What is IT and communication? - Computers & Internet
    Brigadier General:
  • 10,406 Answers
> What is IT ?
IT == Information Technology
Posted on Nov 06, 2010
Have a 2005 ford expedition with 5.4 l eng its throwing code u1900 . what is this
U1900 CAN Communication Bus Fault Vehicle Security Module REFER to Section 418-00 . U1900 CAN Communication Bus Fault 4WD Control Module REFER to Section 418-00 . U1900 CAN Communication Bus Fault-Recieve Error Parking Aid Module REFER to Section 418-00 . U1900 CAN Communication Bus Fault-Recieve Error DSM REFER to Section 418-00 . U1900 CAN Communication Bus Fault-Recieve Error Instrument Cluster If the 4X4 light is not flashing at key ON, REFER to Section 418-00 .
If the 4X4 light is flashing at key ON, REFER to Section 308-07A . U1900 CAN Communication Bus Fault-Recieve Error Power Liftgate Module REFER to Section 418-00 . U1900 CAN Communication Bus Fault-Recieve Error Stability Assist Module REFER to Section 418-00 . U1900 CAN Communication Bus Fault-Recieve Error Air Suspension Module REFER to Section 418-00 .
which module won't communicate ? need a up scale scanner to communicate with all the modules on the vehicle. Do you know what C.A.N - controller area network is ? Serial data bus (network) All the modules on the vehicle share data on the network . U code's indicate a problem with the network .
Aug 08, 2018 | Ford Cars & Trucks
Error Code: E197 0000 in cannon 2900 printer
Printer engine communication error
Erroneous communication between the DC controller PCB and image processor PCB was detected.
- Check the connectors of the DC controller PCB and image processor PCB.
Replace the DC controller PCB for normal connection. - Replace the image processor PCB.
E197 0000 Laser Driver PCB communication error
Description :
Description Error in communication with the Laser Driver PCB (communication data failure)
Causes :
Solutions :
Remedy
1. Check the Laser Scanner Unit connector.
2. Replace the Laser Scanner Unit.
3. Replace the DC Controller PCB (PCB1).
Nov 16, 2017 | Cannon Office Equipment & Supplies
Where is the hdm module on 2006 monte carlo ltz
HDM module ??????? No such module .
DTC U0100 00: Lost Communication With Engine/Powertrain Control Module (ECM/PCM)
DTC U0101 00: Lost Communication With Transmission Control Module (TCM)
DTC U0121 00: Lost Communication With Electronic Brake Control Module (EBCM)
DTC U0140 00: Lost Communication With Body Control Module (BCM)
DTC U0151 00: Lost Communication With Restraints Control Module
DTC U0155 00: Lost Communication With Instrument Panel Cluster (IPC) Control Module
DTC U0164 00: Lost Communication With HVAC Control Module
DTC U0168 00: Lost Communication With Vehicle Theft Deterrent (VTD) Control Module
DTC U0170 00: Lost Communication With Passenger Presence System (PPS)
DTC U0184 00: Lost Communication With Radio
DTC U0186 00: Lost Communication With Audio Amplifier
DTC U0194 00: Lost Communication With Digital Radio Receiver (DRR)
DTC U0198 00: Lost Communication With Communication Interface Module (OnStar®)
DTC U0209 00: Lost Communication With Heated Seat Module (HSM)
DTC U0214 00: Lost Communication With Remote Function Actuation (RFA)
These are all the modules onyour vehicle - no hdm module .
Oct 13, 2017 | Cars & Trucks
Why do we need English communication classes ?
English communication classes help you improve your professional communication in English for successful business interactions. Each course focuses on a particular area of communication in English: writing emails, speaking at meetings and interviews, giving presentations, and networking online. Whether you want to communicate to potential employers, employees, partners or clients, better English communication can help you achieve your language and professional goals. The course will focus especially on making those important connections to take your career or business to the next level. Make yourself more competitive by improving your English through this class: Improve Your English Communication Skills.
Apr 27, 2017 | Miscellaneous
I have 08 ford escape when I try to scan it said no communication
Do you know about communication networks or serial data communications on vehicles , these let the scan tool communicate with the different modules on the vehicle ! Newer vehicles have several, PCM - powertrain control module , Anti-theft module , Air bags , antilock brakes , Body control module or in the case of ford a smart junction box . an some others !
Communications Network Vehicle communication utilizes both International Standards Organization (ISO) 9141 and controller area network (CAN) communications. ISO 9141 is used for diagnostic use only, and CAN is used for many modules to communicate with each other on a common network. CAN in-vehicle networking, is a method for transferring data among distributed electronic modules via a serial data bus. Without serial networking, intermodule communication requires dedicated, point to point wiring resulting in bulky, expensive, complex, and difficult to install wiring harnesses. Applying a serial data network reduces the number of wires combining the signals on a single network. Information is sent to the individual control modules that control each function.
The vehicle has 3 module communication networks:
  • ISO 9141
  • Medium speed (MS) CAN
  • High speed (HS) CAN
All 3 networks are connected to the data link connector (DLC). This makes diagnosis and testing of these systems easier by allowing one scan tool to be able to diagnose and control any module on the 3 networks from one connector. The DLC can be found under the instrument panel between the steering column and the audio unit.
HS-CAN Network Operation
The HS-CAN network communicates using bussed messages. The HS-CAN network uses an unshielded twisted pair cable, data bus (+) and data bus (-) circuits. In addition to scan tool communication, this network allows sharing of information between all modules on the network.
The HS-CAN is a high speed communication network used for the following modules:
  • ABS module
  • 4WD control module (if equipped)
  • Instrument cluster
  • PCM
  • MS-CAN Network Operation
    The MS-CAN network communicates using bussed messages. The MS-CAN has an unshielded twisted pair cable, data bus (+) and data bus (-) circuits. In addition to scan tool communication, this network allows sharing of information between all modules on the network.
    The MS-CAN is a medium speed communication network used for the following modules:
    • SJB
    HS-CAN Network
  • What type of scan tool are you using ? or are you using a code reader ?
  • What
Computer No Communication Troubleshooting by Wells Saturn Toyota Echo No Communication Case Study
Mar 18, 2015 | 2008 Ford Escape
Plz help sc 681 in ricoh mpc 4500
• NoiseRFID: Communication error • Communication error occurs when the RFID starts to communicate with the RFID receptor. • Retry of RFID communication fails three times after the machine has detected the RFID communication error.
The problem is Defective RFID reader and writer • Disconnected ASAP I/F • No memory chip on the toner cartridge • Noise
Mar 14, 2015 | Ricoh Aficio MPC3500
Kode error konika photocopy
Defective main PCB.
Energy save communication problem • Communication errors from the communication microcomputer on the main PCB. No communication: there is no reply after 5 retries. Abnormal communication: a communication error (parity or checksum error) is detected five times in succession.
Mar 18, 2014 | Kyocera Mita Office Equipment & Supplies
Call for services code : E7-80
Communication trouble
between the MFP control
and the scanner (MFP
control detection)
Communication
establishment error/
framing/ parity/ protocol
error
Follows the
communication protocol
specifications.
Communication error,
timing abnormality of the
communication data and
the communication signal
line
Dec 05, 2013 | Sharp AR-M700N Copier
I got a code from auto zone that is i believe UO 101 AND UO105 OR UA101 AND UA105 WHAT do these codes stand for
These codes are communications code errors:
The UO101 is a transmission communication error: poor communication to your transmission ECM / computer
The UO105 is a fuel injection communication error: Poor communication to your fuel injector ECM/ computer.
Jun 15, 2011 | 2006 Dodge Stratus
Hi how are you , mt problem in xerox copy centre 245 , the code is    03-372 i cannot scan a photo and attach it to an e-mail. i get a message that the fax extention has been disabled by...
03-321, 322, 326, 327 LLM to ISIL communications problems 03-328 IOT communications problem with duplex or tray 4 03-330 IOT communications problems with HCF 03-335, 03-336 LLM communications problems with edit 03-340 NVM memory 03-341, 03-347 Communications problems between IOT and sorter 03-350, 03-354 Communications problem with LLM and user interface 03-363, 03-364 Communications problem between LLM & optics 03-370, 03-372 Communications problem between LLM & DADF 03-380, 384 03-416, 03-422 RAM memory problem 03-424, 426 NVM memory problem 03-430, 432 Billing problem 03-439 GRAIB communications problem 03-440 RIC communications problem 03-441 RIC NVM problem 03-442 Modem 03-443, 03-458 RIC problems
Jul 05, 2008 | Office Equipment & Supplies
Computers & Internet Logo
16 people viewed this question
Alun Cox
k24674
