Question about Frigidaire FLEB8200DS Top Load Stacked Washer / Dryer
My dryer has stopped heating completely. Worked fine for six years and stopped heating four days ago.
  • Frigidaire Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Apr 02, 2011
Whirlpool electric dryer LER5620KQ1. won't heat up timer does not advance
Same problem with my Whirlpool Dryer: Model LER4634EZ2 which stopped heating. I checked the coils that was "OK" then I checked the fuse that was "OK" I replaced the Thermal Fuse and High Limit Thermostat then after starting the dryer the heat came on ... problem solved NO.... the dryer just kept running and running until I opened the dryer door. Not going to put 70 or so $$$ into this 10 year old dryer which up until 12/15/2011 worked fine.
Dec 08, 2011 | Whirlpool LER5636P Electric Dryer
My Maytag Dryer DE608.. does not get any heat. It worked great 2 days ago.
heat element can be bad. you can fine heat element inside at the back of the tumbler
Oct 15, 2010 | Maytag Washing Machines
One month ago, my gas dryer began taking forever to dry the clothes. Upon inspection, I noticed I had a very badly clogged outside vent. I removed the vent and replaced the entire length of vent from the...
It sounds like it never was the thermostat. Usually when a thermostat goes there is no heat at all, unless it was the cycling t-stat, but unlikely. This sounds like the dryer coils are failing. They tend to fail as they heat up. They are inexpensive and easy to replace.
Here is a video at this will walk you thru the troubleshooting a gas dryer. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Sep 28, 2010 | Whirlpool LGB6300 Gas Dryer
I have a roper dryer red4440sq0 that will not turn on.. I have checked all power its going to the dryer and hitting what it needs to hit and suggestions?
I bought this dryer 2 years ago. After exactly 1 year, the heat stopped working completely. It turned out to be the Thermal Cutoff device ($20). Then, just last week, the thing stopped working completely. It took me all of 10 minutes to determine that it was the Thermal Fuse (http://www.appliancepartspros.com/part_details.aspx?part_id=3132867), just by using my continuity detector on the two terminals. I unhooked the terminal wires, stuck them together, and the dryer turned on fine. They count on people buying new dryers completely whenever one of these dinky little parts made by child laborers in Asia fail. The fuse is $10 at the site I just linked.
Nov 09, 2009 | Dryers
I have an similar problem with my Amana Dryer LEA30AW.
First Clean out your filter, Assuming the element is okay and cut-out are fine it should run okay, you could also try running it on low heat will take a bit longer but hey if it works great..Good luck
Oct 01, 2009 | Dryers
Dryer will not heat
check heating element,,,and thermister
Jul 06, 2009 | GE DPSR610GGWT Dryer
No heater fan in all switch positions
are you talking about the fan that blows heat into your car or the fan that cools your engine
Jan 20, 2009 | 1990 Oldsmobile Cutlass Ciera
Frigidaire FLEB8200DS Top Load Stacked Washer / Dryer Logo
131 people viewed this question
Top Frigidaire Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Jason Harris
Jason Harris
Sal De
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
