Question about Car Audio & Video
Hey there, ive just put a panasonic cq-c8401w headunit into my car, everythings hooked up properly, but when i turn my ignition on the stereo just lights up and says adjust then turns on abd just keeps doing it, how do i solve this problem??? Thanks heaps jodee
techman
  • 3130 Answers
SOURCE: Panasonic cq-c8303u Car stereo problem
There is for sure a hook up problem my friend. There should be a memory wire that always has power to it even when the car or the ignition is off. Then there is a switched type wire that only comes on when the cars ignition is on. Check both of these wires in the car. Check the car wiring diagram to confirm this. To confirm the wiring in this vehicle, I Good Luck with this install. And if all else fails, don't take a chance and blow out the unit, take it to a pro to be installed. Good Luck found the right wiring diagram for your car. Confirm this wiring diagram with this one you have. Go here:http://www.the12volt.com/installbay/stereodetail/955.html
Posted on Jun 20, 2007
pjstanley
  • 185 Answers
SOURCE: i need a panasonic cq-c1101u
sorry cnt help u
Posted on Apr 06, 2008
Benimur
  • 6966 Answers
SOURCE: i need the wiring diagram
Any developments?
Cheers.
Posted on Aug 03, 2008
SOURCE: wiring
I HAVE ONE SCREEN LANZAR SVTV7R, I NEED THE POSITION AND COLOR WIRING OR DIAGRAM ELECTRIC THE CONECTOR. THANK YOU.
Posted on Nov 29, 2008
etirbynnor
  • 655 Answers
SOURCE: error saying MUTING LV 0
Hello da_redhot_su,
Make sure that the "MUTE" button on the upper left of the volume control is operating properly. Sometimes a button will get stuck.
If that does not work, there's something wrong internally and you need to take the receiver to your audio dealer for repair.
Hope this helps.
Posted on May 08, 2009
Panasonic CQ-C8303U. Hooked up an amplifier and it works with the radio but when i put in a cd the amp doesn't work. the receiver just plays with normal sound.
Verify your wire connections are correct. Keep in mind that if your amp is hooked up to the radios power antenna wire this is the problem. When you insert a cd the radio is designed to lower the antenna. If your amp is hooked up to the antenna wire the radio is shutting off the amp when you put in a cd Panasonic does this on most of all their units. You may have to hook your amp up to a separate switch to turn the amp off and on or hook it to your ignitions acc wire, if you hook it up to your ignitions acc the amp will stay on as long as your key is on even if you turn off the radio.
Here's a link to download the manual for your radio just copy and paste it in to your web browser and download the PDF file. You will need the reader to view it. If you don't have the reader you can download it for free at www.adobe.com
http://www2.panasonic.com/consumer-electronics/support/Audio/Mobile-Electronics/CD/model.CQ-C8303U
Oct 09, 2010 | Panasonic CQ-C8303U CD Player
I have a Panasonic CQ-RX400U and I need to hook it up to a 1992 Ford Taurus and I need cables to hook it up and the thing that holds it in place in the dash.
I would get an stereo installation kit from Auto Zone or a local automotive audio store. It will come with the surround for the new stereo to fit where the old stereo went, and a wiring harness to hook the new stereo up to and plug into the existing car wiring.
May 20, 2010 | Panasonic CQ-RX400U Car CD/ MP3 Player
Need headunit pinout diagram for my Panasonic CQ DVR909U
Here's the manual link: http://service.us.panasonic.com/OPERMANPDF/CQDVR909U.PDF
and the wiring diagrams you're looking for are found on Pages 62 thru 65
I hope that works for you
May 05, 2010 | Panasonic CQ-DVR909U Car DVD Player
Reset code security for car stereo panasonic cq-vx100u
My friend have in car panasonic Cq-vx 100u them forgot the code. now Ineed a defaul code please sir.
Aug 18, 2009 | Panasonic CQ-VD7001U Car DVD Player
Panasonic cq-vd7003u ipod video trouble
The problem is that the panasonic cq-vd7003u does not support that function which sucks cuz i have one 2 the slightly newer verision PANASONIC CQ-VD7005U does have that feature. so sorry.
Mar 30, 2009 | Panasonic CQ-VD7003U Car DVD Player
How to remove Panasonic cq-c1301u unit from car
This is an interesting question. As to the fact that you didn't mention what kind of car you have, I can't give you exact instructions, but I can give you approximate instructions. Read all Instructions b4 you do anything and detach battery b4 working on system!!!!!!
1. Most car's require you to remove a dashboard panel, of not the whole thing. (on a side note, the panel on my jeep that has to be removed just pops out).
2. Next you need to unscrew the adapter kit from the car. A lot of older cars put Double DIN headunits into their cars, These are the larger sized headunits. Most after-market systems require a plastic adapter to allow them to fit into the larger space. As long as your new unit is the same size as the older unit, this piece can be reused.
3. Then you must remove the old headunit from the adapter. Most are either screwed in or have pressure pins that hold it in place. Either unscrew or carefully push down the pressure pins until you can remove the old headunit.
4. If you have already purchased the wiring kit, if necessary, then continue onto next step, otherwise purchase appropriate wiring kit for your headunit and car. Do not open wiring kit until you are ready to hook up your new headunit!!!!
5. Find new wiring kit, detach old wiring kit, and hook up new wiring kit according to included instructions. For best reliability, I recommend using wire nuts as electrical tape isn't as relaible and can come apart after a while. If you need to save space and can't use wire nuts, I recommend liquid electrical tape. Let this dry before you go any further.
6. Attach new headunit to adapter and then attach wiring kit to back of the headunit. Make sure to attach radio cord to back of headunit. Push adapter and headunit back into place, adjusting wires as necessary. Screw adapter back into place.
7. Re-attach dash panel back to car, reattaching screws where and if necessary and reattach battery. Power up car and test system.
8. Listen away.
If you cannot get this to work, most places like Best Buys and Circuit City have professionals that have the necessary parts and expertise to exchange headunits in cars and can do this for a small fee. Just replacing a headunit should be relatively cheep. Adding other components as well would be more expensive.
Mar 25, 2009 | Panasonic CQ-C1303U CD Player
I have the panasonic cq-c8303u radio and i would like to hook up the ipod to it. any tips?
You need to get the Direct Cable for iPod® (CA-DC300U) from panasonic. This allows you to plug in and control your ipod from your headunit. There is also the expansion module (CY-EM100U), however I am not sure if this is necessary if you have the Direct Cable. The Direct Cable might plug directly into the back of the headunit without the need for the expansion module. Check with the company before purchasing one or both. If the direct cable requires the expansion module, then get both, however, I think the direct cable works independent from the expansion module. Again, contact the company about this. The expansion module also lets you plug your ipod as well as other devices into your headunit, however I don't think it allows you to control them via the unit. I think if you want to control the ipod from your headunit, you just need the Direct Cable for Ipod®.
Mar 23, 2009 | Panasonic CQ-C8303U CD Player
Not for sure which is the hot and which is the ground wire.
Solid black is always ground on aftermarket head units. Red is usually the ignition wire, ie when you turn your car on, your stereo turns on. Hot or positive is usually yellow and usually the biggest wire
Mar 21, 2009 | Panasonic CQ-C1101U CD Player
Jun 19, 2007 | Panasonic CQ-C8303U CD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
