Question about Sakar 62150 Keyboard
Keyboard purchased a used iconcepts wireless keyboard and mouse with remote reciever. changed the batteries in both. the mouse works but the reciever will not recognize the keyboard. i have uninstalled and reinstalled the drivers from drivers guide and that does not seem to help. can someone help me find the correct drivers or a book and cd for installation. i am running windows xp pro. thanks jim
    Problem Solver:
  • 5 Answers
I've used the 62150 black combo on XP Pro, not the 62150N Deluxe silver combo, for years without a problem after setting them up. Had 2 PS2 ports so had to use an adapter for the keyboard connector. To sync, press the ID button on the receiver. LED will blink fast for a few seconds, then slower Press the ID button on the mouse and keyboard while receiver is still blinking (need a pen or something for the mouse button). If the receiver LED blinks whenever you move the mouse or hit the keyboard, it is receiving the signal. If the OS does not recognize input, it could be the connectors (I had separate PS2 for mouse and keyboard each).
Their website does not provide driver downloads or much user support - stop posting the link for everything SLSL2000.....
Posted on Jun 20, 2010
  • progman63 Jun 20, 2010
    BTW, receiver USB connector works both keyboard AND mouse.
    So you only need to connect that one cable to USB.
    That was my mouse problem.
Http://www.sakar.com/p-389.aspx?categoryid=181
Install receiver, mouse, then keyboard.
Posted on Dec 31, 2008
  • Rie Brosco Feb 18, 2011
    Thank you for your help. I could not get the rating system to work but I give you a 4 thumbs up. In the end, the usb device has to be pushed hard into it's port. I am not sure what is on the cd that comes with but once I changed the batteries that came with the keyboard to new ones and pushed the usb hard into the port, everything works. thanks for the link to the manufacture's site. Rie
New mouse does not work.
How does it Connect to your Computer? Probably has a USB Drive that you are suppose to plug in
Try turning your Batteries around (My Microsoft Mouse had the same issue and when I turned it around, everything started to work...
Apr 11, 2013 | Sakar Iconcepts Iconcept M01728 Wireless...
Mouse
Turn the Batteries Around and see if the Red Light on the Bottom comes on
How do you install new batteries in my Kensington PocketMouse 72214
i have the mini m. for awile want to install in another notebook dont remenber how> helpppp
Sep 23, 2010 | Kensington PocketMouse 72214
How to activiate iball wireless keyboard and mouse
My keyboard and mouse are microsoft, But, I think they all sync the same, Look on the bottom of the mouse and the keyboard, you should find a small button, one on the reciever also, these need to be pushed in a certain sequence, Mine is the keyboard first, then the reciever, watch the active light on the reciever, it should flash a few times then stay on, then it's synced, Do the same with the mouse, Your's could be different though, it could be mouse first. One more thing they need to be less than a couple feet apart when you do this. so that's it Good luck. Bob
Aug 01, 2010 | Computers & Internet
Keyboard and mouse not working
Can you give me more information...What brand of mouse and keyboard are they?
Do they use seperated recievers or does one reciever work for both mouse and keyboard?
Aug 27, 2009 | Logitech Wireless Access Duo Optical...
Problem with the wireless mouse
sounds like you need to resync the mouse to the wireless reciever. if this doesn't work than try replacing the batteries.
Feb 28, 2009 | Sakar iConcepts 4D Wireless Wheel Scroll...
Cannot connect wireless keyboard and mouse
I am assuming that this is an INFRA-RED device, with
plug and play capability.
1) Make sure that the infra-red port is turned ON on your PC,
in the BIOS and in Windows (using control panel)
2) Make sure that the infrared driver is working:
My Computer ==> Right Click ==> Properties ==>
Hardware ==> Device manager ==> ....
Find the Infra-red device and check its status.
Some laptops have a mechanical switch witch controls all
wireless ports. If you shut-off the Wi-Fi, the blue-tooth and
the infra-red will also be disabled.
3) Check for tiny reset buttons on the keyboard, mouse and
the receiver. Press them repeatedly.
4) If the device is communicating, and infra-red ICON
should appear on you taskbar (RHS).
Right click the icon and make sure you enable IR
communications AND plug and play.
5) Make sure you have installed any drivers that came with
the keyboard, if any.
6) Again, make sure that infra-red communications are enabled
in the control panel.
5) Failing that, it is possible that the keyboard is defective,
or the infra-red port on your laptop is NFG, it would not
be the first time.
6) You may want to take your keyboard to a computer
shop, and ask the staff the try it with a different PC.
Alternately, try a different keyboard with the laptop.
Martin
May 07, 2008 | Computers & Internet
CANT GET WIRELESS MOUSE TO WORK
Try changing with a new set of batteries. also try to reset the connection of the wireless mouse and keyboard. you can locate a connect button on both the reciever and wireless keyboard. press both of them together and release them. this would reset the connection. try doing the same for reciever and wireless mouse connect buttons. this should work. also check for any possible alignment issues.
Jan 15, 2008 | Computers & Internet
Belkin Wireless Mouse
Today I tried pressing the reset button on the bottom of the mouse, and at the same time pressed the button on the top of the remote reciever. I'd pressed both in the past, but never at the same time. This seems to have fixed this problem. I hope it's a solution for others also.
Dec 21, 2007 | Belkin Wireless Keyboard/Optical Mouse...
HOW TO SET UP AND USE TARGUS WIRELESS COMPUTER MOUSE
I have a iconcept wireless mouse, and can't get it work can you help me?
Sep 28, 2007 | Logitech 9312160403 Mouse
Sakar 62150 Keyboard Logo
1,066 people viewed this question
Top Sakar Computers & Internet Experts
micky dee
Ravi
Are you a Sakar Computer and Internet Expert? Answer questions, earn points and help others
