Question about GE Profile JKP56 Electric Double Oven
What does an FO display mean on GE Profile double oven?
5 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: GE Profile oven beeps and displays FO
Your electronic oven control(clock) is bad and must be replaced.
Posted on Sep 02, 2009
rickzilla
  • 706 Answers
SOURCE: GE Profile double Built-In Oven error Code
According to the GE User manual... any F# error code means you have a function error and they suggest you press the CLEAR/OFF pad and allow the oven to cool for one hour. Then put the oven back into operation. If the function code repeats, disconnect all power from th eoven for at least 30 seconds and then reconnect it.. If it still comes back.. call for service.. however it has been my observation that F0 is usually a shorted off key on the keypad. Hope this helps..
Posted on Sep 22, 2008
localwonder
  • 6784 Answers
SOURCE: ge profile double oven. The bottom oven is beepin
HI, this is a Stuck button on the function pad or, the clock or ERC(control board) is damaged. Try to free the stuck button.(in some models, this is not an option). if the pad is fixed(keypad and board are integrated), simply replace the oven control board.
Posted on Jul 27, 2009
jumptrout51
  • 3361 Answers
SOURCE: ge profile performance double oven. getting an F7
F7 is a stuck keypad/button.
Push all buttons at random several times each. This will sometimes un-stick a stuck button.
If that does not work the keypad control will have to be replaced.
Posted on Jan 16, 2010
How do I clear an error code FO on my GE oven
it usually means the touch pad or the oven control is defective.
Dec 05, 2015 | GE Ovens
What is a fo code on ge doulble wall oven
It is more than likely the touch pad is bad. It could be the electronic control or worst case both. Touch pads are notorious for giong bad. i would look there irst.
Oct 07, 2014 | GE Profile JTP56 Electric Double Oven
I keep getting FO code and beeping won't clear
Hello George,
The F0 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F0 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
GENE
Oct 05, 2011 | GE Profile JKP56 Electric Double Oven
GE profile wall, single, Get a
Hello,The "FO " reading you get is as a result of "Shorted Clear/Off key due to the membrane switch,control or connector".And these mean you have to check the Shorted key panel membrane switch; Check Electronic Range Control(ERC)
Thanks
Jun 02, 2010 | GE Profile JTP18 Electric Single Oven
Sep 02, 2009 | GE Ovens
GE JT912-30 single wall oven "help" with F7 - F0 error
I have a double oven GE Profile. The error message FO appeared. I shut off the circuit breaker for 30 minutes or more and the oven works but without warning FO reappears. FO message means there is short in the clear Off touch button. The only solution replace the complete panel. My cost delivered $328. Ouch!
Jan 19, 2009 | GE Profile JKP56 Electric Double Oven
Sep 21, 2008 | GE Profile JTP56 Electric Double Oven
JTP56 Double Oven Beeping and Display FO Code
http://www.fixya.com/howto/h155060-dreaded_f7_error
May 18, 2008 | GE Profile JTP56 Electric Double Oven
Fo function error code
The F0 usually means that there is a problem with the keypad.
My solution for the F7 problem may help. You will find my solution at the following link.
http://www.fixya.com/howto/h155050-dreaded_f7_error
I have now shared my fix with over 1600 folks and most report success. I hope that it works for you too. Please let me know at:
hutchipop@yahoo.com
Charlie Popeck, P.E.
Consulting Engineer
Mar 07, 2008 | GE Profile JKP56 Electric Double Oven
Ge profile double wall convection oven
My solution for the F7 problem may work for you. It won't cost you anything to try it. It is simple and free. You can find it at the following link:
Please let me know if this works for you. You can email me at:
hutchipop@yahoo.com
Good Luck,
Powerman
Feb 03, 2008 | GE Profile JTP18 Electric Single Oven
Open Questions:
The convection fan comes on intermittently, starts smoking then goes off. Temperature on the display doesn't move from 100F (then it did). My wife left the door closed while it was on broil last night (not sure how long), and this morning I woke up to the smell of burnt electrical and something (one of the fans...? not sure as it was far earlier than I usually get up) running that stopped when I opened the oven door and restarted when I closed it (I'm thinking it was probably running all night). While at work, I turned the breaker off, then pulled the oven out this evening. After taking some of the metal plates off, I put the power back on and turned the oven on for a 450F bake. I don't know if the little cooling fan at the top of the unit is supposed to go on when I have the top exposed and getting plenty of air; it wasn't and it also had a faint burnt electrical smell. After disconnecting then plugging the fan power connector to the circuit board the fan ran for 10-15 seconds before it started smoking and quit. I checked voltage across the fan leads and there wasn't any. I shut the oven off, tripped the breaker, and let it cool. I then tried testing the fan motor directly i.e. bypassing the oven and using a regular outlet since the motor is rated for 120V. It ran for ~1 minute, then smoked and quit. The smoke is definitely coming from the fan rather than any adjoining wires. Is this a case of the fan AND the control board going south or one contributing to the other's demise? I should add that the clock display has been dimming for a couple of years. UPDATE (2/20): I tried just baking (as opposed to convection baking) and the bottom element did come on (I'd reported earlier that it hadn't... that was because I was using convection baking and that does only heat around the fan... just my ignorance on that one). However, the temperature readout on the display did not move from 100F though it was clearly hotter than that in the oven. I then stopped the baking mode and started convection baking. This time the temperature gauge immediately went to 141F and kept climbing. Resistance at the (room temp) temperature sensor (and at the end of the wiring harness plugged into the control board was ~1100 ohms at room temp (as its supposed to be).
Feb 19, 2016 | GE Profile JKP56 Electric Double Oven
See all GE Profile JKP56 Electric Double Oven Questions
GE Profile JKP56 Electric Double Oven Logo
437 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
