Need to find a replacement switch - Heating & Cooling
  • 1,711 Answers
Which is your model and brand
Posted on Nov 06, 2010
Switch bad need to bypass switch
Monica, I highly recommend you replace the switch. By passing the safety of a switch on any appliance or tool endangers both yourself and those around you. Just to by pass the switch, you would need to disassemble the appliance. If you are going to do this then get a replacement part and replace it. :) Safety comes first , especially where mechanical and electrical devices are used.
Nov 08, 2013 | Shop Vac Vacuums
Replacing safety switch under seat - how do I get it and replaced?
some of the switches you need to remove the seat cover to install the switch
Jul 08, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How to remove ignition
you need haynes repair manual for 1993 suburban it has photos and information you need to help you replace ignition switch.i am mechanic i use haynes,chiltons and gm manuals.if you are a home mechanic do it your self you need haynes repair manual it has step by step instructions to remove the steering wheel and remove lower steering column reason i say need haynes repair because your steering wheel has a air bag in it you need to see how to remove air bag in steering wheel you need to read through the entire ignition switch removal procedure if you are going to replace ignition switch with keylock cylinder you will also need steering wheel puller. you need a tool compress lock plate to remove lock plate retaining ring from steering shaft in order to get to the ignition switch in the steering column below turn signal switch.
Feb 03, 2012 | 1993 GMC Suburban
Need to replace the light switch in my bathroom.
yes there the same type of switch,,just one is more up to date than the old one
Mar 28, 2010 | Leviton 1451-2ACP Grounded Quiet Switch
I need to change the bulb in the switch for the passanger side heated seat switch on my 2006 honda odyssey
There is no way to just replace the bulb. You need to replace the hole switch. The bulbs are molded in the switch when they make them. To get the switch you need to go to dealer for it.
Jan 12, 2010 | Honda Odyssey Cars & Trucks
WE HAVE TO PUSH OUR GREEN PRINT BUTTON WAY TO HARD TO GET IT TO WORK ON OUR PC 920
You will need to remove the front control panel assembly (2 screws and 1 ribbon cable) with copier opened like removing a paper misfeed (or replacing toner unit). Next, you will need to separate circuit board from control panel in order to gain access to the switch under the green print button. Sometimes, you can use electrical contact cleaner (tuner cleaner) to spray into the switch itself, pressing the switch numerous times to evaporate the solution from inside contacts of said switch. Now use a multimeter to check for continuity while depressing the switch and releasing. If cleaning the switch fails, either the switch will need to be replaced or the control circuit board will need to be replaced...replacing the switch isn't difficult, if you know how to solder. Reassembly is reverse of disassembly.
Nov 24, 2009 | Canon PC-920 Black and White Copier
How too replace pressure switches
Is the switch screwed to a line or the accumulator? Or is it on the compressor?
Mar 30, 2009 | 2003 Jeep Liberty
Broken on/off switch
need to replace the on/off switch for this camera. I have the broken piece that cannot be repaired. How can i find a replacement switch. I can repair the camera myself with the new switch. thanks.
Jul 19, 2008 | HP Photosmart M425 Digital Camera
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
