Question about Panasonic NN-T694SF Microwave Oven
My panasonic nn-t694sf microwave has worked great for a few years. However, tonight it made a crackling sound inside and shut off after 8 seconds of use. Now each time I turn it on, it runs for 8 seconds and then shuts off. Is there anything I can do to fix this so I don't have to purchase a new one. HELP!
3 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic NN-T694SF smoke, shuts itself off
In most cases, this is a problem with the inverter or a bad transfotmer.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Posted on Oct 22, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Hello i have a panasonic model nn-l5263a
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
The panel you describe - if inside the cavity - is not the light cover, but the waveguide cover.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Mar 02, 2009
NN-T563 shuts off after 5 seconds
We recommend you use the below link to locate an authorized service center. Panasonic microwaves have a 5 year warranty on the microwave.
www.panasonic.com/repair
Apr 12, 2014 | Panasonic NN-S563 Microwave Oven
Microwave shuts off after a few seconds. message says to check the manual. What's wrong?
The problem is the magnetron, or the inverter board, "if 7 years old or less" and possibily the keypad control board.
Apr 28, 2012 | Panasonic NN-S262SF Microwave Oven
Our s333 panasonic microwave stops working after 1 second?.. it just shuts off?? can you advise?
It probably requires a new magnetron or an invertor board or both. Take it to an authorised Panasonic repair agent for an estimate for repair.
Jan 24, 2011 | Panasonic NN-T694SF Microwave Oven
Panasonic NN-SD277. Almost 3 years old. We pressed start, it went for about a second (may have made a sparking sound) and then it just lost all power. There is still power to microwave but no lights are...
We also have this same microwave. It is less than 3 years old. We've had nothing but problems since we purchased it. In November 2010, the microwave made a crackling sound and then BOOM! Nothing. I have been back and forth with Panasonic. I refuse to pay for the repair on an appliance that is less than 3 years old. It's ridiculous!
Anyway, the problem t is an issue with their inverters. Google it and you will find page after page of the same story.
Jan 21, 2011 | Panasonic Microwave Ovens
It is actually NN-T695SF, it will not warm food. It powers up then goes dim, then powers up then goes dim, it keeps doing that. Food comes out cold.
Hi, if it is an inverter microwave and the problem is cycling every 2-3 seconds, my experience is the magnetron has most likely gone short circuit and the inverter board is shutting down to protect itself and then restarting, hence your symptom.
DO NOT try to test this unless you are experienced with extra high voltages - the voltages present/stored in a microwave even when powered off can kill you.
Aug 13, 2010 | Panasonic NN-T694SF Microwave Oven
My Panasonic Inverter S333 just suddenly stopped working. I get a "refer to manual" message. Manual has no help to offer. Even the "signal bell" sounds a little off. Up until today, it was working just...
My Panasonic Inverter S333 just suddenly stopped working April 30 after I used it for only two years, no showing in panel. It will run only when I open the door, it is strange.
Apr 19, 2010 | Panasonic NN-T694SF Microwave Oven
My NN-T994SFR Panasonic Microwave shuts off after 1 second.
My unit shuts off after about 2 seconds. It seems like it tries to go, but it sounds like it stops working and then 1 or 2 more seconds run off and it shuts down. Then you hit start again and it lights up inside and then shuts down. It's only about 2 or 3 years old.Any solutions?
Mar 05, 2010 | Panasonic Microwave Ovens
Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Feb 01, 2010 | Panasonic NN-T994SF Microwave Oven
Panasonic Model No. NN-S933BF Microwave Oven
No sorry the issue will be with eiher the inverter, the magnetron or the main timer board. There is a tracer signal that comunicates through these components and if it doesnt get to where it is supposed to go it wil just shut off, the big hint at that is the time interval. It is not something like a sensor heating up and causing a fault. it is not running long enough to get any thing hot it is in the electroincs. Too expoensive to repair, im sorry better to get a new one. Good Luck
Jun 17, 2017 | Panasonic NN-S950BA Microwave Oven
Oct 20, 2007 | Panasonic NN-T694SF Microwave Oven
Panasonic NN-T694SF Microwave Oven Logo
105 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
