Marantz 2270 receiver
What are the steps necessary to change the panel lights on my Marantz 2270 receiver? I've taken the face plate off and the plastic outer cover to the dial and meter display. Still see no way to get to the lights and change them!
Thanks,
John Davis
    Genius:
  • 1,175 Answers
On some of the Marantz 22XX receivers you need to pull all the screws that hold the Front panel assembly to the main chassis. You'll need to remove the bottom chassis cover as well.
Once screws are out , tip the top of the front panel towards youand you can get access to the screws that hold the lamps assemblies
ALL these marantz units have plastic lamp shrouds that dry up and get VERY brittle. Dont be surprised if some of the plastic breaks
Posted on Dec 17, 2014
  • 979 Answers
The lights are on the other side of the display. They have a plastic "wave guide" that deflects the light where needed. I hope this helps...accordianman
Posted on Jun 14, 2008
How do I change light globe in NN-ST656W microwave and where is it, I've taken off the outer cover
Usually there is an access cover just above the microwave cavity, right behind the grill vent.
Oct 18, 2014 | Microwave Ovens
Cannot access door latch assembly 2009 JEEP LIBERTY
all this is covered in the FSM. step by step. under body or doors.
2nd best is alldata.com
what door? you never said and steps can very by body options.
name the door,
i guess the latch is bad?
here are the words, for door lock motor.
lots of steps. my wild guess , it the door cover is off.
and the plastic film removed
and you get stuck here,
  1. Remove the tape covering the access hole on the carrier plate and discard. Access the window regulator liftplate through the hole in the carrier plate.
  2. Push down the door glass (1) and use a slotted screwdriver to release the tab on the window regulator liftplate (2). Lift the glass up and secure to the header.
  3. Remove the three screws (2) securing the door latch to the door shut face.
  4. Remove the one screw (1) attaching the latch bracket to the door shut face.
  5. Disconnect and remove the electrical connector (1) from the door (4).
  6. Remove the 10 screws (3) from the carrier plate (2).
  7. Disconnect the outside mirror electrical connector.
  8. Remove the carrier plate (2) from the door (4). end
once carrier is out there is chapter on that , disassebly
really, buy the FSM
or log in to alldata.com
and avoid making wrong moves, or getting hurt.
Apr 02, 2014 | 2009 Jeep Liberty
Realistic STA-2270 Stereo Receiver
The pivot that balances the fm signal meter has jammed, it would have to be taken apart, the outer lens removed to attempt a repair, this is a very tricky operation, if you hit the receiver on the side nearest to the meter, the needle should move back and forth freely,"indicating the meter is good" but if it fails to move the mechanical part of the meter is faulty.
Apr 14, 2012 | Marantz 2270 Am/fm Stereo Receiver
When I load papers into the document feeder on top of my HP Officejet 7210 All-in-One printer to scan these documents, the PDF file (scan results) have a multi-color series of lines from top-to-bottom on...
  1. Remove all originals from the document feeder tray.
    NOTE: It might be easier to work with the automatic document feeder if the document feeder tray is removed first.
  2. Lift the cover of the automatic document feeder. Figure 1: Lifting the ADF coverc00222493.gif
  3. Lift the lid on the HP all-in-one, and locate the notch near the top right edge of the lid backing. Figure 2: Locating the notch near the lid backingc00222494.gif 1 - Notch 2 - Lid backing
  4. Place one or two fingers in the notch, as you lower the lid of the HP all-in-one. Keep your fingers in the notch until the lid is almost closed. Figure 3: Inserting fingers into the notchc00222495.gif
  5. Push against the top of the face plate with your thumb as you pull the bottom away from the right side of the HP all-in-one with your fingers. Use a slight twisting motion to help release the face plate on the right side.
    CAUTION: Do not pull the face plate all the way off yet. There is a plastic catch on the far left inside of the face plate that helps secure the face plate in place. If the face plate is pulled straight off, the plastic catch on the inside of the face plate might be damaged. Figure 4: Releasing the face plate from the right side of the HP all-in-onec00222496.gif 1 - Releasing the right side with a slight twisting motion
  6. Slide the face plate to the left until the plastic catch on the left side is not touching any part of the HP all-in-one, then pull the face plate away from the device. Figure 5: Removing the face plate from the HP all-in-onec00222497.gif 1 - Sliding the face plate to the left 2 - Pulling the face plate away from the HP all-in-one
Cleaning the rollers or separator pad Follow the steps below to clean the rollers or separator pad.
  1. Once the face plate of the ADF is removed, use the blue-green handle to lift the pick assembly. Figure 6: Blue/green handle and the pick assemblyc00222498.gif 1 - Blue-green handle 2 - Pick assembly This allows access to the rollers and the separator pad. Figure 7: The rollers and the separator padc00222499.gif 1 - Rollers 2 - Separator pad
  2. Lightly dampen a clean, lint-free cloth with distilled water, then squeeze any excess liquid from the cloth.
  3. Use the damp cloth to wipe any residue off of the rollers or the separator pad.
  4. If the residue does not come off using distilled water, try using isopropyl (rubbing) alcohol.
  5. Use the blue-green handle to lower the pick assembly.
Reattaching the face plate of the ADF Follow the steps below to reattach the face plate to the front of the automatic document feeder.
  1. Hook the face plate onto the left side of the HP all-in-one so that the plastic catch on the far left inside of the face plate catches on the notch on the front of the automatic document feeder. Figure 8: Hooking the face plate into the left side of the HP all-in-onec00222500.gif 1 - Notch 2 - Plastic catch
  2. Line up the right edge of the face plate with the right side of the HP all-in-one, and then press on the right side of the face plate until it snaps securely into place. Figure 9: Snapping the face plate into the right side of the HP all-in-onec00222501.gif
  3. Place your hands towards the center of the face plate, and press until the center of the face plate snaps into place. You should hear two clicks; one when the left side snaps into place, and one when the right side snaps into place. Figure 10: Finishing re-attaching the face platec00222502.gif
  4. Close the cover of the automatic document feeder.
  5. If you removed the document feeder tray, reattach it.
Dec 07, 2010 | HP Officejet 7210 All-In-One InkJet...
My Marantz 2270 sounds great when first turned on, for about 20 minutes. Then it starts crackling very loudly on both channels. Is it expensive to get this fixed?
No, it's not expensive to get fixed. The circuit board has over heated through time and some of the solder connection have weakened. Inspect the circuit board for cold solder connection and reapply heat and solder.
Nov 04, 2010 | Marantz Audio Players & Recorders
I have an Elna 6003Q sewing machine. My light bulb went out and I need to replace it. How do you get it out and replace it?
some call it a lamp cover door or face plate it's on the left side of the sewing machine
some sewing machines have a hinge at the back of the face plate, you can gently pull it open to change the bulb
some machines -in the middle of the face plate there is a plastic plug, use a screw driver to gently lift the plug & then unscrew the screw & change the bulb.put the face plate back on put the srew back in & put the plug back in to concile the screw
Sep 27, 2010 | Elna 2007 Mechanical Sewing Machine
Can you tell me where I can print instructions for free to help me change my timing belt in a 93 ford festiva
Here are the instructions for removing the timing cover, and for replacing the timing belt. If this is helpful, please click my accept button! Thanks!
Remove accessory drive belts.
  1. Remove water pump pulley to pump hub attaching bolts, then the pulley.
  2. Remove right inner fender panel to gain access to crankshaft pulley.
  3. Remove outer crankshaft pulley attaching bolts, then the outer stiffener/spacer and outer pulley
  4. Remove inner stiffener/spacer, attaching screws, inner pulley and baffle plate.
  5. Remove attaching bolts, then the upper and lower timing covers.
  6. Reverse procedure to install. When installing crankshaft pulley, ensure curved lip on baffle plate and deep recess of inner pulley face outward
  1. Remove timing belt covers as outlined previously.
  2. Remove timing belt tensioner pulley attaching bolt, then the tensioner pulley, spring and spring cover
  3. If reusing old belt, mark direction of rotation on belt to aid installation.
  4. Remove timing belt from crankshaft and camshaft sprockets.
  5. Check crankshaft and camshaft sprockets, tensioner pulley and timing belt for wear or damage. Replace components as necessary.
  6. Align camshaft and crankshaft sprocket timing marks with marks on cylinder head and oil pump housing
  7. Install timing belt. If reusing old belt, ensure belt is installed so that direction of rotation mark made during removal is positioned correctly.
  8. Install spring and spring cover onto tensioner pulley, then install pulley and attaching bolt. Do not tighten bolt at this time.
  9. Install tensioner spring onto anchor, then tighten pulley attaching bolt to torque listed at the end of this section.
  10. Reinstall timing belt covers.
This photo shows timing marks.
Jul 14, 2010 | 1993 Ford Festiva
Where is the light bulb located?
Unscrew the vent at the top of the microwave(2 phillips head screws)
inside to the right you'll see another screw holding a metal panel. Unscrew this and take the panel off and you'll see the bulb, which will unscrew counter-clockwise
Nov 03, 2006 | LG LRMM1430 Microwave Oven
347 people viewed this question
 Grubhead
Grubhead
