Question about Biostar P4M900-M7 Fe VIA P4M900 Socket 775 mATX Motherboard w/Video & Audio
Could not activate spdif (no sound) - Biostar P4M900-M7 Fe VIA P4M900 Socket 775 mATX Motherboard w/Video & Audio
Philips TV has spdif out bose sound has optical in
Use the spdif connections (best) if possible after that digital coax (orange cable) then component (5) RCA cords Lower quality) in that order.
Nov 07, 2013 | Kenwood VR-506 Receiver
Lg e500 no spdif output
If you open your sound card properties, you have to tell the hardware (soundcard) to use the SPDIF. For some models of Realtek sound cards, it requires and adapter that you plug into the port and offers optical or coaxial. I could not find anything stating that your PC requires it but I dont have the serial number of your PC to find if you have a different version of the soundcard used in your model notebook.
Also, make sure you are using the proper SPDIF cable to your reciever. This is a digital connection so it requires a 3.5mm to standard male coaxial (RCA) cable. If you are using one, then you just need to make sure that your soundcard knows to ouput audio through the SPDIF port.
Hope that offers some help. If you need further assistance, let me know!
Oct 21, 2009 | LG E500 Express Dual Series Notebook PC
Directing Creative Soundblaster X-Fi synths to SPDIF
I have researched this same problem with my SB X-FI Fatality Gamer Edition and the answer I came up with is that you cannot output sound ( at least not 5.1 surround sound ) through the SPDIF out. Supposedly, this port is used for " some other reason " that I could never clarify. The only solution I ever uncovered was to buy the breakout box for the sound card.
Sep 27, 2009 | Computers & Internet
SPDIF IN/OUT not working on Gigabyte p35c-ds3r
hiya
you may have to set the input on your deck to digital b4 it will recognise the signal
Rik
Feb 21, 2009 | Gigabyte Computers & Internet
Audigy 2zs
u need a 2or 3 pin spdif cable from the spdif on ur gpu to the spdif on ur mobo/soundcard. check manuals of ur gpu and mobo/soundcard for correct pin diagrams. dvi wont carry audio even if using HDMI adaptor, u need to ling the gpu to soundcard/mobo depending on what u use for sound.good luck
google "nvidia spdif to soundcard cables"
Jul 14, 2008 | Creative Labs Audigy Gamer Sound Card
Spdif output on my motherboard dont work how can i fix it i install the driver but no sound
You need to change the output to SPDIF in the sound card settings.
Jul 07, 2008 | Computers & Internet
Spdif pins
First of all when you got these pictures were they from *********** board?If they were did you wear a wrist bracelet to prevent Electro Static Discharge (ESD)? If not you may have just ruined your computer. But there is a chance you didn't. Next I am not positive but you might need to get a three pin SPDIF connector from Radio Shack. But I would try the one you have. See if it works. But I must warn you going inside your computer if you are not a technician can be very harmful to your computer. So if you take my advice Touch some part of metal on the outside edge so you are grounded to your computer.
P.S. Damage from ESD may not be right away. It can be months from when the computer was shocked. If my advice doesn't work tell me and i will give you much more help.
Hope this Helps.
RCF
Apr 26, 2008 | Creative Labs Sound Blaster Live! 5.1...
Receiver compatible with tv
yes digital suround sound is optical spdif k like coxial digital if it dont have analog outs or does it have headphone jack in front run a eth in mini jack to rca offf that to video 1 of sterio ok
Feb 10, 2008 | Televison & Video
SPDIF Output
SPDIF output is only for the integrated digital tuner.
Jan 23, 2008 | Philips 37PF5521D 37 in. HD-Ready LCD...
Biostar P4M900-M7 Fe VIA P4M900 Socket 775 mATX Motherboard w/Video & Audio  Logo
76 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Matthew Spark
Matthew Spark
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
