Question about Vacuums
Myself forget my samsonite bag pin codeplz tell me how i can open my bag..
  • 34 Answers
Try this...http://wiki.answers.com/Q/How_do_you_reset_the_code_on_a_Samsonite_suitcase
Posted on Nov 06, 2010
It's locked and everything imp like my clothes atm etc is inside I am using this bag for first time but it's not opening up
Dial the three wheels to 0-0-0, which is the default combination setting for American Tourister and Samsonite luggage.
Try this setting
Feb 24, 2016 | Vacuums
I put a new vacuum bag in and I get no sunction at the other end of the hose.
Make sure the hose is attached securely to the main vacuum body.
Make sure there are no obstructions in the hose or at the hose opening in the body.
Make sure the cover for the vacuum cleaner bag compartment is securely shut.
Good luck.
Comment back here on this page if you are still having difficulties and don't forget to click on the 4 Thumbs Up rating icon if this was at all helpful.
Feb 16, 2011 | Kenmore 22313 Bagged Canister Vacuum
New wheels for my Samsonite case? one wheel has completely seized
You might get replacement ones but maynot be the same type.
So it is better to get details from their site noted below:
give your request in the contacts site :
www.samsonite.com
Sep 13, 2010 | Vacuums
I can't recoil the electrical cord. What do I need to do?
Open the bag door, remove the bag (leave door open)and then with a hammer and a blunt instrument(wooden dowel) Strike the side rubber "bumper" rails towards the open door side of the machine from the back of the vacuum. You should get it started and then it should easily pull out from both sides. you can remove the bottom of the vacuum and remove the cord "guard" to allow the cord to go thru also. The back is held on by the union of these two halves by dowel pins(plastic nubs) Sometimes the "spring" mechanism gets jammed from over pulling. Just simply roll the smaller wheel to retract the cord manually. You could try spraying the rollers with a silicone or graphite type spray to allow free movement of the spring. Hopes this helps. WFServices
Jun 25, 2010 | Electrolux Lux 7000 Bagged Canister Vacuum
Bad bag sensor
yes it is very simple to take apart and replace. for screws on the bag door and then it is only 3 wires to pull off of old switch
Apr 01, 2010 | Electrolux Guardian Bagged Canister Vacuum
I broke the zipper on the cloth bag on my kirby gen. 3 can i replace this myself
Yes.
To order Kirby vacuum bags, replacement parts, or cleaning products, please visit your local independent Kirby Distributor, or call:”
1-800-437-7170 United States and Canada
Nov 15, 2009 | Kirby Generation 3 Bagged Upright Vacuum
How do you replace the bag on a Hoover Elite 200?
I had the same problem and just figured it out myself. Detach the clamp (attamched to the bag) from the handle. Then slide the bag out from the clamp either left or right. The cloth bag then opnes and you can replace the actual bag inside. Hope this helps.
Nov 11, 2009 | Vacuums
Vacuum won't stay on
When you open the canister you eill see a little rubber hole that senses when your bag is full. This must be clogged. If you have another vac try to vacume all the dusr from this hole and any other opening inside the vacume that you can reach. I hope this helps. Don't forget to rate this answer.
Feb 07, 2009 | Electrolux Epic 6500 Vacuum
Replacing the foot pedal
there is two C clips on the pin that must be removed first. then the pin will come out. if you need a picture of this or have any other trouble feel free to let me know. I also stock those foot pedals if you need one.
Aug 10, 2008 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
Repair my Electrolux 2100 cannister vacuum cleaner
On my 6500, I just disconnected the air line from the switch and now the vaccuum won't sense the bag pressure; I just have to check the bag myself now.
Jun 19, 2008 | Electrolux Epic 6500 Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
