Hi! Welcome to www.fixya.com.
You need to get an Windows Operating system XP
Option 1:
Boot from your CD and follow the directions to start Recovery Console. Then:
Attrib -H -R -S C:\Boot.ini
DEL C:\Boot.ini
BootCfg /Rebuild
Fixboot
Option 2:
Boot from your CD and follow the directions below to start Recovery Console.
Insert the Setup compact disc (CD) and restart the computer. If prompted, select any options required to boot from the CD.
When the text-based part of Setup begins, follow the prompts; choose the repair or recover option by pressing R.
If you have a dual-boot or multiple-boot system, choose the installation that you need to access from the Recovery Console.
When prompted, type the Administrator password. (if you didn't create one try pressing enter).
At the system prompt, type Recovery Console commands; type help for a list of commands, or help commandname for help on a specific command.
Most likely you will need to expand the file from the CD. The command would be expand d:\i386\hal.dl_ c:\windows\system32\hal.dll. Substitute d: for the drive letter of your CD. Once you have expanded the file type "exit" to exit the Recovery Console and restart the computer.
TIP: Recovering Windows XP using the Recovery Console
Hope this resolution fix the problem on your computer.
Thanks for contacting Fixya. Bye for now.
You did not mention what is the manufacturer and what is the operating system you have but you can try following:
hal.dll is the file which protects your hardware devices to access the memory directly. HAL ( Harware Abstraction Layer).
To repair hal.dll we would require the recovery discs else you can try recovery console in your computer
1. press the power button and keep tapping on F 11 for HP computer and ctrl+F11 for Dell computer
2. check if you get a Recovery Manager
3. you can perform a recovery from here
Windows 2000 and XP have a recovery console. You manually restore the hall.dll. Here is the exact procedure:
1. Insert the Windows CD and start the computer
2. When the Welcome to Setup screen appears, press R
3. Type a number corresponding to the Windows installation you wish to repair (usually 1) and press Enter
4. When prompted, type the administrator password and press Enter.
5. Enter the following (assuming the you O.S. is installed on partition C:): ATTRIB -H -R -S C:\BOOT.INI DEL C:\BOOT.INI BOOTCFG /REBUILD FIXBOOT
6. Exit the console, remove the disc and restart your computer.
For that first you have to fix error on harddisk. Boot computer with recovery disk then choose recovery console mode. Then type in prompt "chkdsk /r" then press "y" then it fix error on harddisk then install windows. Let me know if you need more assistance. Thanks.
first boot your computer with winxp recovery disk. then ewnter in recovery console then type in command prompt "chkdsk /r" then press "y" then it fix error on disk. then check.
This issue happens if boot files are corrupted .. you need to have the Operating System Cd to resolve this problem . Considering you have windows xp you need to have the installation cd for windows xp .
you need to use bootcfg command to resolve the issue.
Go to bios and change the boot sequence to boot from the cd, if you are not able to boot from the cd. and then boot using windows xp cd .
Then push R to go to recovery console and use the below command
Boot to Recovery Console and rebuild the BOOT.INI file with the BOOTCFG /REBUILD command.
BOOT FROM YOUR WINDOWS DISC AND CHOSE OPTION RECOVERY CONSOLE AND USE THE GUIDED HELP...BUT FIRST DOWNLOAD THE MISSING FILE AND COPY IT TO WINDOWS 32 SYSTEM FILE FOLDER.RICHARDM69
Issue : Blue screen - Missing HAL.DLL error message Solution : 1) Insert your windows XP CD into your CD/DVD drive. 2) Restart your computer. 3) Press the F12 key to access the one time boot menu. 4) Select Onboard or USB CD-ROM Drive. Press any key when prompted. 5) The Windows XP Setup will launch. 6) Press R to choose the Repair option and enter recovery console on the Welcome to Setup Page. 7) bootcfg /rebuild 8) Enter Y and press enter 9) Type Microsoft Windows XP Home Edition or Microsoft Windows XP Professional Edition. 10) Type /fastdetect 11) Type Exit
