new seal place some thin plastic sheet ( from say a thin walled plastic container )
cut into a size that you can wrap around pto , then slide the seal over it up to the opening ,
the drive the seal into the housing squarely until the seal is flush with the housing ( on a non stepped pto ) 7/8 shaft
but on a stepped pto 25 mm drive it in further until its about 3 mm below the housing
reassemble and refill with oil
cheers hope it helps
pauly46
May 30, 2011 | Garden
1998 ford explorer 2 wheel drive rear wheel bearing replacement
what about it?
conventional axle or limited slip? Get axle code off door sticker.
SECTION 205-02: Rear Drive Axle/Differential - Ford 8.8-Inch Ring Gear 1998 Explorer/Mountaineer Workshop Manual
IN-VEHICLE REPAIR Rear Wheel Bearing and Axle Shaft Oil Seal -4.0L SOHC and 4.0L EI, Conventional
Special Tool(s) swn~us~en~file=st1514a.gif~gen~ref.gif Axle Seal Replacer
T83T-1175-A swn~us~en~file=st1283a.gif~gen~ref.gif Axle Wheel Bearing Puller
T83T-1225-A swn~us~en~file=st1322a.gif~gen~ref.gif Axle Wheel Bearing Replacer
T83T-1225-B swn~us~en~file=st1326a.gif~gen~ref.gif Driver Handle
T80T-4000-W swn~us~en~file=st1185a.gif~gen~ref.gif Impact Slide Hammer
T50T-100-A
Removal
  1. Remove the axle shaft; refer to Axle Shaft in this section.
Axle Shaft Removal
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not use heat to loosen a seized lug nut. Heat can damage the wheel (1007) and the rear wheel bearings (1225).
    Loosen the lug nuts (1012).
    1. Remove the center cap.
    1. With the weight of the vehicle on the wheels, loosen the lug nuts.
  1. Raise and support the vehicle.
  1. Remove the wheel and tire assembly.
    1. Remove the lug nuts.
  1. Remove the axle housing cover (4033).
    1. Loosen the axle housing cover bolts (4346) and drain the rear axle (4001).
    1. Remove the axle housing cover bolts.
    1. Remove the axle housing cover.
  1. Remove the rear disc brake rotors (2C026); refer to Section 206-04 .
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Once the differential pinion shaft (4211) has been removed, turning the differential case (4204) or an axle shaft (4234) will cause the differential pinion gears (4215) to fall out of the assembly. This could result in chipped or damaged components.
    Remove the differential pinion shaft.
    1. Remove the differential pinion shaft lock bolt.
    1. Remove the differential pinion shaft.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the rubber O-rings in the U-washer grooves.
    Remove the U-washers (4N237).
    1. Push the axle shafts inboard.
    1. Remove the U-washers.
  1. Reinstall the differential pinion shaft.
    1. Install the differential pinion shaft.
    1. Install the differential pinion shaft lock bolt finger-tight.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the inner wheel bearing oil seal (1177).
    Remove the two axle shafts.
Installation
  1. Lubricate the lip of the inner wheel bearing oil seal.
    • Use Premium Long-Life Grease XG-1-C or equivalent meeting Ford specification ESA-M1C75-B.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Once the differential pinion shaft has been removed, turning the differential case or an axle shaft will cause the differential pinion gears to fall out of the assembly. This could result in chipped or damaged components.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the inner wheel bearing oil seal.
    Install the two axle shafts.
    Install the U-washers.
    1. Position the two U-washers on the button end of the axle shafts.
    1. Pull the axle shafts outward.
    1. Align the hole in the differential pinion shaft with the differential pinion shaft lock bolt hole.
    1. Install the differential pinion shaft lock bolt.
  1. Install the rear disc brake rotors; refer to Section 206-04 .
  1. Install the axle housing cover and fill the rear axle housing (4010) with 2.4 liters (5.5 pints) of specified lubricant; refer to Axle Housing Cover in this section.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif WARNING: Always remove any corrosion, dirt or foreign material that may be present on the mounting surfaces of the wheel or the surface of the wheel hub or rear disc brake rotor that contacts the wheel. Installing wheels without proper metal-to-metal contact at the wheel mounting surfaces can cause the lug nut to loosen and the wheel to come off while the vehicle is in motion, causing loss of control.
    Clean the wheel hub and mounting surfaces.
  1. Install the tire and wheel assembly.
    1. Position the tire and wheel assembly.
    1. Install the lug nuts and lower the vehicle.
    1. Tighten the lug nuts.
    1. Install the center cap.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Never remove the axle shaft oil seal by itself. Always remove the rear wheel bearing and the axle shaft oil seal at the same time.
    NOTE: If the axle shaft oil seal is leaking, the axle housing vent may be plugged with debris.
    Use Impact Slide Hammer and Axle Wheel Bearing Puller to remove the rear wheel bearing and the axle shaft oil seal.
Installation
  1. Lubricate the new rear wheel bearing.
    1. Use Thermally Stable Rear Axle Lubricant XY-80W90-QL or equivalent meeting Ford specification WSP-M2C197-A.
  1. Use Axle Wheel Bearing Replacer with Driver Handle to install the rear wheel bearing.
  1. Lubricate the lip of the new axle shaft oil seal.
  1. Use Axle Seal Replacer with Driver Handle to install the axle shaft oil seal.
  1. Install the axle shaft; refer to Axle Shaft in this section.
May 18, 2011 | Ford Explorer Cars & Trucks
The electric pto keeps kicking off, after about 10 to 15 seconds. shut the pto off turn it back on, then does it again, & again, ect.
The PTO motor may be bad, but first check the motor shaft for debris caught on it, check the drive wheels, the drive chain and lubricate the wheel bearings and chain(ATF or Snthetic oil)a few drops go a long way. A few drops of oil on the motor shaft where is goes into the motor might help as well. Electric parts usually do not like water(you may need to remove a cover to access the motor and bearings)blow the motor with an air hose if available to remove debris from it. I hope this is helpful the model number and make would make a diagnosis easier on this end. Thanks, SP
Oct 18, 2009 | Garden
How do you remove right rear axle on a 2004 ford crown vic to replace seal on wheel?
Section 05-02A: Axle, Integral Carrier — 8.8-Inch Ring Gear 1994 Town Car, Crown Victoria/Grand Marquis. Workshop Manual REMOVAL AND INSTALLATION Axle Shaft NOTE: Whenever replacing the rear axle lubricant, use Rear Axle Lubricant XY-90-QL (ESP-M2C154-A) or equivalent.
Removal
sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: The rear brake anti-lock sensor must be removed before the axle shafts are removed. The rear brake anti-lock sensor is bolted on the rear disc brake caliper anchor plate.
  1. Raise vehicle to desired working height. Refer to Section 00-02 . Remove rear wheel (1007) and tire assembly. Remove rear disc brake calipers (2552) and rear disc brake rotors (2C026) .
  1. Clean all dirt from area of axle housing cover with a wire brush and/or cloth.
  1. Drain rear axle lubricant by removing the axle housing cover .
  1. Remove differential pinion shaft lock pin and differential pinion shaft .
  1. Push flanged end of the axle shafts toward the center of the vehicle and remove the rear axle shaft retaining u-washer from the button end of the axle shaft .
  1. Remove axle shaft from the rear axle housing , being careful not to damage the inner wheel bearing oil seal (1177) and rear brake anti-lock sensor ring.
Installation
NOTE: Check for presence of rear axle shaft o-ring (4A332) on the spline end of the shaft and install if not present.
sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Care must be taken not to let axle shaft splines damage oil seal or bearing assembly.
  1. Carefully slide axle shaft into rear axle housing without damaging rear wheel bearing (1225) or rear brake anti-lock sensor indicator (2C189) . Start splines into side gear and push firmly until the button end of axle shaft can be seen in the differential case .
  1. Install the rear axle shaft retaining u-washer on the button end of the axle shaft splines, then pull the shaft outboard until the shaft splines engage and the rear axle shaft retaining u-washer seats in the counterbore of the differential side gear .
  1. Position the differential pinion shaft through the differential case and differential pinion gears , aligning the hole in the differential pinion shaft with the lock bolt hole. Apply Rear Axle Lubricant to differential pinion shaft lock pin . Install differential pinion shaft lock pin and tighten to 20-41 Nm (15-30 lb-ft). sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Differential pinion shaft lock pin must be tightened to specification using Stud and Bearing Mount E0AZ-19554-BA (WSK-M2G349-A1) or equivalent.
    NOTE: Axle housing cover must be installed within 15 minutes of application of the silicone rubber or new silicone rubber must be applied.
    sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Make sure machined surfaces on both axle housing cover and rear axle housing are clean before installing the new silicone sealant. Inside of axle must be covered when cleaning the machined surface to prevent axle contamination. Tighten the cover bolts in a crosswise pattern to ensure uniform draw on axle housing cover .
  1. Apply Silicone Rubber D6AZ-19562-AA or BA (ESB-M4G92-A or ESE-M4G195-A) or equivalent. Install axle housing cover and tighten retaining bolts to 28-38 Nm (38-52 lb-ft).
  1. Add Motorcraft Rear Axle Lubricant XY-90-QL or KL (ESP-M2C154-A) or equivalent until it is 6-14mm (1/4-9/16 inch) below bottom of fill hole. Add 118.3 mL (4 oz) of Ford Additive Friction Modifier C8AZ-19B546-A (EST-M2C118-A) or equivalent to Traction-Lok axles. Install fill plug and tighten to 20-41 Nm (15-30 lb-ft).
  1. Install rear brake anti-lock sensor indicator . Tighten retaining bolt to 4.5-6.8 Nm (40-60 lb-in).
  1. Install rear disc brake caliper and rear disc brake rotor .
  1. Install wheels and tires.
  1. Insert Rear Bearing Remover T85L-1225-AH in bore and position it behind bearing so tangs on tool engage bearing outer race. Remove rear wheel bearing and inner wheel bearing oil seal as a unit, using Impact Slide Hammer T50T-100-A.
    Rear Disc Brake Caliper Anchor Plate
  1. Lubricate the rear wheel bearing with Rear Axle Lubricant.
  1. Install rear wheel bearing into the housing bore using Axle Tube Bearing Replacer T78P-1225-A.
    sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Installation of rear wheel bearing or inner wheel bearing oil seal assembly without proper tool may result in an early bearing or seal failure. If inner wheel bearing oil seal becomes cocked in bore during installation, remove it and install a new one.
  1. Install the inner wheel bearing oil seal using Axle Tube Seal Replacer T78P-1177-A. Use Premium Long-Life Grease XG-1-C or K (ESA-M1C75-B) or equivalent between the lips of the inner wheel bearing oil seal .
  1. Install axle shafts as outlined.
May 13, 2009 | 2004 Ford Crown Victoria
Rear wheel bearing
SECTION 205-02B: Rear Drive Axle/Differential — Ford 8.8-Inch Ring Gear 2003 Mustang Workshop Manual IN-VEHICLE REPAIR Axle Shaft Removal
  1. Raise and support the vehicle. For additional information, refer to Section 100-02 .
  1. Remove the wheel and tire assembly. For additional information, refer to Section 204-04 .
  1. Remove the rear brake disc (2C026). For additional information, refer to Section 206-04 .
  1. Remove the differential housing cover (4033) and drain the lubricant. For additional information, refer to Differential Housing Cover in this section.
  1. Remove the differential pinion shaft (4211).
    1. Remove the differential pinion shaft lock bolt (4241).
  1. s3b~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the rubber O-ring in the axle shaft groove.
    Remove the U-washer (4N237).
    1. Push the axle shafts (4234) inboard.
    1. Remove the U-washer.
  1. s3b~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Damage to the rear brake anti-lock sensor (2C190) may occur if it is not removed before the axle shaft.
    Carefully remove the rear brake anti-lock sensor. For additional information, refer to Section 206-09A .
  1. s3b~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the wheel bearing oil seal.
    Remove the axle shaft.
Rear Wheel Bearing and Axle Shaft Oil Seal Removal
  1. Remove the axle shaft (4234). For additional information, refer to Axle Shaft in this section.
  1. NOTE: If the wheel bearing oil seal is leaking, the axle housing vent may be plugged.
    Using the special tools, remove the rear wheel bearing and wheel bearing oil seal.
Installation
  1. Lubricate the new rear wheel bearing with the specified lubricant.
  1. Using the special tools, install the new rear wheel bearing.
  1. Lubricate the lip of the new wheel bearing oil seal.
  1. Using the special tools, install the new wheel bearing oil seal.
  1. Install the axle shaft. For additional information, refer to Axle Shaft in this section.
Installation
  1. Lubricate the lip of the wheel bearing oil seal
    Install the U-washer.
    1. Position the two U-washers on the button end of the axle shaft.
    1. Pull the axle shaft outward.
  1. NOTE: If a new pinion shaft lock bolt is unavailable, coat the threads with Threadlock and Sealer EOAZ-19554-AA or equivalent meeting Ford specification WSK-M2G351-A5 prior to installation.
    1. Align the hole in the differential pinion shaft with the case lock bolt hole.
    1. Install a new differential pinion shaft lock bolt.
  1. Install the differential housing cover and fill the rear axle with the specified lubrication. For additional information, refer to Differential Housing Cover in this section.
  1. Install the rear brake anti-lock sensor. For additional information, refer to Section 206-09A .
  1. Install the rear brakes. For additional information, refer to Section 206-04 .
  1. Install the tire and wheel assembly. For additional information, refer to Section 204-04 .
  1. Lower the vehicle.
Apr 10, 2009 | 2004 Ford GT
Replace left rear axle seal 1999 ford explorer
Axle Shaft Removal
  1. Remove the differential housing cover (4033).
    1. Loosen the bolts and drain the lubricant from the rear axle housing (4010).
    1. Remove the bolts.
    1. Remove the differential housing cover.
  1. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Turning the differential case (4204) or an axle shaft (4234) with the differential pinion shaft (4211) removed will cause the differential pinion gears (4215) to fall out of the assembly and damage the components.
  2. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the rubber O-ring in the U-washer groove.
  3. Remove the U-washer (4N237).
  4. Push the axle shaft inboard.
  5. Remove the U-washer.
  2. Install the differential pinion shaft lock bolt finger-tight.
  3. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the wheel bearing oil seal (1177).
Seal Removal
  1. Remove the axle shaft (4334). For additional information, refer to Axle Shaft in this section.
  1. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Never remove the wheel bearing oil seal (1177) by itself. Always remove the rear wheel bearing (1225) and the inner wheel bearing oil seal at the same time.
    NOTE: If the wheel bearing oil seal is leaking, the axle housing vent may be plugged with foreign material.
    Using the special tools, remove the rear wheel bearing and wheel bearing oil seal together.
6c7eb46.gif Installation
    • For 4.0L SOHC and 4.0L EI with limited slip rear axles and 5.0L vehicles, use SAE 75W-140 High Performance Rear Axle Lubricant F1TZ-19580-B or equivalent meeting Ford specification WSL-M2C192-A.
    • For 4.0L SOHC and 4.0L EI with conventional rear axles, use SAE 80W-90 Premium Rear Axle Lubricant XY-80W90-QL or equivalent meeting Ford specification WSP-M2C197-A.
  1. Using the special tools, install the rear wheel bearing.
  1. Using the special tools, install the wheel bearing oil seal.
Feb 22, 2009 | 1999 Isuzu Rodeo
Oil seal
1. Remove the acorn nut, hex nut, and washer that hold the "planetary" agitator section on the transmission shaft.
2. Remove the trim ring (if any) around the same.
3. The agitator section should now be able to be worked free.
4. Remove the retainer clip on the top of the agitator shaft. (Some models have a pair of hex nuts here; if so, remove those.)
5. Pry the gear up and off the shaft. Remove the square key from the shaft keyway at the same time.
6. Tap gently on the top of the agitator shaft to drive it out from the bearings and grease seal.
7. Recommend removing and replacing the top bearing at this time; it's inexpensive to replace, if you're in this deep.
8. Use a suitable diameter piece of round steel stock to drive out the lower bearing and oil seal. I don't recommend using the agitator shaft.
9. Clean thoroughly, insert a new bottom bearing and oil seal, drive in place with a rubber mallet.
10. Replace agitator shaft through oil seal and bearing, tap gently into place.
11. Fill cavity with approved lubricant. I use USP-grade mineral oil, as it is food-safe and provides satisfactory lubricity.
11. Install top bearing, tap gently into place.
12. Reverse steps 5-1 to reassemble.
Aug 24, 2008 | Food Mixers
RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2 Logo
1,049 people viewed this question
Top RTO Toys Experts
Timllfixit
scrivener
Are you a RTO Toy Expert? Answer questions, earn points and help others
