Question about GE AJCQ08ACB Air Conditioner
Power not getting power,i do see a little green test lite on but nothing happens when i push reset
  • gordens3 Jul 02, 2008
    The air conditioner was running and quit? I pushed the power button and nothing so I pushed the reset button and nothing.I checked the fuse and it's good.I live in Crosby ,Tx and no one around here works on them?Could it be the capacitor? Doug
    Novelist:
    Champion:
  • 230 Answers
It sounds like you have power to the circuit board but nothing coming out. I would say that it has a bad board. This could be a normal wear and tear failure, but be aware that a short or power surge of some kind may have caused the board to fail. A fuseable link or something may be necessary to protect the board in the event that the original problem is still there. I don't want you to blow another board:)
Posted on Jun 17, 2008
Ds light green,dim green, amber then off when power is turned on
Sounds like you need to send it in for repair. I had sent my console to VideoGame911.com and they repaired mine at a great cost and got it back at the end of the week. Give them a try, they are cheaper than a manufacturer. Good luck!
May 04, 2013 | Nintendo DS Lite
HP pavilion a705W pc desktop/ on back by power plugin, green light is on, push power button to turn on, light goes out and nothing happens. I opened panels and observed light again on back lite green and...
if you have installed a new hardware, that might be the cause. specially if it is a video card. The wattage of your power supply might not be enough to run the computer. try to remove newly installed hardware such as video card. If there is none, you may try to remove the power for the hard drive and the dvd drive and check if it will turn on. Just bood in to bios..
if that works, then it definitely is the power supply. it cant provide sufficient power to your equipment..
hope that works.
regards.
May 07, 2011 | HP Pavilion a705w PC Desktop
Green lite will not on . when unit is pluged in
press reset+power for 20 seconds, then release reset ank keep pressing power, it will turn on for 10-20 secs, in this time you must connect it to the pc. run tomtom home and make the upgrades that the program sais. must help.
Apr 20, 2011 | Tomtom One XL GPS Receiver
Turn key and nothing. no clicking. nothing. battery fully charged, lights and radio come on. Is it the starter? Or is there a fuse I do not know about?
could be the starter, get a cheap test lite and get under the truck, on the starter is 2 wires, a big one, and a little one, peirce the little one with test lite and have someone turn the key, if it lites up replace the starter
Oct 14, 2010 | 1999 Toyota Tacoma PreRunner
Green light but nothing actually powers on
You must have forgotten to fix the wifi modul.
Dec 08, 2009 | Nintendo DS Lite Console
DS lite green light comes on, top screen flash,then switches off
Check L2 near the power switch on your DS mobo. That part usually get loosen or taken out when you drop your DS. And usually you can recover it when dismantling your DS.
Jun 16, 2009 | Nintendo DS Lite Console
DS lite, power is on but nothing happens
Ditto... except my daughter is 10. Both screens remain black, are fully charged and green light stays on for more than 4 minutes.
Sep 14, 2008 | Nintendo DS Lite Console
Ds lite charging lite comes on but when i press power button nothing happens
Are you leaving the DS charge until the light comes off? Remember that there are two likes too, one for charging and one for power. If you're just charging for some random period of time (lets say... One hour) then your Battery isn't going to be fully charged. The best way to ensure that your DS Lite is charged is to leave it charge until the charge light turns off. You can play your DS Lite while you are charging (I do it all the time), but it just means that you're just running off of the outlet.
A good test is to charge it fully (until the charge light comes off), unplug the charger cord (Make sure it's secured tightly to your DS while charging), then play for a little bit, your light should be a normal color (green).
If you cannot even play by using the outlet, then you need to
find a charger cord that actually works (You may need to send in the charger for replacement). If the same thing happens with 2 different batteries (assuming that you have two official Nintendo batteries).
TIP: Also run your fingers across the Charger cord. You're going to get a slight friction burn from the rubber, but you're going to get all of the kinks out of the wire in the cord. My charger cord had a similar problem (did not charge all the way, only charged until I moved the DS) but when I ran my fingers across it (pinching) it worked again.
Also check the pins in both charger cords, charging will not work if one pin is missing, nor if any are bent.
May 12, 2008 | Nintendo DS Lite Console
GE AJCQ08ACB Air Conditioner Logo
104 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
