Question about Williams 5008732 Gas Compact Heater
How do i ajust pilot light flame it sounds like a torch is on
  • Williams Master
  • 3,284 Answers
Should be a ajustment screw on the gas valve by the pilot suppy
Posted on Nov 06, 2010
Two burner Infra-red wall heater. How can pilot flame be ajusted?
if the flame is more than 2" high, most likely faulty unit. I've not seen that brand that was adjustable. OKC Mont
Oct 07, 2015 | Vanguard Heating & Cooling
Small Pilot flame on MrHeater MHBF20lpt & pilot won't stay on.
You will probably need to remove the pilot orifice and clean it out use a small needle or orifice cleaning rod. The pilot flame is not big enough to keep the thermocouple engaged.
Dec 22, 2013 | Mr. Heater Heating & Cooling
Pitco fryer
Hi there!
Try to check first the incoming and running gas pressure, it must comply with the rating on the unit's nameplate.
Regards
Jan 26, 2013 | Pitco Frialator Kitchen Appliances -...
One of the top burner pilot lights will not stay
You probably have grease that has gotten into the pilot. Turn off the gas to the pilot and detach the pilot tubing and pilot tip. It sometimes helps to take a propane torch and heat up the pilot tip and tubing, paying special attention to the first bend from the pilot tip. Get it red hot and tap out any ash from the inside. You may have to **** out the tubing with a piece of bare wire or blow it out with WD-40. With the oven pilot, check the pilot flame. If low, adjust. If OK, replace the thermocouple. If neither of these corrects the problem, replace the pilot satety. I always recommend a new thermocouple with a new pilot safety.
Feb 23, 2010 | Vulcan Kitchen Ranges
Kenmore gas oven won't light. The pilot light is on but no gas. What do I do?
Put a torch on the probe. If the flame comes on them the thermocouple is weak.If nothing at all replace the safety valve.That is if you have a standing pilot. If you pilot is an electric one then it should be so bright it is hard to look at but if it is dim orange it is weak.
Sep 07, 2009 | Kenmore 30169 Electric Single Oven
Pilot light will not stay lit
use a torch to simulate pilot flame and read milivolt. if ok then make sure pilot flame is fully contacting thermopile. also make sure thermopile wiring connections are clean and secure.
Jul 16, 2009 | Imperial IFS40 Deep Fryer
Turn up pilot light
The ajustment screw to increase the intensity of the piolet flame is located on the oven gas valve(behind the cntrol knob.
Apr 04, 2009 | General Electric Stove/Oven/Range Chrome...
My ventless gas heater has an uneven flame with orange tips, the flame toward the outer edge is higher than the flame in the middle, and also,when I light the heater, it doesn't just give me a piolot...
This sounds like your gas valve is weak. An orange flame has to much gas and not enough air mixture. Have you trie to ajust the air mixture. If it won't ajust then you will need to replace the valve.
I hope this helps.
Oct 24, 2008 | Heating & Cooling
Reddy heater TB100 propane
Well it sound like you have all the components working. Try lighting it with a torch or long match or something. If it lights, then you may need to adjust the spark-er. You also may need to adjust the pilot. It may be too much pressure, which will blow out the flame, or its not enough gas. Make sure the pilot orifice is clear.
Mar 01, 2008 | Reddy Heater-30-55,000 BTU Variable
GE GAS RANGE OVEN PROBLEM
two options.first does the pilot flame look good (a nice blue flame)?if so you will see a metal probe next to the pilot,use some sandpaper and clean that probe up.if that solves your problem so be it.second if the first thing doesnt work its probably the ignitor board not sensing the flame.the way to definitly tell the one or the other use a small torch and heat up the probe like i said and turn the oven on.if the main burner comes on then you know its the probe which is called a thermocouple and is cheap.hope this helps.
Aug 08, 2007 | GE JGBC20 Gas Kitchen Range
Williams 5008732 Gas Compact Heater Logo
96 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
