Question about Exercise & Fitness
Instructions for celsius enduro treadmill understanding mode settings
Track enduro 450 does not start. power light on but nothing else works
If you wish to get some details about treadmill repair ; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Dec 16, 2016 | Exercise & Fitness
Oven
do you mean celsius ?depending on the recipe and if your talkin about celsius you can covert it to fahrenheit . 180c is 356f
Apr 18, 2014 | Kitchen Ranges
How do you use it
--- SCANNED INSTRUCTIONS ---
CLOCK AND DATE SETTING: 1. Press and hold MODE button for three seconds. The minutes display will begin flashing. Press MODE button to switch among minutes, hour, 12/24 hour, month and day. 2. Press ADJ button to set value of the minutes, hour, 12/24 hour, month and day. NOTE: Original screen will return after one minute of inactivity. To view the date, press ADJ button.
ALARM CLOCK SETTING: 1. Short press MODE button to switch from clock to alarm clock. 2. Press the ADJ button once to make the D))))) symbol appear, which will indicate that the alarm is on. Press ADJ button again and a bell symbol will appear, indicating hour notification signal is on. The hour notification signal
sounds once at the top of every hour. Press ADJ button again to activate alarm clock and hour notification signal, press ADJ button again to clear all.
MEMORY FUNCTION: 1. Press the MEMORY button for maximum temperature and humidity to display. Press MEMORY button again for minimum temperature and humidity to display. Press MEMORY button again to return to current temperature and humidity. 2. Press and hold MEMORY button for three seconds to clear maximum temperature, minimum temperature and relative humidity.
COMFORT DISPLAY: When temperature remains between 68F to 82F (20C to 28C) and the relative humidity remains between 50% and 70% "COMFORT" will be displayed. When relative humidity is above 70% "WET" will be displayed. When relative humidity is below 50% "DRY" will be displayed.
FAHRENHEIT/CELSIUS: To switch between Fahrenheit and Celsius, press FAHRENHEIT/CELSIUS SELECTOR button on back of unit.
INSTALLATION: 1. Use provided suction cups to position the sensor probes in the terrarium. 2. Position THERMOMETER & HYGROMETER in desired location outside of terrarium with a built-in stand.
BATTERY TYPE: 1 PC Button cell (AG13/LR44)
WARNING: Install THERMOMETER & HYGROMETER and sensor probe out of reach of pets and away from water.
For more information about All Living Things products, please call 1-800-806-7870.
Dec 24, 2013 | ALL LIVING THINGS Digital Thermometer &...
Temperature of my Voltas AC has changed from Celsius to Fahrenheit..How to change it back
May be the settings vary from one model of AC to another . In case of Voltas vertis premium AC ( Indian make ) , after turning it to OFF , pressing the MODE and " - " ie minus button simultaneously , the C and F could be shifted . This info is printed on the back of the remote itself .
Jun 04, 2013 | Cars & Trucks
I am looking for a relative humidity sensor which is operable at 400 degrees Celsius.
go to http://www.alibaba.com/showroom/humidity-sensor.html
God bless you
Jun 21, 2012 | Exercise & Fitness
Croc only heats up to 230 degrees is there a way to reset it
CHANGE TEMPERATURE SETTING from CELSIUS to FAHRENHEIT
To Change the Temperature Setting from CELSIUS [230 Degrees] to FAHRENHEIT [450 Degrees]
If [230] appears on the display screen, then the temperature is set to Celsius. To change back to Fahrenheit:
1. Turn off your flat iron and unplug from electrical socket (wait for 10secs).
2. Then plug the iron back into the electrical socket.
3. Press & hold down the HIGH [?]button, then press ON/OFF button. An "F" will appear on the digital screen. Your device is now in Fahrenheit mode.
Jul 23, 2011 | Crocs Croc 2 Flat Iron Titanium Plates 1"
I have a Quinton Clubtrack treadmill Error E105 NVRam Failure
fax me @ 281-469-9550 your full model number and I can fax you the setup modes.
Jun 27, 2009 | RTO Stairmaster Clubtrack 510 Treadmill
Trouble setting Date
TO SET THE DATE:
Press the MODE button until the Year is displayed.
Press SET button
(the YEAR starts to blink)
Press the MODE button to Increase the Year
Press HOUR button to increase the Month
Press MIN button to increase the Day
To Change between Fahrenheit and Celsius.
Press the MODE button until the Time field is blank
Press MIN button to toggle between Fahrenheit and Celsius.
Nov 26, 2007 | Sharper Image SI585 Clock Radio
Exercise & Fitness Logo
180 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
