Question about Sakar 62150 Keyboard
Both of my shift keys stick in the "up" position,
    Novelist:
  • 77 Answers
Hi Brown551967,
Its the dust & dirt in the keyboard problem. If you have a powerful vacuum cleaner, try cleaning your keyboard with that. But before that use a long bristled brush between the keys to loosen out any stubborn dust particles. Concentrate more on the affected keys. If this helps the fine else you might need to disassemble the keyboard and do a thorough cleaning. Please DON'T try it if you're not confident of doing it. Just cleaning it thoroughly will do the job.
Hope this solves your problem.
Posted on Nov 06, 2010
Suddenly I can't type symbols that require the shift key. Capital letters work normally as do numbers.
Not sure if this is what your looking for but you might try to give this a try . It Could be your sticky keys and the worse thing: they can be activated by mistake. Sticky keys make it so you don't have to hold the shift, ctrl, alt and Win keys in order to activate their special functions. You can hit shift, let it go, and then hit a letter. You will get a capital letter.
How do you activate it? Usually by tapping on the shift button five times in a row. When you do that, a beep sounds, and the above dialog box appears. If you're not paying attention, you might just hit yes without realizing, it is the default answer after all, and you're stuck with sticky keys.
So how do you fix it? If you've managed to activate sticky keys by mistake, tapping five times on the shift button will turn them off. You won't see a notice about it, but you'll hear four beeps, and then a distinctive downwards beep. Sticky keys are now off!
Apr 05, 2018 | The Computers & Internet
Shift key sticks on right hand side
It is time to replace your keyboard (it is affordable). eBay is a good source.
Mar 01, 2014 | Dell Latitude D505 Notebook
Left shift key types symbols not capital letters
it could be set to do so in system settings, like a shortcut. or there could internally be something inside under the keys which causes it to do that
Nov 03, 2013 | Computers & Internet
CAP LIGHT DOES NOT COME ON
Unlock the Caps on Computers The All-Caps or "Caps Lock" function causes all letters to appear as capital letters when typing into word processing documents, emails or other files. This is convenient when needing to type numerous capital letters or All-Caps phrases, as you do not have to hold down the "Shift" button with one finger as you type the words. When All-Caps is stuck and does not respond to the "Caps Lock" keyboard button, a simple procedure overrides and shuts down the function. Open a word processing program. Press the "Caps Lock" button located on the left side of the keyboard to turn Caps Lock off. Type inside the document. If lower case letters appear in the document, Caps are successfully unlocked. Proceed if the text is in All-Caps. Hold down "Shift" on the keyboard. Press the letter "P." A lower case "p" appears in the document. Release the "Shift" button. Type the phrase "rint" directly after the lower case "P." The word "pRINT" is now in the document, and the document cursor is after the phrase's "T." Press "Enter" on the keyboard. The cursor goes down one line and "pRINT" becomes "Print." The "Caps Lock" function is turned off. Restart the computer to save the setting.
Enable the Caps Lock Key The "Caps Lock" key is loved by some and disliked by others. The key turns all letters into capitals as you type. While this feature is useful in some situations, a more common occurrence is that the key is accidentally hit and all the text typed is capitalized. The person typing must then delete the capitalized type and rehit the key to turn off "Caps Lock." If the "Caps Lock" key needs to be enabled, it indicates that someone has disabled or remapped the key. If a user wanted to, the "Caps Lock" key can be disabled and enabled through the registry or remapped through the control panels. Updating the registry for the keyboard will enable the "Caps Lock" key. Open the Notepad program. Type the following: [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout] "Scancode Map"=- Select "Save As" from the "File" drop down menu. Navigate to the computer desktop as the save file location and choose "All Files" from the "Save as type:" drop-down menu at the bottom of the Save As window. Type "enable.reg" without quotes in the "File name:" field and click "Save." Minimize all open windows to view the desktop. Double-click on the "enable.reg" file. A box will pop up asking if you are sure you want to run the file. Select "Run" or "Yes" and then click "Yes" for the Registry Editor warning. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled. b> Manually Update the Registry b> Click the "Start" menu, type "regedit" without the quotes and press "Enter." In older versions of Windows, Click the "Start" menu, select "Run," type "regedit" without the quotes and press "Enter." This will launch the Registry Editor. Navigate to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout" to view the settings. Right click on the "Scancode Map" setting and choose "Delete." Click "Yes" to confirm the deletion. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled.
b> b> b> Disable the Caps Lock Key in Windows Your computer's Caps Lock key has likely only collected dust since you first brought the machine home. The Caps Lock key is beneficial if you want to type a long string of words entirely in capital letters, but this form of typing is not needed often. Consider disabling your Caps Lock key if you do not need it, or if you are tired of hitting the key accidentally while rapidly typing.
Restart your computer before beginning the process of disabling your Caps Lock key. Download the registry file necessary to disable your Caps Lock key. You have the option to disable your Caps Lock key or change the key to a number of different keystrokes. For example, you may choose to use the "ChangeCapsToShift" registry file if you want the Caps Lock button to function as a shift key. Double-click the registry file you have downloaded. A prompt will appear on your screen asking if you would like to add the registry file to your computer's registry. Select "Yes" to install the registry file. Restart your computer, once again, to complete the registry change. Upon reboot, your Caps Lock key will no longer function as a traditional Caps Lock key.
Disable the Caps Lock Key on a Computer The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately. When this mistake occurs, usually you must correct some text errors and your time is wasted. If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key. Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window. Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control". Double click on "Keyboard Layout" to open the folder. Open the "Edit" menu and choose "New" then "Binary Value". A new file will appear on the right side of your screen with the file name highlighted. Type "Scancode Map" for the new file name. Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button. Close the "Registry Editor" by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key. Hope this helps
Jan 21, 2013 | Acer Computers & Internet
12/24/2012: XBOX 360/RB3-WIRELESS FENDER MUSTANG PRO-GUITAR: WON'T PLAY "FRET NOTES"
If your guitar was not purchased new (since it was hard to find these guitars late in the life cycle) then perhaps it was already faulty before you received it.
Dec 25, 2012 | Mad Catz Rock Band 3 Wireless Fender...
Problem with shift key
I think reformatting the hard drive at this point is a good move, you have tried everything else to no avail.
Jul 10, 2012 | Compaq Computers & Internet
I can`t get any upper case functions to work on hp 2011 keyboard what key do i press
1.Make sure the "Caps Lock" key is not on. Though this will be obvious to most people, if your keyboard is typing in only upper-case letters it can't hurt to check. Look at the "Caps Lock" indicator light on the top right corner of your HP keyboard. If the light is on, strike the "Caps Lock" key on the left side of your keyboard. This will turn the "Caps Lock" off, allowing you to type in lower case letters again.
2.Make sure the "SHIFT" keys on your HP keyboard are not stuck. Dust and dirt can build up on a keyboard over time, which can cause certain keys to stick. If either of your keyboard's "SHIFT" keys get stuck, your computer will type in only capital letters. Use a toothpick or cotton swab to remove the gunk from the key, which should help it return to its normal position.
3.Unplug your HP keyboard and then plug it back it. This will remove the device from your operating system and then automatically add it back in. This can have the same effect, essentially, as restarting your computer. If your keyboard was typing in capital letters due to an error being stored in your operating system's memory, that error will now be cleared and the HP keyboard will function as normal again.
4.Update your HP keyboard driver. Click "Start" and then right click on "Computer." Click "Properties" and then "Device Manager." Right click on the listing for your keyboard and then click "Update Driver." This will update the computer software that is associated with your HP keyboard. If your keyboard was typing in all capital letters as a result of an error with this driver, the error will now be fixed and you can use your keyboard normally again
Mar 01, 2011 | HP D8597A Keyboard
WHATS THE FN KEY DO AND HOW TO TURN IT OFF
The FN key gives you access to the controls that are usually circled on the regular keys like a shift gives you access to capital letters. it should require you to push and hold it down to activate it. If it is stuck in the down position your choices are limited to locating and clearing what ever it activating the key or replacing the keyboard.
Aug 08, 2010 | Samsung Computers & Internet
My shift key is not working properly in my Keyboarding online class. It gives me an error everytime I try to key in a capital letter. i have changed keyboards and it still does the same thing.
When you say it gives you an error, do you mean an actual error message, or the lower-case letter?
I have no idea what your experience is, so I'm asking if you know the difference between the Caps Lock key and the Shift key? The Shift key has to be held down while pressing the other key, eg h key to get H.
Pressing the Caps Lock key locks into upper-case, SO YOU GET A LINE LIKE THIS until you press it again.
Apr 08, 2010 | Computers & Internet
Cannot use the shift key to capitalize - keys
Check you didn't accidentally use the FN + NUMLCK key
This engages the numeric pad
Both are blue in colour
Sep 10, 2009 | Acer Aspire 5500 5570-2609 Laptop
Sakar 62150 Keyboard Logo
81 people viewed this question
Top Sakar Computers & Internet Experts
micky dee
Jim Thurston
Are you a Sakar Computer and Internet Expert? Answer questions, earn points and help others
